365 BB Chassis 17553 Nut and Bolt Restoration | Page 11 | FerrariChat
Discussion in 'Boxers/TR/M' started by cnpapa24, May 11, 2019.
  1. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,436
    Canada
    Newman
  2. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    ronc52 and ChipG like this.
  3. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    moysiuan, TerryG!, tbakowsky and 3 others like this.
  4. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    Bundle of wires with no terminals are for the console controls. I needed to remove the blade connectors to be able to slide the new sheathing over the main harness where it had been cut open.
    More pics of the general condition of the harness.
    4th pic is the wiper / headlight switch connection just beside the steering column. I replaced all three hardshells but wanted to show the difference by replacing the center one for the shot.
    Center console wiring with new sheathing, blade connectors and silicone terminal covers.
    Under dash connections behind gauges, old brake pedal switch.
    Fuse blocks on earlier cars are better than the later ones, the bean counters in action.
    Front section of main harness. Top of the pic is where it runs along the right side of the inner fender then goes down through an opening with the fan ducting. It handles lighting, headlight lifting motors, horn all along the right side then goes across the bumper structure to power the rad fans (2 single terminal bullet connectors with light blue wires). 365 has 2 fans, 512 has 3. Fn ground are from the motors to the frame structure. Then at the end of the harness it feeds the left headlight, signal, rad fan switch , grounds and headlight lifting motors.
    of2worlds likes this.
  5. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    Working on the next batch of subassemblies.
    A/C box. Pretty sure I wouldn't want to have to find one if this one was broken. Hole in the screen is for a sensing bulb to pass through and sit inside the fins.
    Headlight lifting motors, horn compressor and of course those red things are horns.
    Horns raise a question. When the 512 horns were hidden under the right headlight up until the 1978 model year they were medium blue. Once they went up front for all to see they became what I call Candy Apple red. So did early 365's have red horns that were hidden then Ferrari switched to blue or were these replaced with later horns?
    I suspect replaced. Ill investigate and welcome input from anyone in-the-know.
    A/C blower and heater blowers, rad fans and shifter are next.
  6. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
  7. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
  8. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
  9. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    Fans had black paint to cover the primer overspray from a previous paint job. Once the paint was off I could see shiny areas here and there, especially the hub. So polished them on my polishing wheel to bring them back.
    Right half of blade is after the polishing wheel.
    Inconsistent look is from reflections in the blades
  10. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    I had one extra Lucas fan motor that was as rough on the outside as the original 74 motor. Once apart the original motor had one magnet out of position and the other had a crack - two too many magnetic poles. So Ill use the magnets out of the incorrect motor housing to make 2 motors out of 3.
    Hold the retainer tabs up and I can slide the magnets out of the housing.
  11. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    samsaprunoff likes this.
  12. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    Ill go through the motors, paint them and apply new decals I reproduce.
  13. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
  14. jjeffries
    jjeffries Formula Junior
    Sep 4, 2012
    254
    Connecticut
    John Jeffries
    Paul, rookie question: are the hard wiring connectors Molex brand? My old Alfa had similar looking parts.
    Digging your work always and appreciating the opportunity you give us to look behind the curtain.
    Thanks, John
  15. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    I didn't see a name on the original ones and the new ones are not that brand either.
    You're welcome!
  16. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    Shifter refresh.
    365 has a universal joint on both ends of the shifter shaft as does dino etc. By 1976 they had the small silent block bushings on both ends.
    Note large conical spring in the middle of the picture. Its the spring you depress when you go to select reverse. There's a second spring that presses against the side of the shifter pivot ball which is responsible for giving you the spring loaded centering action in the neutral gate while you play with the shifter at a red light.
    The large conical spring does two things on this shifter. It gives you a reverse lockout of sorts in conjunction with the gate but also centers the shifter fore and aft making the shifter always wanting to return to center. Ferrari did away with this conical spring by 76 (not sure when exactly) and added one in the bottom cup you see hanging off the bottom of the shifter. This gave you the lockout for reverse but took away the fore and aft centering the shifter leaving only the side to side neutral centering.
    Took two shots because my camera can't focus on the gate and ball at the same time. What a great looking part, I think I need one just lying on the corner of my desk.
  17. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
  18. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    I detailed the air diverters, park brake lever and linkage as well but thats not very exciting stuff to look at. Onto the a/c box now then the next bin of parts.
  19. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    A/C box finished.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Based on the location of the white streaks its from the brake fluid reservoirs above thats been spilled and leaked onto the cowl and found its way inside through the blower motor hole. Its directly beneath them so that makes sense. Two solutions. Leave it since you'll only see it here on the bench or paint the box. Painting plastic is never a great solution.
  20. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    of2worlds and samsaprunoff like this.
  21. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
  22. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    I would like to thank Ron, Dyke, Sam and Nick for valuable input on some small but very important details. Although I work alone its never a one man job.
    turbo-joe, cnpapa24 and of2worlds like this.
  23. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    Cleaning the brass hardware. Just like getting the yellow out of the plastic I tried a few different techniques I saw on-line until something worked. My first attempt was ketchup and it did nothing, yes I filled that container with ketchup and put the parts in it - smelled good, that's about it. Yes I could use brasso and clean each piece by hand or find something that does it while I do other things. So this mixture is flour, vinegar and salt. I let it sit about an hour then rinsed under the tap.
    pshoejberg and of2worlds like this.
  24. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    rovexienus and of2worlds like this.
  25. of2worlds
    of2worlds F1 World Champ
    17,882
    ON
    CH
    Ferrari car 'ART' there!
