360 Spider CEL Not Detected By OBD2/EOBD Tool | FerrariChat
Discussion in '360/430' started by Greg Salazar, Apr 15, 2020.
Tags:
  1. Greg Salazar
    Greg Salazar Rookie
    Apr 15, 2020
    2
    Greg Salazar
    My 360 Spider popped a CEL yesterday. Feels mechanically sound. My NX501 OBD2/EOBD tool says there aren't any codes. Is the tool just not reading properly?
  2. eric355
    eric355 Formula 3
    1,163
    Toulouse (France)
    Eric DECOUX
    Is your tool able to read both ECUs ?
  3. Greg Salazar
    Greg Salazar Rookie
    Apr 15, 2020
    2
    Greg Salazar
    Hey Eric. It detects both ECUs, but I only saw relevant data from one of them.
  4. eric355
    eric355 Formula 3
    1,163
    Toulouse (France)
    Eric DECOUX
    Greg, that's probably why you don't see the DTC which set the CEL.
    You need to connect to each of the ECU and read the DTCs, if any, in each of them.
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    In the US, the single connection for the OBD2 under the dash will read OBD codes from both ECUs. That is because … it's the law. The smog shops have to be able to detect the OBD code to pass or fail the car and all they have is one single OBD2 connection. Therefore, Ferrari somehow allow codes for both sides to be read from a single port. I guess the two ECUs talk to each other. As to why the CEL does not show up, may be because it is not emission related.
    But, from that one connection, only live data for one bank is visible.
  6. RedNeck
    RedNeck F1 Veteran
    9,969
    The CSA
    Me
    Here is a trick I learned from @imahorse that may end up being your issue. I have a Foxwell 510, that for some reason could never read the right side ECU,even though it could see it in the software. Turning on the immobilizer prior to reading codes fixed this issue. You may try and see if you have a similar situation.
    imahorse likes this.
  7. yelcab
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    You mean "deactivate" the immobilizer?
    EastMemphis likes this.
  8. RedNeck
    RedNeck F1 Veteran
    9,969
    The CSA
    Me
    push button=turn on deactivation :D:p
