360 - 360 Running Rough | FerrariChat
360 360 Running Rough
Discussion in '360/430' started by Aeron Fout, Jul 7, 2020.
  1. Aeron Fout
    Aeron Fout Karting
    Nov 21, 2019
    88
    Cocoa Beach, FL
    flyadf
    My 360 all of the sudden started running very rough as soon as I finished washing it the other day. I am very careful not to get a ton of water in the engine bay or intakes. I drove it for about 10 miles with no improvement, came home and cycled the battery switch off then back on, and it started running like new again. Has anyone experienced this? Could it possibly have ingested a little water during the wash?
  2. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    Unlikely that any water got in through the intakes. There are drains the the air box so it really can't get in that way. As for why, you will never know. That cycling the battery is a 'fix' for anything is one of the most stupid internet legends that is constantly propagated. Cycling the battery is a last resort, not a troubleshooting/maintenance process. When you cycle the battery you clear any codes that are stored so you will never know what was having issues.
    SpencerMarks and EastMemphis like this.
  3. one4torque
    one4torque F1 Veteran
    5,122
    Houston
    One4torque
    A few items to check:;
    bad mass air meter
    Try swapping w known good mas
    Or pull codes and swap side to side
    oil in intake
    It can build up over time
    Did you have oil change or added recently?
    o2 sensors... prefer to see a code b4 swap
    gl
  4. vrsurgeon
    vrsurgeon F1 World Champ
    15,917
    Charleston, SC
    Curt
    coils. I'd pull the coils and dry them out at least..
    RANDY6005, one4torque and 24000rpm like this.
  5. RedNeck
    RedNeck F1 World Champ
    10,011
    The CSA
    Me
    Never cycle the battery until you pull any pending codes, then you are stuck asking a bunch of forum goons on the internet about a problem with no information to go on. Wait till it happens again and pull the codes. If it doesn't, congrats.....but it will still be a mystery.
  6. Aeron Fout
    Aeron Fout Karting
    Nov 21, 2019
    88
    Cocoa Beach, FL
    flyadf
    Not my first rodeo. I did pull the codes before doing anything else. Only one was for emissions because of my deleted cats.
  7. hessank
    hessank Formula 3
    1,746
    Canada, Florida
    Fred
    Yes, I did.
    There was another thread on how to clean your engine using a bathroom foam product and then carefully rinsing it off. Well I did that and low & behold when I started it it ran like crap. I had used an open ended garden hose with the tap 1/3 open so a little more than a trickle to wash off the foam.
    I pulled the codes and all were on misfires. Knowing that the car ran perfectly before the wash I attributed it to water ingestion or shorting due to the water and not worry about the mass air sensors or O2 or anything else. I concentrated on drying it out. I let it ran like crap for about 10 mins to heat up the engine, bought a shop vac that can be reversed to push air instead of suck (you know the type) and also left the hatch open in the sun for about 4 hours.
    I then cleared each code and it restarted and ran like nothing happened.
    Never doing that again!
    Aeron Fout, Skidkid and Apollo 11 like this.
  8. RedNeck
    10,011
    The CSA
    Me
    Well it wasn't mentioned in the post. Most likely you turning off the battery had nothing to do with the "fix". On top of that,it may not have been failing long enough to produce any codes..on top of that we have no idea what scanner you are using, many of them can only talk to one of the ECU's and the codes are stored on the other...so I'll stand by my claim that there was not enough info in your original post for any kind of helpful dialogue.
    It's completely plausible (and has happened to me on other cars) that there were traces of moisture had made their way down into one or more of the coils, especially if they are older, and caused misfires which would cause the car to run like crap...and had dried out by the time you performed with the battery reset.
