360 precat inspection with bore scope | FerrariChat
Discussion in '360/430' started by cladd2000, Jun 12, 2019.
  1. cladd2000
    cladd2000 Formula Junior
    518
    i have a snap-on bore scope and to me it looks like all I will need to do is remove the front oxygen sensor, insert the scope and look backwards. Sound right?
    I guess that I will have to disconnect the wire/electric plug for the oxs prior to removal or the wires will get all twisted up.
  2. RedNeck
    RedNeck F1 Veteran
    9,965
    The CSA
    Me
    Yes you will have to take the panel off and disconnect the lambda sensor before twisting it out.
  3. cladd2000
    518
    Just got done. What I saw forward was just a metal mesh screen. Looked back and saw ?2 pipes coming together. So I am guessing the pre-cats sit behind that screen and then obviously cannot be seen through the front oxs hole.
    Nice to know there is a screen there to prevent the larger cat fragments from being viciously sucked back into the motor as the sellers of replacement headers have suggested.
  4. cladd2000
    518
    I should say, I looked back towards the rear of car and saw screen
    At first I thought it was the cat. Same pattern but metal
  5. mello
    mello F1 Veteran
    5,041
    CA Bay Area
    Steve
    It would be an interesting thread if you can post a picture of it.
  6. cladd2000
    518
    I can picture take with scope. Geez gotta do again
