360 - (360) Heat exchanger replacement DIY | Page 2 | FerrariChat
360 (360) Heat exchanger replacement DIY
Discussion in '360/430' started by fotostars, May 11, 2019.
  1. hessank
    hessank Formula 3
    1,742
    Canada, Florida
    Fred
    Instead of bypassing the HX buried below the manifold didn't someone install another style of HX close to the fender?
  2. fotostars
    fotostars Formula Junior
    Feb 6, 2015
    341
    Bay Area
    Yes, the 2 banjo bolts are feed and return of transaxle oil. The coolant goes through the 2 boots/reducers on each end going through the Heat Exchanger. I would have started by giving a 1/4 turn extra to the clamps that hold the boots to the H/E. They should be accessible with a long extended ratchet from the top (threading in between the intake plenum pipes going down to the head)....
    What you see leaking from the banjo bolt may be coming from the boot high on the HE and it catches the banjo and leaks from there.
    If you actually have coolant coming off from the banjo, your transaxle is toasted!
    Good luck...
    EastMemphis likes this.
  3. tonino ct
    tonino ct Karting
    Mar 1, 2018
    127
    tonino tony
    My are power seats, do i need to remove the tracks?
  4. tonino ct
    tonino ct Karting
    Mar 1, 2018
    127
    tonino tony
    You wore 110% right. I was able to see where was coming from. I worked the scope camera around the HE and notes coolant coming from the end of the boot facing the engine. Ur suggestion is to replace the boot? Or just tighten the clamp?
  5. fotostars
    Feb 6, 2015
    341
    Bay Area
    Try tightening the clamp first, sometimes that's all it takes... Easy, cheap, rewarding... :)
  6. tonino ct
    tonino ct Karting
    Mar 1, 2018
    127
    tonino tony
  7. fotostars
    Feb 6, 2015
    341
    Bay Area
    The suspense is killing me ;-) Verdict?
  8. 24000rpm
    24000rpm F1 Rookie
    the track and the seat are one unit. you remove 4 bolts and the track/seat are free to go
  9. tonino ct
    tonino ct Karting
    Mar 1, 2018
    127
    tonino tony
    Great. Thanks.
  10. tonino ct
    tonino ct Karting
    Mar 1, 2018
    127
    tonino tony
    all good. Leak stopped. Tomorrow i will bring it up to temp and check it again
    fotostars likes this.
  11. tonino ct
    tonino ct Karting
    Mar 1, 2018
    127
    tonino tony
    Here is the latest. I was putting the cover back on the TB and I notes the right belt is lose. I had my mejor service 2 years ago and did 5k miles. should i just tighten or replace the Hydraulic Tensioner. Or they just forgot to set it. Take a look and tell me what do you tink. Thanks
  12. tonino ct
    tonino ct Karting
    Mar 1, 2018
    127
    tonino tony
  13. tonino ct
    tonino ct Karting
    Mar 1, 2018
    127
    tonino tony
    Is it possible to remove the heat exchanger just removing the pump assembly? I need to replace the botts on the heat exchanger. Thanks.
  14. RedNeck
    RedNeck F1 Veteran
    9,979
    The CSA
    Me
    It is, that's how most people do it. I removed my intake so I could replace my runner gaskets
  15. tonino ct
    tonino ct Karting
    Mar 1, 2018
    127
    tonino tony
    I saw the leak coming from the boot close to the engine. Ones i tide the 2 clamps it started to leak like crazy only with 5 pounds od pressure. Did i over tighten? Did i bend the exchanger? New is 900$. Any way i can still use it ? Or should i just change the boot? Whats your advice? Car only has 20k miles, but is still 17 yers old. .
  16. mdileo
    mdileo Karting
    Jan 27, 2015
    60
    Nyc
    Max
  17. mdileo
    mdileo Karting
    Jan 27, 2015
    60
    Nyc
    Max
  18. tonyc
    tonyc Formula 3
    Oct 19, 2003
    1,641
    Monterey, CA
    Tony C
    I am going to this update during my next major, I spoke Greg and he convinced me that its one of those parts that will eventually go out.
  19. 02360spider
    02360spider Formula 3
    1,730
    Dartmouth
    Richard oliveira
    That company no longer makes the kit are you making your own kit?
    Sent from my SM-G996U1 using Tapatalk
  20. tonyc
    tonyc Formula 3
    Oct 19, 2003
    1,641
    Monterey, CA
    Tony C
    I can barely use a screw driver, I will contact Greg and see what's up with that.
  21. Martaroony
    Martaroony Rookie
    Oct 5, 2020
    17
    Australia
    Marty
    Hey Guys , can anyone help with advise on where to buy replacement aftermarket 360 Heat exchangers. By all accounts , they seem quite hard to come by, and are there any design improvements, ie: different metal makeup, or increased capacities. etc. Thanks in advance. Marty.
  22. clean512
    clean512 Formula 3
    2,027
    Josh @jtcarprojects
    I emailed them about 2 months ago and they told me a new version is coming out soon
  23. 02360spider
    1,730
    Dartmouth
    Richard oliveira
    Lol I wouldn't hold your breath I talked to them 3 years ago.
    clean512 likes this.
  24. fotostars
    Feb 6, 2015
    341
    Bay Area
    Just use the OEM part. If you flush your coolant regularly, you shouldn’t have a failure.
  25. Martaroony
    Martaroony Rookie
    Oct 5, 2020
    17
    Australia
    Marty
    Thanks Clean512 for your reply, I was more so talking about original position replacement, I dont think the Dynamic Tech group option is viable.
    I thought some one may have reproduced them for original Placement with revised Material to Improve on the original design. But having said that , It may not be an inherent design failure , but more an Expectation short fall on our part, thinking that they should last longer with out doing periodic coolant changes.
    From what I understand here in Australia , they are quite hard to find even genuine these days, so its about now ,when someone steps up and starts after market producing, so that well well be my next task next week. (Finding a Heat exchanger Engineering shop) that can make a run of these units..
    Let me know what you think... Marty.
