360 conversion | Page 24 | FerrariChat
360 conversion
Discussion in '360/430' started by RANDY6005, May 19, 2018.
  1. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  2. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    That is what I call a work of art .
    360trev and pilotoCS like this.
  3. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Rear Ti spring
  4. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    This my third go around on trying to restore the stock fasteners for the suspension , spent hours with wire brush then tumbling them and the zinc plating just never look wright . Finely using 80 grit glass beads in my Harbor Freight blasting cabinet cost around 100.00. Took less than one hour now WOW !! Now they are ready for zinc re plating . Leaning curb I guess wend done with the suspension maybe good as a pro IMO. I love Harbor Freight !! good enough stuff for a novice
  5. Mikael-F360
    Mikael-F360 Formula Junior
    Apr 3, 2017
    754
    Finland
    Mikael E.
    Might be the most epic rebuild ever. Down to nuts and bolts. You have built a machine- and surface coating shops around your car! Wow! Thats perfectionism to the max or a bad case of OCD. Maybe both in a good way :)
    360trev and RANDY6005 like this.
  6. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Thanks ! Mikael-F430 I need to go and see shrink :)
    Mikael-F360 and 360trev like this.
  7. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Before I removing bushings and ball joints bead blasted with 80 grit glass beads, I can not believe how long it takes to do just one control arm one hour or more...
    360trev likes this.
  8. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  9. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  10. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,883
    Memphis, TN
  11. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    One of the best complements yet IMHO !
  12. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    1. 3:08 PM
    2. Image Unavailable, Please Login
      360trev liked your post in the thread 360 conversion.
      2:41 PM
    3. Image Unavailable, Please Login
      2:41 PM
    4. Image Unavailable, Please Login
      2:41 PM
    5. Image Unavailable, Please Login
      2:41 PM
    6. Image Unavailable, Please Login
      2:41 PM
    7. Image Unavailable, Please Login
      2:41 PM
    8. Image Unavailable, Please Login
      2:41 PM
    9. Image Unavailable, Please Login
      2:40 PM
    10. Image Unavailable, Please Login
      2:40 PM
    11. Image Unavailable, Please Login
  13. Mikael-F360
    Apr 3, 2017
    754
    Finland
    Mikael E.
    Very likeable thread =)
    MCASEY and RANDY6005 like this.
  14. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Big snow ball !! All I wanted to do was detail all suspensions and changes to Ti springs. One thing led to another from tie rods ends then flamblocks ball joints boot covers drop links shocks bushings upper and lower . And all this needed to be replaced rusted ball joints lose tie rods rubber boots falling apart . I am almost positive that none of this stuff shows up with a PPI inspection report either. 360 mileage only 21050 miles not allot of miles IMHO
    Sent back Superformance flamblocks lower one had wrong size hole for stud bolts below are finale purchase parts
    Factory Challenge flamblocks uses stainless roller bearings not rubber inserts uppers and lowers 16 total 2600.00
    CS Ti springs front and rear 1132.00 x 4 total 4528.00
    Upgraded ball joints from Hill engineering uppers and lowers plus ball joint glue and glue gun total 1070.00
    Four new drop links front and rear 4 240.00 Rear tie rods ends Hill engineering stainless two 992.00
    Front tie rods ends Hill engineering stainless two 404.00
    Front and rear torsion bar rubber 91.34
    Rear lower wishbone bolts 8 51.36
    Upper front and rear shock absorber bushings 4 total 278.00
    Lower front and rear shock absorber bushings 4 total 103.08
    Replacing nuts to high quality yellow nyloc nuts 60 total 105.00
    Just cost of parts no shipping cost or any taxes total of 10231.78 no labor cost 10462.76
    Hopefully I am saving a good bit of money in labor doing it my self I think a dealer would charge 3000.00 to 5000.00 or more
    10462.76 divided by four cost per corner 2615.69
  15. EastMemphis
    May 25, 2019
    1,883
    Memphis, TN
    You're creating a work of art!
    RANDY6005 likes this.
  16. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    And hours of shopping for lowest prices and researching on every part to be the best upgrade as possible
    EastMemphis likes this.
  17. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    SuperFormance refunded 991.00 for 4 lower flamblocks 4 upper flamblocks the lower flamblocks where defected wrong size hole should 10mm but they 8mm
    I emailed Neil at Eurospares ordering Challenge oem flamblocks with bearing rather than rubber inserts cost 2968.00 plus shipping BUT ! luckily he was back up on orders and did not reply.
    I can not believe at the deal I made !! Four Challenge upper control arms they are brand new with Challenge flamblocks and ball joints and boots covers and one Challenge oem RH lower control arm flamblocks and ball joints They are ready to bolt wright up ! shipped 1125.00 !! OMG lucky !
    The company had them listed as 360 430 control arms not Challenge I know this because of older post from Flea7 had posted picks of his Challenge ones.
    Now I have five new control ready too install only 134.00 more :):):):)
    Just ordered LH rear lower control arm from Neil 411.00 and two front lower 867.00 . Getting refund from Superformance 8 HE stainless steal ball joints and for ball joint glue 1200.00
    brogenville likes this.
  18. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
