360 conversion | Page 21 | FerrariChat
360 conversion
Discussion in '360/430' started by RANDY6005, May 19, 2018.
  1. jcurry
    21,582
    In the past
    Jim
    fyi, the basic formulation of Simple Green can be corrosive to aluminum. Simple Green Extreme was created to correct that issue.
  2. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    Hey Jcurry thanks yes you are wright and it is approved aviation use witch say some thing about it as well .
  3. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
  4. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    Rear brake line bracket what a pain in the butt to remove !! The hex head screw that holds the ABS wire connection in place kept turning would not come lose.. And the brake line connection would not budge at all . I just had to stop and take off from it for a couple days . Best thing to do wend you get frustrated if you don not you tear up stuff . After time off and tried again it finely broke lose damn it !! For me to stop and take a brake is very hard to do I hate it.
    G. Pepper and Mel Spillman like this.
  5. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    Just weight CS titanium spring and the standard 360 steel spring 4.80 verses 2.70 deference 2.10 x 4 = 8.40 pounds all four spring, Have not weight the rear springs yet . I believe the rear springs are going to weight more so maybe even more weight saved switching to titanium
    G. Pepper likes this.
  6. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
  7. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    All I had to do was pull apart clean and repaint and a new boot cover from Superformance 49.00 dollars looks like new again. Better than spending 684.00 for new one !
    G. Pepper and DARIES like this.
  8. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    rear bumper inter brackets
    one4torque and DARIES like this.
  9. one4torque
    one4torque F1 Veteran
    5,123
    Houston
    One4torque
    Randy— fighting entropy like a BOSS!
    G. Pepper, kes7u and RANDY6005 like this.
  10. Mel Spillman
    Mel Spillman Formula Junior
    639
    Sugar Land, Tx
    Randy: What did you use on the bumper brackets? The look GREAT!
  11. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    I first used Rustoleum rust remover to remove any rust and clean 3M scotch bright pad. Used etching epoxy primer and then used Eastwood three step golden cadmium paint.
    Mel Spillman likes this.
  12. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    That is the whole RH rear suspension parts and fastens , I am thinking about buying a parts tumbler to clean all the fasteners and small parts. The Ti spring just in from Italy Thursday should be here Monday hopefully start putting all back together soon .
    MCASEY likes this.
  13. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    OMG !! I have been studying how to set the ride height adjustments to CS specs this is going to be a nightmare a pain in the but and a slow process . You can not adjust the shocks springs with a spanner wrench, with the on wheels or rotors or calipers on . I am just guessing here you half to pulling off the rotors and wheels every time just check your height adjustment ? I know I can just leave the calipers off I putting new brake lines on anyway . The CS manual say to put sandbags 75 kg in drivers seat and passengers seat, In pounds 165.00 each, 15 kg is 33 pounds on LH rear RH mudguards .50 Liter of fuel 13 Gallons Damn it man !! ANY BETTER WAY ??
  14. G. Pepper
    G. Pepper Three Time F1 World Champ
    34,046
    Texas/Colorado
    George Pepper
    Bachelors know there is no such thing as entropy. Nothing is ever lost. Crap accumulates. :)
    EastMemphis and one4torque like this.
  15. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
  16. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    These new CS Ti springs give me that same feeling wend you buy a new President Rolex in that wooded Rolex box .And then you get that funny feeling in your stomach :D
  17. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    #524 RANDY6005, Jan 28, 2020
    They even have the brass tags placed around the springs with the part numbers etched in the brass very cool IMHO :cool:
  18. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    #525 RANDY6005, Jan 28, 2020
    crap !! windThrity again Damn it I forgot !! No posting on here wend it is that time !! Now it is to late to delete now !
