360 conversion | Page 20 | FerrariChat
360 conversion
Discussion in '360/430' started by RANDY6005, May 19, 2018.
  1. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    I bet you did not know the front and rear hubs are the same ? the pics above front and rear.. I am going to have the front hubs that has a mounting points for the emergence brakes machine off .. Count the coils on the standard 360 springs and then count the coils on the CS TI springs... Stock springs has 8 coils and the CS springs has 5 coils... I weight the the CS and springs and Modena springs today CS 2.50 and Modena 4.50 pounds. Good stuff love doing this build
  2. veilstylez
    veilstylez Formula Junior
    760
    SoCal
    When you say cleared over....does that mean clear bra over or factory clear coat over?
  3. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    Before the sprayed the clear coat they installed the stripes and then cleared over them
    pilotoCS likes this.
  4. veilstylez
    760
    SoCal
    ohhhhhh wow ok thank you!
    I need to call Dave your interior guy soon to have my interior redone.
  5. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    Okay pm and I will give you his info
    veilstylez likes this.
  6. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    Installing the next installing Ti springs and all new flamblocks and tie rods and bushings
  7. clean512
    clean512 Formula 3
    2,029
    Josh @jtcarprojects
    Perfection. Love everything about the build.
    RANDY6005 likes this.
  8. one4torque
    one4torque F1 Veteran
    5,123
    Houston
    One4torque
    This is not a cs copy. It is something better.
    RANDY6005 and G. Pepper like this.
  9. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    One4torgue that is the best complement I have had yet Thanks !!
  10. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    I spent almost the whole day cleaning up the control arms upper and lowers just on the left rear suspension using wire wheels and sanding blocks and Rustoleum rust remover . Pulling the old brake lines and replacing new oem ones and pulled all the mounting brackets and had them cadmium plated like new again.
  11. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    Next off too the machine shop press out old ball joints and flamblocs and install new ones.
  12. one4torque
    5,123
    Houston
    One4torque
    Just imagine the retail cost to have this done—- at f car labor rates! $100m in labor.
    G. Pepper and EastMemphis like this.
  13. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    And you pay a shop 100 plus hour and they most likely will not do it as good and take short cuts, remember the faster the shop does the work the more money they make.
  14. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    This is my kind of Christmas day !!
  15. 24000rpm
    24000rpm F1 Rookie
    superformance flamblocs' outer metal part will rust in no time. Not to say that bothers me a lot
  16. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    The pics online are black ? we are the ones I got are not ?
  17. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
  18. duck.co.za
    duck.co.za Formula Junior
    Jan 9, 2007
    983
    Cape Town South Afri
    Dave
    Did you order the " high quality " for a CS ? Supposedly stiffer than the std Modena ones .
  19. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
  20. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,650
    England
    Mark
    The Scuderia/CS ones were always shown as black. It would be worth the confirmation.
    I've always been too nervous to order these because it would be so easy for s non-OEM to sell the same part for both cars.
