360 conversion | Page 19 | FerrariChat
360 conversion
Discussion in '360/430' started by RANDY6005, May 19, 2018.
  1. one4torque
    one4torque F1 Veteran
    5,710
    Houston
    One4torque
    Nice... I'm doing the same thing (albiet not to that degree of cleanly-ness!) on my 360 as well.
    Started off with a simple brake job.... then one thing leads to another, and she's getting all cleaned up.
    RANDY6005 likes this.
  2. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    The more stuff I pull more corrections and rusted bolts and screws I find never would thought it was that dirty .
  3. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Most of the corrosion and rust was from the standard 360 cast iron brakes . Now with the carbon ceramic brakes it will stay cleaner longer eliminate most of this stuff
  4. one4torque
    5,710
    Houston
    One4torque
    oh so fine!
    rolling art should not stop with ceramic paint coating........ the mech bits should look top notch..... represents a well maintained auto!
  5. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  6. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    just in case some one would like to swoop out to stainless bolts you can not use stainless bolts on critical loaded stuff like suspension , steering stuff . The minimum grade blots for automotive use is grade 5 . The Ferrari bolts are rated number 8 . I am pretty sure no would want to do that but just in case they did I thought they should know. Stainless bolts are graded number 3
  7. one4torque
    5,710
    Houston
    One4torque
    I use "borrow" my wife's christmas ornament tupper ware covers for drip tays whilst cleaning the ferrari....... she does not know, but I'm certain she would support this method ;)
  8. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    I am pulling all the suspensions parts control arms upper and lower, replacing flamblocs dust covers ball joints and the replacing the standard 360 stock springs too CS titanium springs .
  9. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    I used a very high grade primer and then used 3M paintable undercoating and then painted black, should be allot easier to keep clean and look like new again
    G. Pepper likes this.
  10. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  11. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  12. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  13. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    tifosi101, E60 M5, one4torque and 2 others like this.
  14. one4torque
    5,710
    Houston
    One4torque
    Lambo holds ALOT of oil? :) Great idea. I shall borrow this idea for my next service.
  15. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Wend I pulled the 360 standard side skits off they where full of gravel and dirt, there is just over one inch gap that is wright in front of the rear tire that allows dirt and gravel inside the side skirt . I had some extra gravel guard gasket cut it to fit so it will block off gavel and dirt
  16. veilstylez
    veilstylez Formula 3
    1,011
    SoCal
  17. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    From what I have heard all the CS striped cars are decals and cleared over, and if the are not cleared over they are after market stripes. you can buy a factory striped decal still Eurospares has them in stock 262.40
  18. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  19. veilstylez
    1,011
    SoCal
    ohhhhh interesting! Thanks!
