360 conversion | Page 16 | FerrariChat
360 conversion
Discussion in '360/430' started by RANDY6005, May 19, 2018.
  1. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Hey 02360Spider the standard 360 head pipe is black and CS is blue I am waiting on the proper claps to install the CS head pipe I will check to see how they are different. I think they are the same though maybe a little lighter .
  2. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Factory Challenge Racing exhaust found new in the box, with no cats and test pipe the engine bay never really gets any hotter than a normal car. I never even think about it any more. I use to have to leave my garage door open and blow fan on the engine bay to cool it down huge difference in temp now .
  3. 24000rpm
    24000rpm F1 Rookie
    question: do you find more crackle and burps when lifting throttle or downshift(with no throttle) than an factory setup?
  4. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Hey 24000rpm not as much as it used to, sense MaseEngineer did the CS mapping tune here how it sounds now just skip the first few minutes of this video let my me what you think ??
    sparetireless, 24000rpm and Apollo 11 like this.
  5. Easy888
    Easy888 Formula Junior
    Sep 28, 2006
    517
    CA, NV
    Jim
    I'm assuming the CS anti roll bar is different from that of the standard 360? Does any aftermarket companies make one for the 360 or can the CS version fit on a standard 360? Interested as I plan to get more aggressive suspension setup on my standard 360.
  6. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  7. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,007
    Cape Town South Afri
    Dave
    Great video , thanks
  8. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Is this the only 360 in the USA that has these lexan door glass windows ??
  9. 24000rpm
    24000rpm F1 Rookie
    one of the bad thing being live in china is that you can only view youtube on certain days, if u are lucky. Google had a very bad relationship with china so that banned it!!! I use bing.com here.
    so im giong to see the utube later
    BUT, its weird, u might want to ask mase engineering if they shorten the delay of fuel cutoff after throttle off, since any restriction u remove from the exhaust u'll get noticeable crackle.
  10. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    In the end does it drive like a real cs? Would a cs owner be fooled?
  11. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Not trying to fool any one LOL , the biggest difference between the CS and standard 360 is the weight. This 360 conversion build weights less than a CS by over a hundred pounds
    Tarek307 likes this.
  12. DCooper72
    DCooper72 Rookie
    Feb 15, 2019
    28
    Don Cooper
    What was the gain for the 430 TBs? You also had to change airbox lids? What else is involved in that mod?
  13. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Remapping the ECU,s new CS TCU mass air flow sensors using a factory Challenge race carbon fiber air in take tube, deleted smog pump cats evap system CS anti roll bar, shocks springs upgraded the ecu for the shocks and CS air box lids and many more things . I am waiting for cooler weather before it goes to Mase and swooping out the TBs to 430
    360trev and tifosi101 like this.
  14. veilstylez
    veilstylez Formula 3
    1,051
    SoCal
    I think I honestly viewed this tread over and over 10x now. I love this project.
    You have inspired me to build one which I will start soon but this one is crazy...not sure I can hang to this extreme. I will get in contact with you if thats ok...
    Thank you for all your support and info for this build.
    Awesome build!!!!!!
    360trev and RANDY6005 like this.
  15. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  16. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Update on my 360 conversion taking it to Ferran Automotive in Jacksonville FL, the owner of the shop is Mike Ferran . He has been a mechanic for over 40 years and currently owns himself a CS and 430 Scud and a ford GT40 so he knows these cars inside and out . He going to install CS anti roll bar flush and change all fluids, replacing ac compresses and new ac belt replacing all the pinch clamps. Installing the new CS blue vent pipe. Changing out the F1 filter and pull the factory Challenge oem race exhaust witch has singe tips and modify to duel tips. I am very picky about my 360 and I trust him totally, very fair on the price and you get what you pay for. I would very much like to get your opinion 1 should I remove the F1 rain light 2 remove the rear tow hook 3 convert to duel tips ?? Looking forward to your opinion thanks
  17. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    I want to share one more thing it is about replacing the ac compressor I spent allot of time trying to get the best value rebuild or new one, from a my research rebuilds do not last very long and the factory oem ones cost to much over rebuilding I all most went rebuild but I found the same one the factory use made by Delphi found one at AW Italian in New Jersey they are asking 1298.00 I always ask for a discount so they sold me one 1000.00 shipped Fedx https://www.awitalian.com/AC-Compressor--180041_p_5153.html hope this helps some one out one day
    360trev likes this.
  18. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    Hey Randy,
    You still one of the best conversions ever done... just been doing some mega things on my car pm me for more info. You wont believe how much power I'm now pulling... Redline @ 9,250rpm with power right up to the limiter! ;)
    tifosi101 and RANDY6005 like this.
  19. Neil A
    Neil A Karting
    Oct 11, 2011
    54
    Edinburgh, UK
    Stunning car Randy
    I would leave the rear rain light , and go twin pipe but loose the rear tow hook.
    Maybe go slightly larger than stock on the tailpipe similar to the Capristo system
    RANDY6005 likes this.
  20. Tarek307
    Tarek307 Formula 3
    1,349
    Long Beach, CA & Alexandria,Egypt.
    Tarek Salah
    Looks amazing!
  21. 02360spider
    02360spider Formula 3
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    Do tell
    Sent from my SM-N975U using Tapatalk
  22. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    WOW Thanks Neil A just what I was thinking Sir
