360 AC Fuse Blowing? | FerrariChat
Discussion in 'Technical Q&A' started by pbonaguro, Aug 5, 2018.
  1. pbonaguro
    pbonaguro Rookie
    Sep 30, 2010
    16
    Tried to search around the forums and couldn't find any advice directly related. My 1999 360 Modena AC has been working fine all summer and just stopped working today. The 7.5A fuse behind the driver seat was blown and when replaced just blows again. The only thing I might still be able to do on my own is replace the AC relay which is also behind the driver seat. Any other thoughts?
  2. hessank
    hessank Formula 3
    1,746
    Canada, Florida
    Fred
    How's the compressor?
    Is it seizing and pulling too much juice?
    While keeping the fuse removed I would pay close attention while putting 12v directly to the compressor ONLY to establish if the clutch is frozen or sticking.
    But that's me. I cannot advise you to do that.
  3. pbonaguro
    pbonaguro Rookie
    Sep 30, 2010
    16
    Thanks for the reply.. every little bit helps. You bring up a good point that if the compressor is frozen for some reason, might draw more juice. I'm a decent mechanic working on my own cars, race cars, etc., but gonna tip toe into this one. I'm looking for a quick fix.. wishful thinking I know. Have ordered a new relay which is a cheap attempt at something simple.
  4. ferrarioldman
    ferrarioldman Formula 3
    Jun 19, 2002
    1,029
    Summerfield, NC
    Tom Jones
    I have had several of the compressor clutch coils go bad. Common problem. Joe at Polar Bear a/c in Florida can fix you up. www.polarbearinc.com/
    Zcobra1 likes this.
  5. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,319
    maurice T
    If the compressor is seized it won’t draw more amps as it is belt driven and not electrically driven,,
    if the clutch coil has shorted out to ground,then that will blow a fuse..
    When you replaced the fuse,did the fuse blow whilst the car was running or did it blow with the key turned,dash lights on but engine not running?
  6. pbonaguro
    pbonaguro Rookie
    Sep 30, 2010
    16
    Thank you all for the info. I also received a diagnosis tip/reply to my email from Aldous Voice. Fuse doesn't blow with the car running and the AC stop button pressed in/engaged. As soon as you turn off the Stop button the fuse blows. So it would seem the problem is definitely at the compressor end. So I'm just going to remove compressor and have it rebuilt. Thanks again for your responses
  7. pbonaguro
    pbonaguro Rookie
    Sep 30, 2010
    16
    Did a little more work/test this evening. Without the car running and with a remote 12 volt battery, I tested the AC clutch and it worked.
    Then instead of the 7.5amp fuse, I put in a 15 amp fuse for about 15 seconds and the compressor engaged, ran and didn't blow a fuse.
    So any definitive thoughts on why the compressor is drawing more than 7.5amp standard fuse size will be appreciated. I'm assuming the answer is that I need a new clutch?
    Thank you.
  8. Zcobra1
    Zcobra1 Formula 3
    Oct 9, 2012
    1,247
    So Cal
    Bert
    As posted above....if you do a rebuild, Polar Bear Inc., in FL. has a deal going on completely rebuilt one for $390, they also have the dryer and another part you need for about $90, so all in for $480 plus your core and shipping costs. They sometimes have a couple on hand so exchange is quick. I have NOT used them, but have heard good things about them.
    Handy if no local rebuilders around....
  9. Ballvice
    Ballvice Karting
    Oct 19, 2019
    121
    Georgia
    Frank Ball
    what did this turn out to be in the end? I am having the same issue - but - my 15A fuse blows too -
