355 Speedline Challenge wheels, strange offset? | FerrariChat
Discussion in '348/355' started by Robbe, Nov 26, 2015.
  1. Robbe
    Robbe Formula Junior
    Aug 22, 2013
    611
    The Netherlands
    #1 Robbe, Nov 26, 2015
    Hi all,
    I just purchased this nice set of Challenge wheels, 865 and 864.
    According to what I found on info over here, the offset on Challenge wheels should be 60 and 80.
    But these have a different offset, they are 50 and 69 or thereabouts.
    (measured as follows: total width is 27.2 cm, half is 13.6. Backspace between hub-touching surface and outer rim is 20.5. So offset is 13.6 - 20.5 = 6.9 cm = 69 offset)
    Someone in an old posting pointed out that these offsets are for 348's, but my wheels have a date of 95 cast into it. And according to the seller, which still has another set, they came from a 355 Challenge racing team.
    Anybody know the story behind these wheels/offsets? And do the backs fit with 295 tires, or should I go for 285?? (front is no problem)
  2. F355Bob
    F355Bob Formula 3
    I've had 295 on my Challenge wheels no problem. I have 285 on them now.
  3. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,570
    SoCal LA/OC/New Mexico
    Tim Dee
    I never measured mine I will
  4. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Those wheels will not work on your car. They are junk. Fortunately for you, I am a scrap metal dealer, so I will take them off your hands for a few bucks. ;) ;) ;)
    Sleestak and Qavion like this.
  5. Robbe
    Aug 22, 2013
    611
    The Netherlands
    #5 Robbe, Nov 26, 2015
    The offset on the front poses no problems to the wheelarch by the way, the extra 0.5 inch in width is fully compensated by the offset. I managed to measure that with the wheel on the car, the outer rim is exactly as far apart from the brake rotor as the stock wheel.
    On the back there is an offset difference of 15 mm compared to stock 10J rear wheels.
    I do not mind if I would need 275's or 285's, as long as the end result would fit the car.
    But as the engine is still out, I can't measure anything on the back at the moment.
    Other question, why are my rears supossed to be 10J wide, bu when measured 10.7 inch? Or do I need to measure inside the outer lips?
  6. Robbe
    Aug 22, 2013
    611
    The Netherlands
    Maybe you can help the Original seller as well, he still has a set for sale. I tried a package deal for 2 sets, but I am glad I didn't
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    Thanks for pointing that out. Forgot that they were made for both and the offsets would be different.
    That explains why Tim and Bob were so much faster than me on the track.
  8. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,395
    Richmond
    Pete
    Challenge ran 295's on the rear and they fit fine, that's what I currently have on my challenge rims (r6's).
  9. Robbe
    Aug 22, 2013
    611
    The Netherlands
    But 295's with an offset of 80 , compared with my offset of 69 or 70 , would mean that the tire would be 1 cm nearer to the wheelarch....
    Does anybody positively runs these 70 offsets with 295's?
    Thanks.
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    I as told stock offset is 68 on the 355 but i have since seen 80 as well. I have nver measured but who knows.
  11. tazandjan
    38,082
    Front offset (ET) for the 8J X 18 Challenge wheels is 49 mm and I think the rears are the same as stock F355 wheels, 10J X 18 and 77.9 mm. Anybody who has a similar image for the rear wheels, please post.
  12. F355Bob
    F355Bob Formula 3
    Are you measuring the wheel width all the way to the outer lip which makes a 10 inch rim really 11 inches or inside the flange which is 10 inches? I notice offsets are all over the place so I wonder if people are measuring the rim width in different ways.
  13. Jasonberkeley
    Jasonberkeley Formula 3
    Apr 23, 2017
    1,321
    NW Corner, CT
    Jason Berkeley
    Thats a great document with all the wheel sizes and offsets. Thanks for sharing!
  14. tazandjan
    38,082
    Bob- I am not measuring anything. I am reading the ET cast into the wheel by the manufacturer and the ET marked on the box of a new wheel from photos. Measuring will just give you errors. Photos courtesy of Chris at Exoticar. All the offsets in the document I posted are the manufacturer's data.
  15. F355Bob
    F355Bob Formula 3
    I think your offset is correct. I,have challenge wheels also. But some guys with aftermarket 1i inch rears that look good in the wheel well say their.offsets are 60. Some with 10 rear say their offset is 52. How can that be?
  16. m.stojanovic
    m.stojanovic F1 Rookie
    2,759
    Malaysia - KL
    Miroljub Stojanovic
    That makes sense. In the case of the 11 in. wheels, the offset is increased so that they do not protrude too much out.
  17. F355Bob
    F355Bob Formula 3
    I think on an 11 inch rim, the total width is really 12 inch from outside flange to outside flange. If you measure from inside the flange which is 11 inches, the two different measurements will be off 1/2 inch or about 12mm. I think that is why some of these offsets seem to be so different for the same wheels. Does that make sense?
  18. tazandjan
    38,082
    When Ferrari went to wider wheels on later street models, mostly with 114.3 X 5 bolt patterns, the offsets usually were adjusted for the wheel width. Inch wider wheels had the offset adjusted by around 12.7 mm to keep the wheel at a constant distance inside the wheel-well (half the width on each side). An example of this are the similar 10J X 20 wheels on the 612 rear, vs the 11J X 20 on the 599 rear (ET 51.1 vs ET 63.8). Explains why the 599 wheels fit the 612 perfectly, too. On the racing wheels, however, the offsets were sometimes not changed to give a slight increase in track. An example of this are the 360 Challenge (8J X 18 ET 31.5) and Scuderia/16M front wheels (8J X 19 ET 31.5), which have the same offset as the narrower stock wheels (7.5J X 18/19 ET 31.5), resulting in a track increase of 1/4" on each side (1/2" total). Good for cutting down on understeer. Without knowing what the manufacturer was trying to do, and not understanding exactly how the manufacturer measures offset (yes, we all know how offset is calculated), the only way to get good offset information is to get it from the manufacturer.
  19. ShineKen
    ShineKen F1 World Champ
    16,663
    Southern California
    Nostradamus
    This document list stock 355 OE wheels as 18 x 7.5 + 32mm offset and Challenge wheels as 18 x 8.0+ 49mm offset. This would imply the stock wheels sit roughly 10-11mm out more aggressive than the challenge wheels. I get the feeling the listed offset on the 355 OE wheel is wrong. Can someone confirm?
  20. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    1,949
    NE FL
    Ken
    Stock rears are a crazy 79mm. That why a lot of us run spacers so we dont look like a old Winnebago RV
    A set of challenge wheels with 59mm offset would be awesome! The would fit perfect with the fenders
  21. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,570
    Tim Dee
    When you run the slicks they are up against the lips of the fenders. Slicks are big :)
  22. ShineKen
    16,663
    Southern California
    Nostradamus
    #23 ShineKen, Apr 25, 2021
    F355 OE wheels are actually 18 x 7.5 +46 (not +32). Which means these are roughly 3mm less aggressive than 355 Challenge Speedline wheels. Someone should edit the doc :).
    OE and Challenge Speedlines have identical sizes and offsets for the rears. 18x10 +78
  23. tazandjan
    38,082
    Like this? That post is several years old.
    348
    Five Spoke 17” Early, 5 X 108 mm
    Front 7.5J X 17 ET 49 mm, Rear 9J X 17 ET 68 mm
    Five Spoke 17” Late, 5 X 108 mm
    Front 7.5J X 17 ET 49 mm, Rear 9J X 17 ET 43.05 mm
    355
    Five Spoke 18”, 5 X 108 mm
    Front 7.5J X 18 ET 46.15 mm, Rear 10J X 18 ET 77.9 mm
    355 Challenge
    Front 8J X 18 ET 49 mm, Rear 10J X 18 ET 77.9 mm
    ShineKen likes this.
  24. ShineKen
    16,663
    Southern California
    Nostradamus
    Post might be several years old, but it appears to be the most recent on the subject when I searched. It is good to have the numbers updated for clarification as I was about to order new wheels based off incorrect numbers :).
