Looking for a picture of the top of the engine with plenums off and can clearly see the heat exchanger. I took mine apart and want to double check the power steering hose routing. It has some extra hose on outside for rubbing so just want to ensure I have it back together correctly thanks.
Thank you. I see how high yours comes by the oil filter I thought mine stayed underneath but maybe not. Seemed bloody obvious when I took it t out 2 days ago. An other pictures thanks guys appreciate it.
Looks like the extra guarding is for when it comes from Underneath and hits your scuderia rampante piece by the water pump.
This was actually wrong It stays a under everything, heat exchanger and wires Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Yes Mitchell Was going to reach out once I timed it. Head is on as per your instructions Thank you very much Been doing lots of reading on cam timing Need to make some kind of piece to go on crank to fit wheel Working on that this week
Get one of these 7 inch wheel, make the hole bigger to fit the 36mm bolt, put it on the crank sandwiched between two large washers. Image Unavailable, Please Login
