355 Fuel Pressure Regulator | Page 2 | FerrariChat
Discussion in '348/355' started by SethP, Jul 4, 2017.
  1. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Still waiting for the brotherhood to find me a fuel rail adapter that fits to our stock rails and has an -6an or -4an fitting
    We also need an adapter for our fuel lines that goes to 3/8 npt so it can screw directly into the fuel pressure regulator
  2. m.stojanovic
    m.stojanovic F1 Rookie
    3,212
    Serbia - Niš
    Miroljub Stojanovic
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Do you have a pic of it as ours has an print that pushes into the rail and a metric reverse taper coming out.
    I believe it’s 12mmx1.5 but a reverse taper that a male jic or something similar would couple with.
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    This is what it looks like the nipple with the orang goes into the fuel rail
    The male oem fuel lines taper fits on the threaded portion and a outside cooler pulls them together
  5. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    The rail adapters I find have only 1/8 inch return fitting and the hole for fuel is likely too small for a proper bypass back to tank.
    I think we need at least -2an or even -3an or 1/4 inch npt
    The first diagram fits but the nipple is slightly small but would likely fit with a larger oring
  6. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    I'm damned if I remember. I believe there is an acura adapter that fits. I had a couple laying around and cant find them in my AN fitting box. May have put them on my 348 TB setup
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Does your 348 use 355 fuel rails because I did not think they were the same
  8. m.stojanovic
    3,212
    Serbia - Niš
    Miroljub Stojanovic
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Hi Miro
    Yes I have a few I can change as well on a lathe but I was looking for 1 I did not have to
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Mine is 10.89mm on nipple end before oring and 13.37 below oring and 14.4 on oring once installed.
  11. m.stojanovic
    3,212
    Serbia - Niš
    Miroljub Stojanovic
    Yes that's about right for Bosch FPRs. I suggest you go ahead with the mod of the 5/8 nipple adapters that you have as it seems that nobody is making adapters for Bosch FPR rail sockets, except VAC motorsport but their adapter is for early style Bosch FPRs (https://store.vacmotorsports.com/vac-performance-fuel-pressure-regulator-adaptor-early-style-bosch-p1765.aspx).
  12. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    The problem I see with mine Miro is I do not like the small 1/8 inch out feed because it could be too small for the flow
    As you can see the hole is quite a bit larger in the oem and because it’s steel the thin wall where the oring sits is likely fine
    But on this aluminum one I feel if I machine it down the wall thickness would likely be too thin
  13. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    I am starting to think it would be easier just to cut out the adapter from the stock fpr and weld a -an3 on it
  14. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    I just took a picture of the outlet side duh
    Looks like the outlet side is a lot smaller on the factory piece so maybe I can modify
    Without restricting too much
  15. m.stojanovic
    3,212
    Serbia - Niš
    Miroljub Stojanovic
    A smaller orifice will not really impede the overall flow, the fuel will just flow faster through it. No big deal if the length of the reduced diameter is short, very small friction losses. A flow through a longer stretch with a reduced diameter would cause impediment. As it is just the return flow, you should have no problem like higher fuel pressure at idle.
  16. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    No I have a 355 TB setup ready for a 348 :)
  17. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Gotcha
    So I machined the oring groove and maybe it will fit
    I will let the brotherhood know
  18. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Question for the brotherhood
    I far prefer the factory jic style fuel fittings but it seems that most of the aftermarket fuel pressure regulators side towards using npt instead.
    I do not trust npt verses jic as much.
    What does everyone else think?
  19. 308 GTB
    308 GTB F1 World Champ
    11,713
    New Jersey
    Barry Wolinsky
    Aeromotive 13101 EFI Regulator, A1000 Injected Bypass - Adjustable and JEGS fuel, pressure gauge.
  20. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    You ever check your actual AFR on each bank of the motor with a wide band? I get a little variance side to side I adjust with fuel pressure
  21. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    I cant remember but I believe an Acura one fits, I had a couple but damned if I can remember
  22. 308 GTB
    11,713
    New Jersey
    Barry Wolinsky
    Tim,
    I was able to do that with my old set-up (posts 14 and 15). But those Aeromotive FPRs were old and rather than replacing them, I upgraded to a single heavy-duty regulator and was able to use some of the existing plumbing and a single fuel pressure gauge. My car runs better with this new set-up. Testing was done last year at Daytona, Watkins Glen and Lime Rock Park.
    When my car gets back from Florida in April, we'll tune and dyno the car again. The last time that was done was in 2013. Since then, in addition to this new set-up, I've installed Tubi exhaust manifolds and have had the fuel injectors serviced.
    Barry
    SoCal1 likes this.
  23. 308 GTB
    11,713
    New Jersey
    Barry Wolinsky
    Right, Grant. New fuel lines were installed years ago when the two Aeromotive FPRs replaced the OEM Factory regulators. When we changed to the single heavy-duty regulator, those new fuel lines were used to replumb my set-up.
    Barry
  24. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Thanks Barry
    I really wanted to stay with factory but may have to make a custom fitting.
    Was hoping someone would have a source for an off the shelf adapter
  25. PaulK
    PaulK F1 Rookie
    4,780
    Michigan
    Paul
    Hi Everyone,
    Has anyone had any experience with SPA and their fuel pressure regulator? They say its a drop in replacement.
    https://spaturbousa.com/products/ferrari-355-456-550-512-in-rail-adjustable-fuel-pressure-regulator-e85-safe?_pos=1&_sid=d86253f86&_ss=r
    fits to Ferrari 355 456 550 & 512
    direct replaces OEM regulators in the factory EFI systems
    floating ball seal
    adjustable 10 to 65 psi range
    1:1 boost reference.
    E85, 100% Ethanol and methanol safe.
    can be used as OEM replacement
    replace the following OE PN:
    0280 160 564
    Beetle and Qavion like this.
