355 f1 pump bleeding | FerrariChat
Discussion in '348/355' started by sjuliani, May 28, 2017.
  1. sjuliani
    sjuliani Rookie
    Apr 10, 2013
    26
    #1 sjuliani, May 28, 2017
    I had to manually disengage the clutch into neutral using the method mentioned in the workshop manual(see photo).
    Does anyone know if i have to bleed the system after this procedure? The manual doesnt mention anything about doing so, all i did was use the specialty pump to release the gear into neutral.
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Great post as you are the first I know that did this.
    When you disconnected the coupling did you lose a lot of fluid? I've not had and confirmation if that fitting has a check valve on each side.
    If it does not, and fluid poured out, yes - you will need to bleed.
    Where did you get the pump? Please post pictures.
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    No fluid came out of mine when I did this so i think it does or if it does not still not fluid came out much nd you the sytem likely had bled down because it was a few hours between running and the disconnect.
  4. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    The easiest way to bleed the F1 system is to open the bleeding valves, connect tubing for flow back to reservoir, open the door or turn on the engine. The F1 pump will become activated (if the electric motor is functional), and because hydraulic fluid pressure will not rise due to open bleeding valves, it will keep pumping fluid and getting rid of air bubbles. Make sure you have enough additional hydraulic fluid to prevent the system from "sucking in" air from the reservoir.
    GregLong likes this.
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I personally would not flow from the bleed screws back into the system. I would just have fresh fluid filling the reservoir.
    Like bleeding brakes - you would never pour the fluid bled back into the reservoir.
  6. WATSON
    21,720
    WI
    Juri, where is the bleed screw for the 355 F1 system?
  7. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    It is on the same block #2 shown in the diagram (Fig.15; D25), just opposite of the fast disconnect junction #1.
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    The WSM states to use the same bleed screw as manual cars (left side of pumpkin). I believe the actual pump body as a bleeder too.
    Only posting observations as I've not bled an F1 system before.
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    Sorry i was drunk when i posted this.
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    Yes Dave there is a bleed screw on pump body.
  11. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Lol!!! I was going to call you today and ask if that was a drunk post (no lie) :)
  12. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    Ya kinda hot here like 25 so beer tasting really good.
    I am not really sure what i was trying to say.
  13. sjuliani
    sjuliani Rookie
    Apr 10, 2013
    26
    #13 sjuliani, Jun 2, 2017
    Yes it did but from the line coming from the f1 pump.
    i found the bleeding procedure in the manual, it asks for the sd1 but i doubt thats needed. Im going to try this ill get back to you.
    I've located the bleed screw its under the bottom of the car, to the left of the gearbox. see photo
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Well, that unfortunately means the nipple (item 1) is not check valved - I did not think it was, but was hoping.
    My John Deere tractor had hydraulic quick disconnects and they had check valves so only a couple drops of fluid lost each time...
    Yep - that's what I posted above via the WSM :)
  15. sjuliani
    sjuliani Rookie
    Apr 10, 2013
    26
    thanks man ill keep you guys updated, im planning to get this done hopefully this sunday
  16. sjuliani
    sjuliani Rookie
    Apr 10, 2013
    26
    Update!
    Had been out with work the past few weeks but managed to get back on working on the car today.
    So hooked everything up, after starting the car the pump kicked in and i was able to engage the gears. Turned off the car and then back to position "II" and now i can engage all gears.
    The problem im having now is that i can only engage the 1st or reverse by first applying brake then holding the "UP" paddle OR R lever and then getting on the accelerator while continuously holding the "UP" paddle/ R Lever. Letting off the accelerator OR the paddle/Lever automatically pops the gear right back to neutral. I would then have to repeat the above procedure again. Same thing with reverse. The f1 light on the cluster is NOT on.
    Is there something im missing?
  17. Shane
    Shane Rookie
    Dec 5, 2018
    14
    Canada
    Shane
    Have you found out what was the problem did you end up solving the issue?
  18. WATSON
    21,720
    WI
    sjuliani has not logged in here since Feb of 2018..... so.....
  19. Shane
    Shane Rookie
    Dec 5, 2018
    14
    Canada
    Shane
    :D fair enough, he probably end up taking it to a dealership then.
    But also was wondering, there no way around the SD1 then when it comes to F1 bleeding Watson?
    I tried the same thing as above but it also made it worst than building up more pressure :(
  20. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    You should confirm what you are bleeding.
    This quick coupler is for the clutch only not the f1 system unless you lost so much fluid it got back to the main housing with all the solenoids.
    Yes I have bled the clutch without an sd Or Leonardo.
    WATSON likes this.
  21. Shane
    Shane Rookie
    Dec 5, 2018
    14
    Canada
    Shane
    Yeah that's true, i just found out the seals in the f1 throw-out bearing is leaking and the air might be coming into the system from there.
    If i do go replace the seals is it better if it just disconnect the quick coupler before hand? replace everything and then reconnect and bleed?
  22. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    That’s what I would do but never done that so someone else might have a better reason not to.
    Shane likes this.
  23. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    How did you ascertain the leaky slave cylinder?
    This is one of the more tedious jobs on the 355.
    Shane likes this.
  24. Shane
    Shane Rookie
    Dec 5, 2018
    14
    Canada
    Shane
    Yeah i spotted a slow leak in the back of the car near the clutch housing area sadly, small drips of some sort of red fluid on the ground
    so i double checked the colour of my gear oil and F1 fluid turns out it was the F1 fluid :(
    Its going to be a tough job replacing the seals you think?
  25. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    Like all things 355 skill and experience helps a lot. Can be difficult to get seals on without damage to them
    Shane likes this.
