355 coolant tank cap | FerrariChat
Discussion in '348/355' started by Carmellini, Feb 10, 2021.
  1. Carmellini
    Carmellini Formula Junior
    Jul 16, 2019
    814
    My cap looks fine, and when I unscrew I feel pressure. Seems fine? However, I keep seeing blue coolant residue on the visible threads. Wipe it off clean, and few days later, its back. If the cap was cracked there wouldn't be any pressure build up? Not loosing coolant and temps are good.
    Are these plastic caps consumables? Perhaps there is something pressure related inside the cap. The hose looks good and I don't believe its leaking at that point.
  2. Qavion
    Qavion F1 World Champ
    11,484
    Ian Riddell
    flash32 likes this.
  3. Carmellini
    Jul 16, 2019
    814
    I see 145030 is for modern Ferrari like Portofino and 329417 is for 355. Is this a supersession or upgrade?
  4. Qavion
    11,484
    Ian Riddell
    One type fits all (almost)
    Less than 20 left in May 2020... You may be too late.
  5. Carmellini
    Jul 16, 2019
    814
    just sent a PM
    assuming this solved your problem?
  6. Qavion
    11,484
    Ian Riddell
    yup :)
  7. Qavion
    11,484
    Ian Riddell
    Unfortunately, we discovered that Joel has run out of tank caps. I guess the usual stockists and usual prices apply. :(
  8. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,625
    CT
    John Kreskovsky
    If you are not loosing coolant it's not a problem.
  9. Carmellini
    Jul 16, 2019
    814
    Sorry to have missed out on Joel's caps; great deal.....
    Anyone have any idea if the 145030 cap is better than the original number 329417. Same 1.0 bar,
    and same threads, but 030 cap is $20 more?
  10. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,814
    Tinton Falls, NJ
    Bob Ferraris
    Brian Crall used to talk about caps being a regularly replaced item.
  11. johnk...
    Jun 11, 2004
    10,625
    CT
    John Kreskovsky
    There is a simple reason coolant can collect in the treads of the tank.
