348 Speedo Problem | FerrariChat
348 Speedo Problem
Discussion in '348/355' started by tonyguy, Feb 10, 2021.
  1. tonyguy
    tonyguy Rookie
    Jan 24, 2021
    25
    London
    Tony Pemberton
    My speedo has become intermittently working. Now it goes up & down in speed. Is this some kind of connection/relay type of issue you think? Is a fairly simple fix that my local mechanic can do, or shall I take it to a specialist?
  2. Ricambi America
    Sponsor Owner
    11 out of every 10 times, it's the speedo sender which is jammed into the drivers sider of the gearbox. Part 116987
    On the 13th time, its the speedo head itself. :)
    jdlegg, Steve Magnusson and Qavion like this.
  3. Qavion
    Qavion F1 World Champ
    11,547
    Ian Riddell
  4. Ricambi America
    Sponsor Owner
    Depends on whether or not you have arms smaller than Baby Yoda.
    Qavion likes this.
  5. Qavion
    11,547
    Ian Riddell
    If it's like the F355, there are a few ways to skin a cat...
    Go from underneath the car or ..
    Remove the left rear wheel and wheelwell liner
    Create a special socket to go over the sensor and harness (if the sensor is too tight for an open end spanner).
    Summary here:
    https://www.dropbox.com/sh/kufk5c92mfqd50n/To1XNeSKVT/Ferrari DIY?preview=F355+Speed+Sensor+Replacement.pdf
    Test the sensor using various methods and replace as required. Repair it if you have the skills.
    http://www.dinoplex.org/instruments/vegliaspeedosensor/
    Your car will probably have a Type II sensor
  6. AceMaster
    Feb 6, 2009
    34,560
    Ontario, Canada
  7. tonyguy
    tonyguy Rookie
    Jan 24, 2021
    25
    London
    Tony Pemberton
    Thanks, great step by step thread there
    AceMaster likes this.
  8. AceMaster
    Feb 6, 2009
    34,560
    Ontario, Canada
    That's what the 348 brotherhood is all about
  9. John_K_348
    John_K_348 F1 Rookie
    Sep 20, 2013
    2,747
    Boston, MA
    John E. Kenney
    I made a heat shield jacket for my new one years back. Just some header tape and aluminum insulation tape. When you see where it sits so close to the exhaust you will see it makes sense. Just wrap it around and tape it. Cheap insurance, replace if it comes loose. Works great for Exhaust ecus too. I made a set for my 360. Fold up and bolt in underneath.
    Qavion likes this.
