[348] Show us your belts and bearings! | Page 3 | FerrariChat
Discussion in '348/355' started by Wade, May 31, 2016.
  1. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Either the compressor seized or the clutch windings shorted and overheated the belt, causing it to snap. Easy enough to determine by trying to rotate the compressor shaft. That said, even if the compressor spins I'd be tempted to have it gone through while it's off the car.
    If the compressor did seize you need to determine if it threw shrapnel, because in that case the system will require more flushing than usual.
    But something tells me Wade already knows all of the above. :)
    Sorry it happened, Wade. Best of luck getting it all sorted. Let us know how you proceed. I've been jealous of your chilly AC system for a while now so I'll be interested to hear how you go about resurrecting it.
  2. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Yes Pap, easy fix on the 348. The location of the compressor makes it more so.
    Mike, you know what happens when tuning for performance over endurance... ;)
    So, the usual repair as with any other; replace the compressor, expansion valve and filter/dryer along with a full flush.
    All's well again and the A/C is back to its frigid self.
  3. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Do you know what the root cause was, Wade? I'm guessing compressor failure from what you wrote, but just curious...
  4. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Not really sure right now. The compressor shaft rotates without binding/grinding although it doesn't spin freely. And that's without caps or anything covering the hose connections/ports.
    The tech said that he had a lot of difficulty with removing the clutch assembly, especially the pulley (which incurred slightly bent edges as a result).
  5. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Thanks for the response, Wade. I've seen the windings in those clutches short out before, so it's entirely possible that's what happened here. That's the absolute best case scenario since it doesn't leave shrapnel in the system. I'd pay the clutch $2k to fail instead of the compressor, and I do my own work so it’s all just labor to me. The point being that it’s an everlovin’ bear to get those crunchy bits out of your AC system…
    What refrigerant did you use this time around? Is it as cool as the previous system?
  6. PAP 348
    PAP 348 Nine Time F1 World Champ
    Dec 10, 2005
    99,341
    Mount Isa, Australia
    Pap
    If the compressor turns, then that is ok. The pulley bearing must have seized Wade.
    The a/c compressor will never spin freely like a bearing as it's a pump so it will always be 'firm' to turn by hand.
    They are even tighter to turn when they are brand new.
  7. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Before it was a mix of Freeze12 (was in the car when I bought it) and R-134a. I serviced it down to 36° for a bit but backed it off to the mid 40s and ran it that way for about a year.
    Now it's fully serviced with R-134a and still around 40° while idling in the garage (measured with a laser temp sensor).
    Great info, thanks Pap. I'll just keep the old compressor in the box for now.
  8. PAP 348
    Dec 10, 2005
    99,341
    Pap
    No worries mate, keep it in the shed. :)
  9. boxcarracer
    boxcarracer Formula Junior
    Jul 29, 2005
    333
    Montreal
    Luigi
  10. Nader
    Nader Formula Junior
    Feb 12, 2011
    990
    East of Seattle
    Slightly OT; Which muffler is that, and how do you like it?
  11. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Very helpful and descriptive pics, Luigi. Thanks for sharing.
    How many miles are on the old tensioner pads?
  12. PAP 348
    Dec 10, 2005
    99,341
    Pap
    Great pic man, did you perform the major yourself?
  13. boxcarracer
    Jul 29, 2005
    333
    Montreal
    Luigi
    Nouvalari Sport w/cat bypass. Don't know about the sound, haven't started it up yet lol
    I do not know for certain, as I don't have records of the tsb being performed, but I believe they have 40-50'000km (25-31'000mi) max.
    Thanks Pap. I wish I had a garage big enough to carry out this work, would have made a good father/son project with my dad. All I did was read fchat and provide the parts to my trusty tech lol
  14. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Thanks for the additional info, Luigi. So are you saying that total mileage in the engine was 50k km?
  15. boxcarracer
    Jul 29, 2005
    333
    Montreal
    Luigi
    Hi Mike,
    The car got its last major at ~60'000km w/o the oil pads on the invoice. I'm assuming the oil pump tsb was performed some time after the car rolled off the lot, that's why I'm assuming the pads have around 50'000km
  16. PAP 348
    Dec 10, 2005
    99,341
    Pap
    Too easy mate, thanks for sharing. :)
  17. AceMaster
    Feb 6, 2009
    34,555
    Ontario, Canada
    I can add to this thread, let me dig up my old parts.
    Mine was 9 years and the belts just barely started to show wear. I don't drive it hard and it was about 10,000 miles.
    I didn't deliberately wait 9 nine years, I wanted to do it at about 4-5 years (but that's a story on its own as to why)
  18. Skippr1999
    Skippr1999 F1 Rookie
    4,216
    Thanks for sharing. Does the 355 have these oil tensioner pads ?
  19. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    Yes,
  20. Skippr1999
    4,216
    Thanks Mitchell. Where are they located ?
  21. Ricambi America
    Sponsor Owner
    #71 Ricambi America, Apr 7, 2018
  22. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
    Two years later from my above post, and here is an up date. I have just swapped my 12 year old Hills engineering thrust bearing and carrier, for another Hills unit.
    So this is what a 12 year old (25k miles) HE unit looks like in terms of wear and tear next to a new HE unit. Only the bearing its self has worn in terms of hight.
    R
