348 repaint | FerrariChat
348 repaint
Discussion in '348/355' started by rivee, Nov 27, 2016.
  1. rivee
    rivee F1 Rookie
    Jan 20, 2002
    3,731
    Nowhere important, USA
    I'm thinking of repainting my 91 348ts.
    It's the original Single stage Rossa corsa.
    The problem with the paint is the single stage paint doesn't have
    Enough thickness to it to endure the numerous polishing and waxing
    Jobs throughout the years so the white sealer is starting to show through at different locations
    So what do I repaint with? 2 stage with a poly clear or with a ceramic clearcoat or something else?
    I want as durable a finish as I can get.
  2. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,597
    Maryland
    David
    Interested on replys as mine has a couple of low spots as well.
    Mobilized reply by Dahveedem
  3. Fast mustang
    Fast mustang Karting
    Nov 15, 2014
    173
    Island lake Il
    Ron
    Single stage paint is up to you if you want to go back the original a two stage base coat clear coat finish is going to give you a lifetime of shine durability .
  4. dailyferraridriver
    dailyferraridriver Formula 3
    Nov 12, 2010
    1,402
    New Jersey
    Erik
    I'm currently undergoing a full bare metal paint job on my 348. I'll find out how it's being done.
    Erik
  5. phrogs
    phrogs F1 Veteran
    7,130
    Michigan
    If you're in california you will be using waterborne base coat/clear coat.
  6. vjlax18
    vjlax18 Formula Junior
    680
    Nottingham, MD
    My car was repainted with base/clear. The paint is one of the reason I bought my particular car. :)
  7. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,570
    SoCal LA/OC/New Mexico
    Tim Dee
    I would use a base clearcoat system, they are easier to repair and hold up very well
    Glassuret or Sikkens makes a top notch paint along with it's pre coats, primer sealer etc
    Not 100% true. We can still use and have available lacquer paint. For production shops yes waterborne yes however they are extremely durable and give lifetime warranty on paint.
    We used dupont then sikkens at my shop before I retired. Absolutely great products still today
  8. phrogs
    phrogs F1 Veteran
    7,130
    Michigan
    I have no doubt you can get lacquer.
  9. dailyferraridriver
    Nov 12, 2010
    1,402
    New Jersey
    Erik
    Mine is being done using the following:
    "Glasurit base coat/clear coat"
    Thanks,
    Erik
  10. Chupacabra
    Chupacabra F1 Rookie
    3,233
    Behind a drum kit
    Mr. Chupacabra
    I'm looking at having mine done, too as it's SS parts are two stage while the original parts are single stage. I'm thinking single stage overall just for originality, but likely capping it off with one of the ceramic paint protection compounds out there. Basically, same net effect I suppose. Maybe it's a dumb idea, but I don't know much about paint :)
  11. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    My Maserati GT front clip was painted with Waterborne (and my understanding is that was Maserati does from the factory) - it's terrible paint - chips way too easy...
  12. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,570
    Tim Dee
    Ahh thats what we can in the industry "the great compromise" OEM paint
  13. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,614
    Australia
    Mark R
    Do the front clip in base coat then clear. Much earlier to maintain longer term for wear and tear on a bonnet (hood).
