Image Unavailable, Please Login You have to remove all the adapters off the old one and transfer to the new one.
Image Unavailable, Please Login On the passengers side I couldn’t get to the fuel filter without disconnecting this pipe.
Image Unavailable, Please Login Going to send out my injectors and MAFs for a service. There is a little clip which holds the injector to the rail. It just pulls out.
Image Unavailable, Please Login With the clip out, a little tug and the injector comes out of the rail.
Image Unavailable, Please Login Cam phase sensor next. You can see here the bolts being undone. (What does this sensor do ? And why is there only one of them ?)
Image Unavailable, Please Login The electrical wire connector is bolted to the side of the block. So there is another bolt to undo to get it off.
Image Unavailable, Please Login There is also a magnetic shield inside that you have to replace (why ? Does the old one go bad ?). It’s held in with a couple of screws. You can just see in the pic the end of the screw driver.
