348 - 348 Parts Thread | Page 23 | FerrariChat
348 348 Parts Thread
Discussion in '348/355' started by plugzit, Mar 1, 2005.
  1. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    348 speedometer sensor (pulse sensor)
    Ferrari: 116987
    Alfa Romeo: 60575205
    Maserati: 393650106
    Veglia Borletti: 680517
    jferrante and AceMaster like this.
  3. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    If you dont mind a little rewiring job the 355 one can be used and is quite a bit cheaper
    https://www.ferrariparts.co.uk/part/ferrari/
    And cheaper again at eurospares.
    https://www.eurospares.co.uk/search?partNumber=149095
    Its just the plug on the end is a supaseal type and you can either change the plug on the sensor or as I did buy a matching plug for the car loom end.
    AceMaster, ernie and Qavion like this.
  4. AceMaster
    Feb 6, 2009
    34,776
    Ontario, Canada
    Excellent job Ernie. I am in the middle of diagnosing my 348 with an intermittent dead speedometer. Will keep everyone posted once I have it figured out.
    ernie likes this.
  5. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
    These are selling in the $30-$40 dollar range at Algar Ferrari and Ricambi now.
    https://www.ricambiamerica.com/car-diagrams/ferrari/v6-v8/mondial-group/mondial-t/air-injection-device-for-cars-with-catalyst-motronic-2-5.html
  6. Polygaryd
    Polygaryd Karting
    May 8, 2020
    81
    Arizona United States of America
    Paco Ramirez
    This sd7h15 7840 is now $389 plus shipping from polar bear inc and the sd709 7505 is non existent
    A much cheaper but identical compressor (except the pulley and connector) is the sanden sd7h15 4710 from techchoiceparts.com for $159.80 plus shipping.
    The pulley is an 8 rib pulley but the length of the compressor is the same as the 7840 or 7505 meaning the belt rides on the outer most 5 ribs and the 3 ribs closest to the compressor are empty. I'll attach the pdfs to show how this compressor fits and works exactly the same they just put a deeper pulley on the shaft but its recessed.
    • 7505.pdf
      File size:
      1,008.8 KB
      12
    • 4710.pdf
      File size:
      109.4 KB
      7
    Qavion likes this.
  7. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    One could spin off the pulley with an impact wrench, put the old pulley on, tighten it back up with an impact as well.
    Sent using FerrariChat.com mobile app
  8. Polygaryd
    Polygaryd Karting
    May 8, 2020
    81
    Paco Ramirez
    According to Rick at acparts.Com the owner and automotive ac guru for 30 years says the shaft sizes are different and you cant do that. I already asked.
  9. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Good reference thanks!
  10. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  11. Polygaryd
    Polygaryd Karting
    May 8, 2020
    81
    Paco Ramirez
    That's the exact one I was referring to in my original post the sanden sd7h15 7840 for $389
    $230 more for oem size pulley that makes no difference in how the car operates is not what I'd do but to each their own.
  12. Louis Brown
    Louis Brown Karting
    Dec 24, 2019
    83
    Richardson Texas
    Louis Brown
    Fuel Pressure Regulator for 1989 Mondial with 3.0bar unit and barbed fitting to fuel pump. (Bosch 0 280 160 731- Ferrari #137960)
    I can source the later 3.8bar unit (with threaded fitting) from NAPA only. Thanks
  13. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Lots of places, not just Napa. Rock Auto for another online retailer.
  14. Louis Brown
    Louis Brown Karting
    Dec 24, 2019
    83
    Richardson Texas
    Louis Brown
    RockAuto no luck.
  15. Louis Brown
    Louis Brown Karting
    Dec 24, 2019
    83
    Richardson Texas
    Louis Brown
    Thanks Eric! Only issue with that part is it requires threaded pressure-fitted hoses unlike my earlier fpr with barbed fitting. Do you know what hoses I’d need to make that work?
  16. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I'm confused. Tell me exactly what you want. lets start there.
    1) I want the 3.0 bar with the barb fitting used prior to 93 typically TS ad TB models (there were actual 2 different ones over time)
    2) I want the 3.8 bar with the threaded fitting used after 93 typically on the Spider
  17. Louis Brown
    Louis Brown Karting
    Dec 24, 2019
    83
    Richardson Texas
    Louis Brown
    Numero #1 .... for the Mondial TTTTTTTTT!
  18. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Qavion likes this.
  19. m.stojanovic
    m.stojanovic F1 Rookie
    3,211
    Serbia - Niš
    Miroljub Stojanovic
  20. Louis Brown
    Louis Brown Karting
    Dec 24, 2019
    83
    Richardson Texas
    Louis Brown
    Thanks for both of the options. I’ll just need to upgrade to the threaded fittings found on the fuel pump inlet.
  21. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Not following, why, but good luck regardless.
  22. Louis Brown
    Louis Brown Karting
    Dec 24, 2019
    83
    Richardson Texas
    Louis Brown
    Because my FPR is barbed not threaded like the replacement unit. Thus I would need to purchase a threaded female pressure fit hose. My hose is rubber only requiring a clamp.,
  23. m.stojanovic
    3,211
    Serbia - Niš
    Miroljub Stojanovic
    If your original FPR has a barb (hose push-on), then your replacement threaded FPR is incorrect for your engine. As clearly pointed by Eric, barbed is 3.0 Bar, threaded is 3.8 Bar. You cannot use 3.8 Bar (threaded) FPR-s in your car.
