348 - 348 Parts Thread | Page 22 | FerrariChat
348 348 Parts Thread
Discussion in '348/355' started by plugzit, Mar 1, 2005.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
  2. aec
    aec Karting
    Jul 28, 2011
    138
    Weston, MA
    The cut-off valve made by Pierburg in Germany (Ferrari part #147390) appears to be exactly the same as the Saab part #4228011 used for the Saab 900 and Saab 9000. The Saab part appears to be readily available online for around $70 (new). Has anyone used this Saab part?
  3. aec
    aec Karting
    Jul 28, 2011
    138
    Weston, MA
    #528 aec, Mar 7, 2016
  4. vjlax18
    vjlax18 Formula Junior
    687
    Nottingham, MD
  5. PAP 348
    Dec 10, 2005
    100,215
    Mount Isa, Australia
    Pap
    Awesome!! That looks to be indentical! And cheap too. :)
    Just double check there is the diode under that insulation for the power wire.
    You can see it under the heat shrink on your old one, double check the new one has it in place.
    When I replaced my a/c compressor last year it never had the diode in place, so we soldered one in.
    Thanks for sharing, much appreciated.
  6. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    It looks like Bosch 0280160738 has been discontinued. Anyone know if Bosch makes another model that's a 3.8 bar? Standard makes a PR298 that should work, but I'd rather stick with Bosch if possible.
  7. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    FYI.. confirmed the Bosch part 0280160738 has been discontinued.
    PR298 is the 3.8 bar option available - for now.
  8. OldBill
    OldBill Rookie
    Nov 18, 2016
    1
    London
    Bill Hanley
  9. albagtp
    albagtp Karting
    57
    Beach City
    Bryan
    Since I originally posted this information I felt it necessary to update it. I purchased a rebuilt pump from them, It was not as advertised. They kept stalling me to make it right but never did for over a year. I returned the pump and to this day have not received a refund and lost a good core pump in the process as well. Unfortunately after doing more research it seems i'm not the only one taken by this guy, he also goes by max071492 on ebay. Beware of this guys unsatisfactory business practices.
  10. AceMaster
    Feb 6, 2009
    34,776
    Ontario, Canada
  11. vjlax18
    687
    Nottingham, MD
  12. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
  13. AceMaster
    Feb 6, 2009
    34,776
    Ontario, Canada
  14. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Air filter, Ferrari part number 155871, is from a fiat Croma. Fram part number CA10049.
  15. FSM348
    FSM348 Formula Junior
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    TB Shaft Seals
    I'm in the process of restoring my 348 and after powdercoating the throttle bodies I realized replacement throttle shaft seals on the TB were necessary. After a crazy amount of searching a little shop which happened to be local to me just so happened to have perfect sized replacements. 8mm x 12mm x 3mm rubber seals. Also they are only a couple bucks each!
    These seals fit both the throttle bodies and the intake manifold butterfly shaft seals.
    Metric Seals
    Westfield, Indiana
    metricsealsinc.com
    part number S 8 x 12 x 3 WOA
    https://www.metricsealsinc.com/single-lip-springless/022044-s-8-x-12-x-3-wao
    SPECS:
    Single Lip Spring Less Oil Seal
    BAOF, VC, WAO, INA, VG
    Specs:
    Radial shaft seal with rubber covered O.D. And sealing lip without spring.
    Material:
    NBR (Natural Rubber), Plain Steel insert.
    Max Temperature: -40°C/-40°F – 100°C/ 212°F
    Max Surface Speed: 6 m/s
    8mm ID x 12mm OD x 3mm
    Application:
    Grease
    Simple sealing element for ancillary use; to seal against grease; as an additional seal against light to medium dust and dirt.
  16. marc556
    marc556 Formula Junior
    590
    Wiltz (Lux)
    Marc Foyen
    Do you know where I can find a PDF or XLS file about all these infos ?
  17. m.stojanovic
    m.stojanovic F1 Rookie
    3,206
    Serbia - Niš
    Miroljub Stojanovic
    Here's one I have.
  18. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Tank you so much
  19. Koenig1
    Koenig1 Formula Junior
    Aug 25, 2016
    328
    Ottawa ON
    Sandy
  20. AceMaster
    Feb 6, 2009
    34,776
    Ontario, Canada
    Here is what I have
    ernie likes this.
  21. User-C3
    User-C3 Karting
    Aug 29, 2018
    239
    Detroit
    Trevor
    ABS brake pump
    The jaguar xj6 uses the same setup and the electric motor, pressure switch, and accumulator are all the same as the Ferrari. The electric motor bolts right up, and even uses the same plug. The only difference between the two units is the accumulator is located on the opposite side of the jaguar pump housing pointing it straight up if used on the Ferrari and not fitting under the closeout panel. Complete units can be had for $200
    seabass23 likes this.
  22. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  23. Cauf61
    Cauf61 Formula Junior
    Jul 12, 2016
    557
    Belgium
    Patrick
  24. User-C3
    User-C3 Karting
    Aug 29, 2018
    239
    Detroit
    Trevor
  25. Clarence Cazimero
    Sep 17, 2019
    25
    New York
    Clarence Cazimero
