348 - 348 Parts Thread | Page 20 | FerrariChat
348 348 Parts Thread
Discussion in '348/355' started by plugzit, Mar 1, 2005.
  1. Ed Niles
    Ed Niles Formula 3
    Honorary
    Sep 7, 2004
    2,493
    West Hills, CA
    Edwin K. Niles
    Brake caliper rebuild kit?
  2. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,357
    South of Philly
    Paul Nicholasen
    ABS computer: search Ebay for "ATE E5LC-2C219-AA". Same unit but from a Lincoln for about 1/1000th the price.
  3. porphy
    porphy Formula 3
    1,203
    LouisvilleKY/Switzld
    Randall Gatz
    Does this unit fit the Mondial T or the late 3.2 Mondial's with ABS?
  4. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    Is there any interchange part for the shockdamper lower and top bushes ? They cost alot in europe. I found some cheaper ones on Superformance.co.uk and ordered them but i didnt got any reply from them since the order and its days ago maybe they are out of business i dont know. Only other source i found is maserati it seems that atleast the top bushes are also used in some maseratis and they charge half the price but if they realy fit i dont know.
  5. juhani
    juhani Karting
    Aug 28, 2012
    71
    Helsinki, Finland
    Juhani
    I found out that many cars share a similar ABS system as the 348. I fixed my brake problems with a Saab 9000 ('93) pressure switch.
    Saab part number for the pressure switch is 8994071 and GM / AC Delco part number 25530882. It can be found on Amazon for around $80. Search google for "Teves mark 2" and you can find a lot of information. This article was very helpful while troubleshooting brake problems: Ford Thunderbird - ABS Anti-Lock Brake System
  6. gaw111
    gaw111 Formula Junior
    Sep 24, 2012
    662
    Rainelle WV
    George Wheeler
    Just cross referenced this on the 355 interchangeable parts sticky; This part is NLA. F7192 (Actually a Victor Reinz part number) has been discontinued. Ferrari # 154984 = Felpro 60155. I have not verified this, however, going to buy 4 tomorrow from Advance Auto and I will update. BTW, the Advance part number is 60155 for $2.59 each, pretty cheap!
  7. gaw111
    Sep 24, 2012
    662
    Rainelle WV
    George Wheeler
    Got all 4 for $11.00!!
  8. dantm
    dantm Formula 3
    Nov 1, 2003
    1,101
    YYZ, BOS, SFO
    Dan B.
    #484 dantm, Nov 9, 2013
    Are these gaskets for the pressure switch where it goes into the three-way block? Mine seems to be leaking (See picture) although this is on a F355...I wonder if I need to get the whole assembly or if I can get by with the gasket?
    Does the brake fluid need to be drained from the system when replacing this?
    Thank you.
  9. gaw111
    Sep 24, 2012
    662
    Rainelle WV
    George Wheeler
    Sorry, no. This is the donut gasket for the exhaust pipes.
  10. mikeportugal
    mikeportugal Rookie
    Nov 21, 2013
    1
    Hello
    This is my first post.
    I am from Portugal and we´d like to have information about possible sourcing for this part, and suppliers.
    If possible in Europe.
    Thank You
  11. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,503
    Jeff
    Does anyone know the part no for a 348TS wiper motor? (it maybe 0390246312 but could do with confirmation).
    If you have some photos of the plug as well that would be great :)
  12. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,503
    Jeff
    #488 348Jeff, Dec 18, 2013
  13. Räserperra
    Räserperra Karting
    Jan 1, 2013
    216
    Ingarö Sweden
    Per Kringberg
    Alla bearings in a Ferrari are SKF. Official supplier since 1948.
  14. Pixel6
    Pixel6 Karting
    Jul 6, 2013
    66
    Denver
    pixel
    Any advice on where I can pick up 2 lower door sections for my 348 so I can remove the strakes? The ones on eBay ATM are in pretty bad shape. Or, anyone know if tubi Japan is still making them?
  15. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    Early 348 rear wheel bearing made by SKF, part number 62209-2RS1.
  16. gaw111
    Sep 24, 2012
    662
    Rainelle WV
    George Wheeler
    Found a near perfect replacement Nipondenso alternator for a 348. As I said before, it is a near perfect replacement. It only puts out 70 Amps but I have been using it for a couple of months and have put 500 miles on it and it keeps my battery charged. I also had to put a small spacer (1/4 in) on the adjustment bracket but the lower bracket lines up perfectly. The bolts comes out of the side but there was plenty of wire to put in place. Here's a link to the post I made about the upper bracket for ref. http://www.ferrarichat.com/forum/142802126-post26.html
    It's a Tough One, sold at Advance Auto, the PN is 14809. It fits a 91 Toyota Corolla. Cost, $78 bucks, I kept my core, so, that added another $35, but still a good price. I was also able to find a 130 Amp alternator for a 91 Corolla on eBay for about the same price. I couldn't find a part number for it though. This is a good option if your alternator was not rebuildable like mine. Toyota Corolla 130Amp High Output Alternator 1988 1991 | eBay
  17. Racing-Baker
    Racing-Baker Karting
    Jan 11, 2008
    216
    Beveren Leie
    Enzo Duquesnoy
    I have a 348 complete (without gearbox)engine who suffered from a broken belt. What i don't have is;
    -heads
    -cams
    -rods
    -liners
    -crank
    If you need something; PM me.
  18. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,597
    Maryland
    David
    SB1010S
    M10 x 1.0
    Brembo Calipers
  19. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    Here is another option for those that can't find the SKF bearing.
    Alternator belt tensioner bearing - Fafnir 9107PP / Timken 9107PP
    The Fanfnir bearing came in the Timken box. Same part number on the box as stamped on the bearing race.
  20. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    #496 ernie, Apr 26, 2014
    Bought a couple of 3.8bar/55.1psi fuel pressure regulators from Napa auto parts. They are made by Echlin and cost me $70 each, and the part number is CRB 219624. When looking them up on Napa, they come up listed for a 1991-1993 Mondial T.
    Here are some other cross reference numbers:
    AIRTEX: 5G1127
    ACDelco: 2173329
    Bosch: 0280160738
    BWD: 22863
    CarQuest: PR298
    Ferrari: 147281
    GP Sorensen: 800410
    Kemparts: 143865
    Niehoff: 22863
    Standard motor Products: PR289
    Wells: PR440
  21. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  22. wildcat767676
    wildcat767676 Formula Junior
    May 20, 2011
    531
    Gilbert, Arizona
    Has anyone created a spreadsheet that summarizes all these great additions in the thread? 😁
  23. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,597
    Maryland
    David
    Hey ernie. ... Those the non barbed type replacement? I know there are 2 versions right?
    Mobilized reply by Dahveedem
  24. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    YES! The 348 has 2 versions for the FPRs. The replacement version I listed (for Bosch part #0280160738) you must have threaded connectors on both ends of the fuel line going to the regulator, and going to the pump. The other type (the one I replaced, Bosch part #0280160715) only has the threaded fitting at the pump, and a fitting on the FPR to slip the fuel line on.
    So before you order MAKE SURE what type fuel lines you have, or may need to get.
