348 - 348 Instrument Cluster Clip | FerrariChat
348 348 Instrument Cluster Clip
Discussion in '348/355' started by Derekevan13, Jan 10, 2021.
  1. Derekevan13
    Derekevan13 Karting
    Jun 9, 2017
    62
  2. GatedF355GTB
    GatedF355GTB Karting
    Dec 5, 2017
    172
    The instrument electrical plugs are truly the most diabolical creation ever. They suck.
    You need to carefully pry the locking tab down while slowly working the plug free. It can a truly miserable experience but try to resist the urge to use a lot of force. It will eventually break free with perseverance.
    One other thing: each of the plugs are different. Some require prying and others require depressing the tab.
  3. Qavion
    Qavion F1 World Champ
    11,534
    Ian Riddell
    Interesting. It seems like the spider has a few extra wires going to the instrument panel. Not sure of the colours, though...
    Left Hand:
    1. pink/yellow?
    2. white/yellow? (unused on non-spider)
    3. grey/yellow
    4. green
    5. unused
    6. green/white
    7. blue/black?
    8. blue?
    9. grey/white
    10. white
    11. black
    12. green/black
    13. orange (unused on non-spider)
    Right Hand:
    1. red (unused on non-spider)
    2. orange
    3. pink/black (yellow/red on non-spider, but joins up to pink/black on other side of the relay panel according to the WSM)
    4. green/white
    5. yellow/black
    6. yellow/green
    7. white (unused on non-spider)
    8. unused
    9. red/green? (green/red on non-spider)
    10. yellow
    11. violet/white
    12. pink (unused on non-spider)
  4. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,502
    Jeff
    If you spray a small amount of contact cleaner (so no harm done) round th egap between where the plug is contact with the socket it will lubricate it a bit and they should come apart a lot more easily :)
  5. Derekevan13
    Derekevan13 Karting
    Jun 9, 2017
    62
    Thank you for the tip. Would you think sticking a small flat head screwdriver to pry the tab down while pulling will do the trick? The 2 larger clips were easy as you just pinch the tab and pull out.
  6. GatedF355GTB
    Dec 5, 2017
    172
    Yea, that's what I used. Just go easy.
    Derekevan13 likes this.
  7. Derekevan13
    Derekevan13 Karting
    Jun 9, 2017
    62
    It worked! Now, any idea how to get the control knob on the front of the Speedo off?
  8. Qavion
    11,534
    Ian Riddell
  9. Derekevan13
    Derekevan13 Karting
    Jun 9, 2017
    62
  10. Qavion
    11,534
    Ian Riddell
    Sorry, I forgot the speedo had one, too.
    It seems like a different part number, so I'm not sure.
  11. WATSON
    21,712
    WI
    Friction fit as well. At least mine was.
    Derekevan13 and Qavion like this.
  12. AceMaster
    Feb 6, 2009
    34,560
    Ontario, Canada
  13. Derekevan13
    Derekevan13 Karting
    Jun 9, 2017
    62
  14. GatedF355GTB
    Dec 5, 2017
    172
    The speedos do sometimes have issues. If you do determine there’s a issue with the gauge and need to have it repaired, I recommend North Hollywood Speedometer. They’re great to work with and know what they’re doing.
  15. Derekevan13
    Derekevan13 Karting
    Jun 9, 2017
    62
    Awesome, thanks for the reco. I’m in the South Bay so will try Paul’s Speedometers in Redondo Beach first. Hoping a bench test tomorrow will identify the problem.
