credit = rivee (thread initiator), Dr_Ferrari, blackcross http://www.ferrarichat.com/forum/348-355-sponsored-bradan/170633-348-door-stop-removal.html
Credit: Nader http://www.ferrarichat.com/forum/348-355-sponsored-bradan/552548-slight-fuel-leak-very-pressurized-tank.html#post145558111
348 steering rack removal Credit: superjet2099 https://www.ferrarichat.com/forum/threads/348-steering-rack-removal.568601/#post-145798093
How do I print the fuel tank removal for my tech to follow while he removes my tank? [email protected]
If your tech doesn't know how to do this and your having to give him instructions I'd suggest your at the wrong garage!!!
Please NO discussions in this thread, because we need to keep it easy for owners to locate DIY information. Thank you.
348 ABS ecu credit: pnicholasen (thread originator), m.stojanovic, bjwhite https://www.ferrarichat.com/forum/threads/348-abs-computer-clarification.572644/
348 starter clicks https://www.ferrarichat.com/forum/threads/348-starter-sometimes-it-just-clicks.305582/#post-145968398
348 heater valve. Credit: ///Mike, thread originator. https://www.ferrarichat.com/forum/threads/hot-wiring-the-348-heater-valve.578459/
348 ignition switch Credit: boxcarracer https://www.ferrarichat.com/forum/threads/ferrari-348-ignition-switch.585995/
348 pressure in fuel tank. Credit: Nader https://www.ferrarichat.com/forum/threads/slight-fuel-leak-very-pressurized-tank.552548/#post-146289581
348 steering rack install Credit: fdekeu https://www.ferrarichat.com/forum/threads/348-steering-rack-install.587795/
348 HVAC recirculation boss. Credit: Flacon Wing https://www.ferrarichat.com/forum/threads/348-recirculation-door-for-the-hvac-is-non-functional.400666/
348 HVAC amp connector re-pin Credit: Davsk1 https://www.ferrarichat.com/forum/threads/348-hvac-amp-connector-re-pinning.588390/
348 HVAC recirculation motor & hidden fuse Credit: Ferrarium https://www.ferrarichat.com/forum/threads/hvac-flap-motor-and-hiden-fuse.590569/
348 window motor Credit: Ferrarium (thread initiator), Jh348, alexion https://www.ferrarichat.com/forum/threads/348-window-motor-serviceable.590600/
348 steering rack rebuild Credit: Ferrarium https://www.ferrarichat.com/forum/threads/started-348-steering-rack-rebuild.591467/#post-146379582
348 timing chain tensioner pad & lower drive pulley bearing Credit: steved033 https://www.ferrarichat.com/forum/threads/348-cam-drive-chain-tensioner.593867/
348 glove box strut alternative fix. Credit: jebones https://www.ferrarichat.com/forum/threads/glove-box-fix.594614/
348 purge valve hoses credit: steved003 https://www.ferrarichat.com/forum/threads/purge-valve-hoses.595670/
348 oil chain tensioner Credit multiple posters in thread: https://www.ferrarichat.com/forum/threads/185577-updated-oil-chain-tensioner.514804/#post-144530590
348 fuel sender repair credit: 348steve https://www.ferrarichat.com/forum/threads/fuel-sender-repair-348-defect-in-my-opinion.596552/
348 climate control Credit: Wade & m.stojanovic https://www.ferrarichat.com/forum/threads/view-inside-the-climate-control-ecu-info-request.596451/
