330GTC Ignition Issue | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by 330BRC, Jul 15, 2018.
  1. 330BRC
    330BRC Karting
    May 4, 2007
    128
    Seattle, Washington
    Brian Conlan
    I parked the 330GTC after a trouble free drive, went back to start it and no ignition power. It cranks but does not fire. The instruments stay dead which indicates no ignition power. I checked the ignition fuse. It is fine. Does anyone know of a possible issue upstream of the ignition fuse that can interrupt power?
    I seem to remember something about ignition power tied in with the clock. The clock is original and works intermittently.
    Any feedback out there would be greatly appreciated.
  2. 330BRC
    330BRC Karting
    May 4, 2007
    128
    Seattle, Washington
    Brian Conlan
    Problem resolved for now. The CEAM ignition relay next to the fuse panel was not closing with power applied. I tapped the ignition relay lightly with a socket extension and it started working.
    Rebuilding/servicing the relay, if possible, is now on the list.
  3. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    1,831
    Brian: Check your fuse panel for a black square Bakelite electrical junction box. It will have four connections with brass screws holding the wires. If you look closely, you will see a "staple" jumping the power between the connectors. Remove the wires and "staple" and clean them. That could very well be your problem.
  4. gburkett
    gburkett Karting
    78
    Austin, Texas
    Glenn Burkett
    I think I have a nos black electrical relay box for your car if you need it. A spare for my old 330GTS. Also. CHeck the bus bar where the wires connect on the firewall. Need a very small slot screw driver to tighten them. I had the same problem years ago and although I thought the relay box had failed, it was a hidden connection on the firewall.
  5. 330BRC
    330BRC Karting
    May 4, 2007
    128
    Seattle, Washington
    Brian Conlan
    Thank you Gents for your feedback and knowledge. Very much appreciated. I have some sorting to do.
    Glenn - I believe I have a spare used relay. I will see if I can make what I have reliable. Thank you for the offer.
  6. Motob
    Motob Formula 3
    Nov 11, 2003
    2,238
    Frederick, Maryland
    Brian Brown
    The CEAM power relay on the fuse board is very simple, easy to work on. The hardest part is getting it on and off of the fuse board. After you get it off, there are two tiny screws on the back of the relay that hold the cover on. Take the cover off and clean the points contact surfaces with very fine sandpaper, I use 1000 or 1500 grit. Make sure that the points touch evenly when the relay closes. There is a red cloth that is wrapped around the coil winding that comes loose with time. I have seen it foul the points. I reglue it to the windings with good contact cement.
