330 GTC - fuel line hose | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by John B, Oct 10, 2014.
  1. John B
    John B Formula 3
    May 27, 2003
    1,564
    NJ
    I'm redoing the front fuel line hoses on my 1967 330 GTC (9303) and decided to go all in and replace the whole lot since I don't really know how old the back sections are and I have been using ethanol spiked gas. I know the two yellow wired lines from the tank to the electric pump, and the electric pump to the mechanical pump are M10, but I have heard conflicting opinions as to the proper size of the yellow wired lines from the Mechanical pump to the glass fuel filter and the filter to the fuel rail for the carbs. Some say M6, some say M8. I'm inclined to go with the larger (M8) unless I hear strongly otherwise. I have heard the M6 is for smaller, 4 cylinder cars like Alfas etc... but Ferrari V-12's use M8.
    What is the experience here?
  2. Dustin Wetmore
    Dustin Wetmore Karting
    Mar 31, 2011
    73
    Neenah, Wisconsin
    Dustin Wetmore
    M6 flex hoses would be used for pressure gauges. I would expect to see an M8 for your application.
  3. Zanny1
    Zanny1 Formula Junior
    987
    Arizona
    They were M8 on my 250GTE, so I cannot image M6 on a 330.
  4. enio45
    enio45 Formula 3
    1,537
    Gilbert, AZ
    Ed
    i assume the M8 is also used on the fuel rail return as well?
  5. Dogdish
    Dogdish Formula Junior
    Dec 27, 2005
    367
    Denver
    #5 Dogdish, Oct 12, 2014
    M10 prior to fuel pumps, "pulling" fuel through.
    M8 after pumps, "pushing" fuel through.
    ……as I recall, but I'm getting old
    Bill
  6. Jumprun
    Jumprun Karting
    Feb 7, 2012
    227
    Southern California
    T. Martinez
    It just so happens that I too am replacing all the original hoses on my late 330 GTC, here is the inventory;
    Gas tanks to electric pump, 10mm
    Electric pump to chassis tube, 10mm
    Fire wall chassis tube to rear of fuel log, 8mm
    Glass filter to front of fuel log, 8mm
    Glass filter to mech. pump, 8mm
    Lower front chassis pipe to mech. pump, 10mm
    I believe I bought 41 inches of 10mm and 45" of 8mm
  7. John B
    John B Formula 3
    May 27, 2003
    1,564
    NJ
    Thanks Guys, that's the info I needed!
  8. jimmyr
    jimmyr Formula Junior
    Oct 10, 2004
    288
    Scottsdale, AZ
    Jim
    Be sure to get new ferrels for the ends as the old ones do not fit the new hoses.
  9. Dustin Wetmore
    Mar 31, 2011
    73
    Neenah, Wisconsin
    Dustin Wetmore
    The issue we face with the "off the shelf" replacement hose is that our modern fuels chemically erode the hose from the inside out. Solutions to this are available however.
  10. JimEakin
    JimEakin Formula Junior
    Jun 13, 2015
    988
    Mountain Living
    Jim
    So the fittings on the end of the hoses are reusable? Where to get new ferrules?
  11. TTR
    TTR F1 Veteran
    5,191
    Riverside, CA
    Timo
    Yes
    Your hose supplier might or should have them.
  12. 19633500GT
    19633500GT F1 World Champ
    11,999
    Blueberry
    Muffin-Tops
    Jim, what hoses/fittings do you need?
  13. JimEakin
    Jun 13, 2015
    988
    Mountain Living
    Jim
    The hose from the fuel filter to the carbs Is leaking at the fuel filter. Yellow wrapped hose, #6 on Eurospares fuel page, p/n 19386.
    What’s the best way to fix this?
  14. 19633500GT
    11,999
    Blueberry
    Muffin-Tops
    are you trying to fix it, or just find and buy a new hose/fitting?
  15. JimEakin
    Jun 13, 2015
    988
    Mountain Living
    Jim
    I’d like to keep the original fittings. I found Newcoproducts has the 8 mm yellow hose. How hard is it to change out the hose? I’m pretty accomplished at DIY. (Eurospares has a new hose for about $200.)
  16. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,920
    romano schwabel
    the fittings you can srew out
  17. christc
    christc Formula Junior
    Mar 3, 2013
    444
    Germany
    But the new hoses are slightly thicker than the old one’s and therefor the old ferules will not fit. You can use the screw fittings you have but have to use new ferules. Would meke sense to have them cad plated to have them looking accordingly.
    19633500GT likes this.
  18. turbo-joe
    Apr 6, 2008
    8,920
    romano schwabel
  19. christc
    Mar 3, 2013
    444
    Germany
    From my knowledge the old thinner hoses are not available any more. The new look the same but are sligthy thicker. They are available from Newco in the US, Autorpoca in Italy or OKP in Germany as well as many others. Prices will make you wince...
  20. TTR
    TTR F1 Veteran
    5,191
    Riverside, CA
    Timo
    Romano (& Jim), the old/original manufactured hose is not compatible with todays gasolines with modern formulation, at least ones available in the U.S.
    The newly reproduced hose is made of materials that can handle chemical composition of modern pump gasolines, but its O.D. is slightly larger and requires the (larger dia.) new ferrules.
    turbo-joe likes this.
