My electric wing mirrors both sides don’t work and are slightly loose. Is this a common problem, is there a simple fix? Thx Sent from my iPhone using FerrariChat.com mobile app
done mine some time ago and put it on below section, easy job but fiddly and if you eye sight close is poor "what have you done to your ferrari today" #2286 post Well I finally had time today to tackle that wing mirror switch, plenty of cursing was coming from the garage A real pain in the ass, but it's working perfectly so all ends well. Had to break down two old padlocks so I could salvage some newer springs and use in my switch. The problem was easy to understand after the PCB was taken off, four out of six of the ball bearings were sitting low and stuck inside the plastic holder (see pic), because some of the springs had become too compressed and damaged so had to use some new ones in the end as they kept getting stuck again and again. A few pics below for reference to others it may help
loose wing mirrors---remove rubber and tighten up bolt with a star washer added behind it, they hold better but if the bracket is broken you can buy new ones from Hills Engineering or Verrel i believe
Thanks for the info guys, I’ll have a go at the fix’s over the weekend. Sent from my iPhone using FerrariChat.com mobile app
Update Some bits were missing and one motor faulty, fixed by my local Ferrari service agent. Sent from my iPhone using FerrariChat.com mobile app
I now have both my wing mirrors all working. Needed 2 new Hills brackets, one motor and a tighten up. Its a RHD UK model 328 GTB,....the left side mirror will not adjust in orientation enough for the driver to see down the line of the car. If you sit in the passenger seat on the left you can set the mirror perfectly. I've now realised that this mirror is for a LHD euro car! Someone has fitted the wrong mirror in the last 34 years. Does anyone have the correct LH UK RHD mirror lying around they would sell me or is there any kind of adaption that can be done? The part number is 61172700 Thanks, Image Unavailable, Please Login Image Unavailable, Please Login
