328 GTS Chassis Squeak | FerrariChat
Discussion in '308/328' started by rocket50, Aug 26, 2020.
  1. rocket50
    rocket50 Formula 3
    1,247
    Nashville
    Rod
    I have recently begun to hear a squeak when accelerating hard and changing gears quickly. Yes, there is a small targa squeak but this one is different. Not being a hands on car guy, but reasonably mechanically inclined, any thoughts on what I need to look at and how to address it. I want to start working on my car but also don't want to screw it up. Thanks.
  2. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    It can be so, so many things. You need to more definitively determine where the noise is coming from. Start with suspension components.
    rocket50 likes this.
  3. pappy.72
    pappy.72 Formula Junior
    Nov 13, 2010
    516
    Elgin, IL
    Dave
    Squeak or whistle? Belt squeal maybe? Can you tell if the noise is coming from front, back, pedal area, etc?
  4. rocket50
    rocket50 Formula 3
    1,247
    Nashville
    Rod
    Squeak coming from the front.
  5. bertrand328
    bertrand328 Formula 3
    Jun 1, 2015
    1,483
    France
    Bertrand
    I had some "noise" when I got my GTS, I greased the two seal between the targa top and the body with glycerine. The noise disappeared
  6. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,109
    Mansfield, TX
    Ron
    Spray your front bushings with Teflon spray and see if you can make it go away. Shock bushings, sway bar bushings and A-arm bushings.
  7. rocket50
    rocket50 Formula 3
    1,247
    Nashville
    Rod
    Thanks for the tips guys. I will give them a try.
  8. Alfer
    Alfer Formula 3
    Sep 4, 2007
    1,346
    NH/the Netherlands
    Menno
    Indeed sounds like front suspension en bushings is the 1st to look at. Please let us know if you found the issue.
  9. JohnnyTS
    JohnnyTS Formula Junior
    Jun 3, 2012
    905
    Pretoria East, RSA
    only squeak with Targa on or without also ?
  10. rocket50
    rocket50 Formula 3
    1,247
    Nashville
    Rod
    Both. There is a small squeak with the targa top on but this is a different squeak coming from the left front of the car between aggressive acceleration and gear shifts.
  11. EP328
    EP328 Formula Junior
    616
    Northern California
    Ed
    I had a broken front bushing in my ‘86 328. Squeaked like an old bed frame!
