308 water temperature gauge gone ? | FerrariChat
Discussion in 'Technical Q&A' started by Martin308GTB, May 10, 2007.
  1. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,216
    Black Forest Germany
    Martin N.
    Hello from Germany,
    some days ago I inquired regarding removal of the water temperature sender on the 308 GTB.
    Now it seems, that this is needless, because I received a new sender yesterday.
    And prior to tearing all apart I set up a test comparing resistance figures of the new and old sender at identical temperatures. Result: resistance old / new sender is identical within the relevant temperature range of 80 - 100 centigrade.
    Then I connected the new sender with the gauge in the car and the ground of the car. Heated it up with the help of hot water and compared the figures on the gauge with the figures of a digital precision thermometer. Result: gauge in the dashboard still shows significantly false - much lower - temperatures.
    I now assume, that I need a new gauge. Or does anyone of you have further suggestions what to check first ?
    What I already tried is trying different terminals on the fuse box for voltage supply of the gauge. Nothing changed.
    Any hints or tips would be highly appreciated. Thank you in advance.
    Best Regards
    Martin
  2. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Dumb question: does the gauge have a calibration feature?
    Ken
  3. Steve Magnusson
    25,124
    (With the ignition key "on") Touch the wire going to the sender directly to ground (like the nearby bare engine) -- if the gauge doesn't go to the max reading, that's a bad sign for the gauge itself.
  4. Martin308GTB
    Jan 22, 2003
    4,216
    Martin N.
    Steve; I forgot to mention, this was the very first think I checked. The gauge goes to maximum immediately if I bypass the sender with the grey cable touching directly the ground.
    The gauge works, but it works incorrect. Difference in the figures is around 15-20 centigrades.
    All other gauges, fuel, oil pressure, oil temp work fine.
    Best Regards
    Martin
  5. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    More than likely it is the gauge, but it is possible that there is a connector in between the gauge and the sender that has high resistance. High reistance means a lower reading. Try grounding directly to the back of the gauge just to be sure before ordering a new one.
    pilotoCS likes this.
  6. Martin308GTB
    Jan 22, 2003
    4,216
    Martin N.
    thanks Brian; I checked this too. When I did the test I first connected the ground wire coming from the sender with the connection in the engine compartment near the airbox. Then I connected the wire directly to the terminal on the back of the gauge. No difference. I also measured the whole resistance of the ground wire from the dashboard to the engine compartment. Barely 1 Ohm.
    Best Regards
    Martin
  7. f355spider
    f355spider F1 World Champ
    17,939
    If the gauge is truly off calibration, I would think you could send it to a specialist to be recalibrated, rather than replace with a new one. There are shops that specialize in this work, they usually have an emphasis in speedometers, but work on all gauges.
    Just let them know of the difference in reading to give them a starting point.
  8. PT 328
    PT 328 F1 Rookie
    3,957
    I replaced my sender but kept my old gauge in an "87 328 after chasing down what might be causing the temp to read too high. Before replacing the gauge I pulled the dash out and cleaned the connectors that attach to the temp gauge. After a thorough cleaning all was well. Try cleaning the connections on the back of the gauge first. It might save you some headaches as well as money.
    Dan
  9. Martin308GTB
    Jan 22, 2003
    4,216
    Martin N.
    Hello all,
    thank you for all your hints. In the meantime I have done all the checks you suggested and I think I need a new gauge. I also removed the gauge completely from the car to eliminate any influences caused by connectors, fuse boxes etc.
    With the gauge removed I repeated the test with the new sender, a digital thermometer and hot water.
    The gauge showed the identical wrong figures like wired to the car.
    So I will order a new one. Recalibration is no option I think, because the fault is not linear. This means, at 60°C it shows the correct figure. At 75°c it's 10°C, and at 95°C it's 20° C off.
    For the archives and if someone of you has similar problems in the future you might need the figures below for reference.
    I have documented the resistance values of the new sender at different temperatures. So one might check, with the help of a IR temperature gun, whether a suspected temperature sender is faulty or not before dismantling anything.
    at room temperature
    20°C ( centigrade ) = 68 °F ------> ~ 2.3 kOhm
    50°C = 122°F ------> 760 Ohm
    60°C = 140°F ------> 550 Ohm
    70°C = 158°F ------> 420 Ohm
    80°C = 176°F ------> 305 Ohm
    90°C = 194°F ------> 215 Ohm
    ~100°C
    ( boiling point was 99.5°C here)= 211°F ------> 150 Ohm
    Best Regards from Germany
    Martin
    flanguasco likes this.
  10. flanguasco
    flanguasco Rookie
    May 25, 2006
    19
    Imperia - Italy
    Franco G. Languasco
    Hi all,
    my car, a 308gtb QV (1984), exhibits exactly the same symptoms described by Martin308GTB and all the test results are identical, including those with the gauge on the bench in my lab.
    I understand that this is a quite old thread but, if Martin is here, I would like to ask him a couple of question:
    - in your last post you wrote that you were going to replace the gauge: did this solve the problem?
    - on the same post you included a table of sender resistance vs temperature: what version of the 308 does it refer to? Do you still remember if the thermistor part number was #104628?
    The last question is very important to me because I am using the table values to test the gauge, i.e. if I simulate the sender with a 215 Ω resistance I should read 90 °C on the dial while, on my gauge, I have to use a 150 Ω to read 90 °C.
    This means that, if the table is the right one for my sender, the gauge is clearly faulty but if not the problem could be the sender.
    Ciao so far and many thanks for any help.
    Franco
  11. raemin
    raemin Formula 3
    Jan 16, 2007
    1,858
    Lyon (FR)
    R. Emin
    What about a gauge capacitance module? It does take an input ohm value and generate a calibrated output value.
    I am using these in order to match generic fuel tank sender to my dashboard gauge. The ohm range of these modules does seem wide enough for temperature and pressure sensors. https://spiyda.com/fuel-gauge-wizard-mk3.html .
    Maybe you could drop them an email?
  12. flanguasco
    flanguasco Rookie
    May 25, 2006
    19
    Imperia - Italy
    Franco G. Languasco
    @raemin
    thank you for the link: it looks interesting and it is worth to be better evaluated.
    Only one concern: where to install it in a 308? Behind the dash there is not enough space and near the sender it will get roasted because the engine heat…
    @TonyL
    The link you provided is really fantastic! Did you inspect the gauge “anatomy” by opening it? In this case what is the best way to proceed? I can’t figure any way other than to cut the chromed bezel.
    The “anatomy” that you described goes in accordance to what I thought just measuring the resistances among the gauge terminals.
    If we name Gn = car ground, Th = sender terminal and Vc = +12V, the results of my gauge are:
    Th to Gn = 170 Ω
    Th to Vc = 110 Ω
    Vc to Gn = 278 Ω
    So I assumed that there is a coil from Vc to Th and another one from Th to Gn: 110 + 170 = about 278 Ω
    Just to be double sure I measured again the impedance among the gauge terminals but using a Vector Impedance Analyzer: the value of resistance and inductance are in agreement with my “theory” and only the sum of the inductance Vc to Th + Th to Vc is smaller than the expected series value but I think that this is due the to mutual influence of the coils positioned at 90 degrees.
    Following this reasoning I thought to compensate the wrong readings (smaller than expected) by connecting a resistance from Th to Gn, at least to have right values around 90 °C (+/- 20 °C).
    If, and I repeat if the Martin table is correct for my sender, at 90 °C the sender resistance should be 215 Ω and I get the right reading with a compensation resistor of 440 Ω.
    This seems to work, but on the bench: on the car… who knows...
    Ciao and sorry for my English but in this language I only have 8 bits resolution :)
    Franco
    Impedance Vc - Th
    Impedance Th - Gn
    Impedance Vc - Gn
  13. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,836
    Norfolk - UK
    Tony
    Franco, you certainly are going into this in a very professional way. I wasnt brave enough to strip the gauge down as i wasnt convinced the gauge was at fault. From the data you have supplied it looks like the culprit is the sender, it was on mine. Getting it to read correctly with a aftermarket sender was frustrating.
    To get the chrome bezel off is a nightmare and i didnt do that since I found this diagram on the net, it seemed to explain how the gauge worked and what the terminals did.
    Installing a fixed resistor to get the temperature to read correctly at 195 was my goal, the problem is that the values are not linear so it varies up the scale. I just got the gauge to read correctly at 195.
    Would be interested in your findings.
    Veglia changed the temp gauges & senders quite a lot through various cars so some may be slightly different but the concept is the same
    Terminals on my car were marked BN, 12v and GN.
    BN was on the left, 12v was on the right and GN was ground.
    Ciao
    Tony
    PS-Your English is just fine:)
  14. flanguasco
    flanguasco Rookie
    May 25, 2006
    19
    Imperia - Italy
    Franco G. Languasco
    Hi Tony,
    first of all many thanks for the gift you gave me: the gauge electric diagram that I searched in vain on the net for many hours!
    Now what to do next?
    First, on the gauge side, I want to better measure, on the bench, the reading non-linearity introduced by the compensation resistor. I already know, that once calibrated for 90 °C, it is acceptable in a small range around this value but I want to record the error in a range of temperatures from 60 to 120 °C: from a very preliminary look I found that the 60 °C reading is a lot to high.
    But all of this “experiments” could be completely useless because they will depend from the Martin table and of course if the problem is in the sender: at least I'll have fun...
    Then, on the sender side, I plan to have at least one fixed point by reading, with an ohmmeter, the sender resistance during the engine warm up: according to the user manual the radiator fans should start at 84 °C and, if I remember correctly, that is what happened before.
    I am also considering to buy a cheap IR thermometer and to read temperature of the block near the sender vs resistance during the warm up: a friend of mine got from Amazon for 32 € one of these chinese “toys” and he says, that once you have found the right emissivity calibration it is rather precise, obviously if you don't expect the performances of a professional one costing more than 300 €.
    Finally, if the most likely culprit is the sender, I will replace it but if it is the gauge I will try to open it because it could just be a cold welding.
    I'll let you know my progresses.
    Ciao, have a nice Sunday and following week.
    Franco
    TonyL likes this.
  15. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,836
    Norfolk - UK
    Tony
    The biggest problem is nobody knows the manufacturers original resistance readings for the gauge and any measurements taken on a 40 year old sender unit could be way out.
    I did map the readings from the Veglia gauge via a small potentiometer but is was rather crude and relied on digital thermomenters, multimeters, IR gun etc.
    The values change so quickly it was difficult to get repetitive accurate results unless you can control the temperature by heating the sender very slowly.
    It takes a brave man to break into the gauge to see whats going on, i would leave that as a last resort. There is a company over here that repairs gauges (speedy Cables) and are excellent but rather slow.
    In the end i settled for getting the gauge to read accurately at 195 F as the temperature below that wasnt of concern, so long as any increase beyond normal operating temperatures was registering properly.
    All of the sender units on sale and even those sold as "Veglia compatible" were way off the mark. The Valeo unit was the most accurate but i had to fit an adaptor to the engine (dino 246) block to convert it.
    Have fun !
    Tony
  16. flanguasco
    flanguasco Rookie
    May 25, 2006
    19
    Imperia - Italy
    Franco G. Languasco
    Hi Tony,
    I have just ordered the IR gun, it “should” arrive tomorrow and then I’ll carry out the measurements of the thermistor resistance during the engine warm up...
    This test should give me an understanding of the sender health.
    If it turns out that the gauge is the culprit I have two chances: yust compensate with a resistor to have the right reading at 90 °C (194°F) or to buy a new one. It should be available at Maranello Classic Parts, in Egham, a lovely place that I visited several times in the past and where I even have a good friend. It is priced 245.95 £ + VAT but now, after Brexit, I don’t know how much I’ll pay for the shipping only…
    For sure, if I go with the second option, I will open the old gauge trying to understand what was the problem !
    Ciao, good evening at to the next.
    Franco
    P.S.
    From your profile I saw that you are located in UK.
    We, me and my zoo (wife and daughter) lived there for three years, in the eighty, while I was working for Unilever Research and we used to return there almost once a year but not the last and you can easily guess why :-(
  17. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,836
    Norfolk - UK
    Tony
    Franco
    I very much doubt Maranello would have that part in stock unfortunately, if it is defective then i can recommend you try Speedy Cables, they can repair most gauges and may even be able to match it with a new sender. My speedo drive broke some years ago and they machined up new parts to restore the old one and only cost £80GBP, a new one was over £390 !!
    https://speedycables.com/
    Keep us posted on your findings with pictures, these posts are invaluable to others in the future who are brave enough. I do remember a post sometime ago where a Fchat member did this successfully. As you say the chrome ring is the difficult part. Speedy do the chrome rings i beleive!
  18. flanguasco
    flanguasco Rookie
    May 25, 2006
    19
    Imperia - Italy
    Franco G. Languasco
  19. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,836
    Norfolk - UK
    Tony
  20. flanguasco
    flanguasco Rookie
    May 25, 2006
    19
    Imperia - Italy
    Franco G. Languasco
    #21 flanguasco, Feb 16, 2021
    Last week I couldn’t carry on the programmed sender tests because I was too much involved babysitting my two granddaughters …
    Yesterday the first test gave me temperature vs resistance values too high, both during the engine warm up and cooling down, so I suspected that it was due to a bad choice of the ground point.
    This was the test setup during this trial:
    Today I repeated the test using a different ground point and…
    the results during the warm up were so bizarre as to be completely useless (jumping measures and in some cases with extremely low values) such as to make me suspect that there was a strong influence from the nearby high voltage cables and other eddy currents.
    For the measures I used an IR chinese toy (that seems accurate within +/- 3°C) and a reliable Tektronix TX1multimeter.
    During the cooling down the results were definitively more stable although all lower than expected, at least compared with the Martin table above and the one that I found at:
    https://www.ferrarichat.com/forum/threads/water-temperature-sensor-curve-chart-for-308-gt4.409456/
    and, in range 75 – 83 °C, the curve seems to flatten too much.
    Using the found resistor values I have simulated, with a trimmer, the sender on the gauge still on the bench: with 446 Ω I read the correct 60 °C, with 250 Ω the gauge shows a little less than 75 °C but with 215 Ω the reading is only a little bit over the 75 °C mark; the sender resistances, to make my gauge happy, should have been 228 Ω for 75 °C and 169 Ω for 83 °C.
    This is the reading with the trimmer set at 215 Ω (I should read 83 °C on the gauge):
    So the question remains: which is the culprit, the gauge or the sender?
    Now the next step is to remove the sender from the engine and to test it with hot water in a pan; removing the sender doesn’t seems to be a painless operation (get rid of the oil filter ?) and, BTW, is it possible to do it without emptying the coolant circuit ?
    Franco
  21. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    2,778
    FWIW: I helped a friend with this issue on his 308. Connected all sorts of electronic temp measuring devices adjacent to sender on manifold, checked with IR temp gage etc etc. After much time spent, problem was with gage.
    I just had a thought: ~~~~~
    Gage responds / sender calibration 'should' be fairly robust ~~~ Why does gage suddenly start reading too high?
    What if return spring holder for galvanometer movement (gage itself) is adjustable and it slipped its position allowing needle swing to be exaggerated?? Not certain of gage construct, but this is a typical component on D'arsenval movements. On "spring for control action", there's typically a little brass spring holder that adjusts the springs fixed position. Could holder have slipped??
    image here:
    https://www.rfcafe.com/references/electrical/NEETS-Modules/NEETS-Module-03-1-11-1-20.htm
    If I run into this again, I'll dive deeper. We just replaced gage this time.
  22. flanguasco
    flanguasco Rookie
    May 25, 2006
    19
    Imperia - Italy
    Franco G. Languasco
    I am with you if a gauge starts reading too high ...
    but mine is reading too low, mainly in the “high” temperature range 75 – 83 °C making me thinking that the sender, when the temperature increase, doesn't decrease its resistance as it should but rather flattens out to a value greater than the right one.
    Now I'll try, as I said, to test the thermistor alone and, at least, I'll have some fun …
    Ciao and thanks.
    Franco
    2dinos likes this.
