308 Turn signal failure | FerrariChat
Discussion in '308/328' started by Alex Rogo, Apr 19, 2012.
  1. Alex Rogo
    Alex Rogo Formula Junior
    Jan 2, 2004
    273
    California
    I've had my '85 308 QV for about three months now, and no problems. Today I took it in for a brake fluid change, and when I picked it up all the turn signals have stopped functioning...no dash indicator, no lights in either direction. Is there something that could have been knocked loose during the service, or is it just coincidence? Would this problem likely result from a bad fuse, a burnt bulb, or something else more serious? Car has 60k miles. Any help or link to sites covering this would be greatly appreciated.
    Cheers
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,282
    South East
    Jimmie
  3. bspellerin
    bspellerin Formula Junior
    352
    Midlothian, Texas
    Brian Pellerin
    Do your Hazard lights work? Every now and then when my blinkers don't not work properly, the usual remedy for me is to actuate my hazard switch on and off a few times as the blinker wiring goes thru there as well.
    miketuason likes this.
  4. ztarum
    ztarum Formula 3
    Mar 30, 2008
    1,302
    South Jersey, USA
    What he said.
  5. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    A Ferrari tradition...carried on from at least the early Boxer days. It is part of my "First drive in the spring" maintenance schedule! : D
  6. md88plt
    md88plt Karting
    201
    usa
    dc
    Also check ground wire secure and claen at bumper ground connection.
  7. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    I do have to periodically wiggle the Hazard switch to bring the turn signals back on line.....it's become comic relief. Before long, I'll open that sucker and go at it with some Stabilant 22. There are many fascinating "stops" within Ferrari circuits
  8. Alex Rogo
    Jan 2, 2004
    273
    California
    Thanks guys. This solved the problem, at least for the short term.
  9. shawxhurst
    shawxhurst Formula Junior
    Nov 6, 2006
    672
    San Diego
    Steve Hawxhurst
    Did you go to a Ferrari-knowledgeable shop or to the corner gas station? Either way, I would take the car back to them. After all, it worked when you brought it in.
    Unfortunately, the light stalks are fragile on these cars - easy to break just getting in and out especially for a bigger guy. Check fuses and relays - do you know if you have a "Birdman" replacement fuse box in there? If it is broken you need to contact Verell at Unobtainium Supply (he has a website and specializes in this sort of problem). Unfortunately at 65K miles things on your car will begin to wear out. Not to worry - I have an 85QV with 104K mostly trouble free miles but I have had to fix some things along the way.
  10. jim rosenthal
    jim rosenthal Karting
    Sep 10, 2006
    114
    21409
    Thanks for posting these. I have the same problem on my '85 GTB; will try turning the hazard lights on and off a few times before getting out the test light and VOM.
