308 QV - Correct Radiator / Surge Tank Cap | Page 2 | FerrariChat
Discussion in '308/328' started by robo330, Feb 6, 2017.
  1. Labman
    Labman F1 Rookie
    3,776
    Long Island, NY
    Steve
    Just replaced my new OEM style (squarish) cap with a Stant 10331 with red lever. I let the car warm up and when it got to temperature, coolant started spewing out of the overflow tube going to bottom of car. Does this mean I have a bad Stant? Scared the heck out of me so I put the OEM style back on. 1983 308 QV.
  2. GordonC
    GordonC F1 Rookie
    4,120
    Calgary, AB, Canada
    Gordon
    That depends on what the fluid level in the tank was when you switched caps. If you topped up the fluid and the level was within an inch or two of the top, then some overflow would be expected.
  3. robo330
    robo330 Formula Junior
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    I believe seeing somewhere on a previous post that the coolant level should be between 45mm and 50mm down from the top of the Filler Neck when the engine is stopped.
  4. Labman
    Labman F1 Rookie
    3,776
    Long Island, NY
    Steve
    This could be. Major was done last year and I think it was filled close to the top. So what causes it to come out with the Stant? Pressure difference?
  5. Rifledriver
    34,003
    Austin TX
    Water expands when hot and is not compressible. The cooling system needs X amount of air for expansion space so it spit out water until that space was achieved.
    Also many times the Italian caps rubber seal will expand not allowing pressure relief. I have tested some that would peg the gauge on my tester, your may have been one of those.
    Put the other cap back on.
  6. Labman
    Labman F1 Rookie
    3,776
    Long Island, NY
    Steve
    Interesting and understood. I most certainly will. Thanks Brian :)
  7. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    IMHO...I switched recently and the 1.1 is the best...for me ;)
    miketuason likes this.
  8. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    16,247
    wisconsin/chicago
    bo
    Anyone know of a generic radiator cap that works/fits?
  9. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,086
    SanFrancisco BayArea
    1983 US 308 GTS QV
    Stant 10230
    Labman likes this.
  10. bpu699
    Dec 9, 2003
    16,247
    wisconsin/chicago
    bo
    #35 bpu699, Jul 5, 2020
    ‘thanks!
    That’s the 1.1 or 16psi one, correct?
    I have a 0.9 right now, is there a part number for that’s psi also?
    Will try the one you suggest...
    Does a higher psi increase risk of water pump seal/failures? This is for a testarossa, if that matters...
  11. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    No.
  12. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,086
    1983 US 308 GTS QV
    Apparently Ferrari issued a Service Bulletin for 308s where they increased the recommended system pressure to 1.1 bar.
    The first owner of my car used 0.9 bar caps for the 30 years he owned it. When I bought it, I decided to increase the pressure with a 1.1 bar cap figuring if a measly 0.2 bar pressure increase blew my hoses, I wanted to know about it. I've been running 1.1 bar ever since.
    I can't comment on TRs; ain't never even got a ride in one.
  13. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    I have been using a 1.1 cap since Sept 1997.
    If they were going to cause a problem, im sure I would seen it by now.
  14. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,534
    Cerritos, CA.
    Although my .09 bar cap still works great, I went ahead and switched to 1.1bar a few months ago and it works great.
