308 guys: buy Iridium plugs! | Page 3 | FerrariChat
Discussion in '308/328' started by Birdman, Aug 16, 2010.
  1. jimpo1
    jimpo1 Two Time F1 World Champ
    Jul 30, 2001
    24,524
    Dallas, TX
    Jim E
    Same plugs for a 328?
  2. Steve Magnusson
    25,137
    #52 Steve Magnusson, Sep 3, 2014
    No (different thread size) -- you can look up the stock 328 NGK plug (both ES and EIX) at NGK Spark Plugs USA (I'm in the pro-V, VX, and IX camp, too).
  3. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,690
    Sarasota
    David
    Dave Feinberg put them in my 77 GT/4 last year and they're great. Starts easily hot or cold. Runs clean at Max power or just pottering around in the Florida heat.
  4. leslie_choo
    leslie_choo Formula Junior
    Aug 5, 2012
    422
    Singapore
    BCChoo
    #54 leslie_choo, Oct 25, 2014
    I am using the same set up as Birdman on a 308 GTS carb . I am not sure anyone has tried brisk ? Definitely more expensive and they claimed the spark is 360 degree..
    Amazon.com: SET OF 8 PERFORMANCE SPARK PLUG Ferrari 308 GTS 3.0L V8 with all engine serial nr. (1980) * 4513PLR14ZCSLU52: Automotive
  5. Papa G
    Papa G Formula 3
    Dec 29, 2003
    1,406
    I run NGK BPR7EIX plugs without any issues - great plug.
  6. DANCER308
    DANCER308 Formula Junior
    Oct 24, 2009
    935
    KY
    Dan
    What car do you have them in?
  7. Papa G
    Papa G Formula 3
    Dec 29, 2003
    1,406
    '77 308 GTB
  8. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,540
    Cerritos, CA.
    I believe that carbs car will benefits more with the Iridium plugs.
  9. George Vosburgh
    George Vosburgh F1 Rookie
    It's on my list, haven't gotten there yet. But I have to say, my '77 is running so strong and so fast it's hard for me to think it could get better.
  10. 4right
    4right F1 Rookie
    The biggest power gain that I received from an ignition perspective was when I replaced the points with electronic ignition and high power coils. Night and day difference and no more fouled plugs!
  11. keysmatt
    keysmatt Karting
    Oct 31, 2014
    80
    Key Largo, FL
    Matt Anderson
    What Iridium plug do I use in a 81 GTSi? Also, What size spark plug wrench do I use? None of the wrenches I have seem to fit.
  12. RobinD
    RobinD Karting
    Aug 17, 2014
    92
    Lincolnshire
    Robin Duxbury
    NGK BPR8EIX should do it and 14mm spark plug socket with small extension on works for me
  13. miahshodan
    miahshodan Karting
    Feb 25, 2016
    90
    West Jordan, UT
    I know this is an old thread, but I noticed your page says BPR6EIX Ferrari 308 Consumables (birdman308.com) but this post says BPR7EIX which one did you decide was the right temperature?
  14. miketuason
    Feb 24, 2006
    15,540
    Cerritos, CA.
    I have been using the BPR7EIX on my 84 QV for years with good results.
    miahshodan, GordonC and Tustin308 like this.
  15. GordonC
    GordonC F1 Rookie
    4,121
    Calgary, AB, Canada
    Gordon
    Also using BPR7EIX, also on an 84 QV. That's the right heat range for general all around and sporting driving.
    miahshodan and miketuason like this.
  16. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    BPR7EIX is the correct heat range for the 308 GT4/GTB/GTS/QV engine. BPR6EIX is a tad too hot for spirited driving, that would be more suitable for the coffee racer drives.
  17. miahshodan
    miahshodan Karting
    Feb 25, 2016
    90
    West Jordan, UT
    thanks, I assume that is true for Carbed cars as well as FI? I have a 75 GT4
  18. f355spider
    f355spider F1 World Champ
    17,939
    Actually the NGK 6 heat range is often used for carb 308s in North America. Its what I used and was recommended to me by two Ferrari technicians. Obviously the coolest range you can use without fouling is ideal, so nothing wrong with starting with a 7, and if it works, stick with that.
    miahshodan likes this.
  19. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Yes, both for carbed and fuel injected, both engines have the same thermal range.
    Not sure why the technicians would do that, the BPR6EIX is too hot for the 308 except for city driving and cruising. NGK's official recommendation is also BPR7EIX, and that heat range works perfectly for the 308 series when driven both in the city and on the highway or track.
  20. f355spider
    17,939
    Might have to do with the type of driving in North America? There was a technical article in Forza magazine many years ago, and the technical advisor recommended NGK 5 (!) heat range for pretty much all carb Ferraris. Even I was taken aback by that recommendation.
    alhbln likes this.
  21. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    You have a point, the average speed might be lower in NA due to the speed limits compared to here. Still i would always start with the colder range and only go up in heat range (e.g. lower NGK number) if the plugs getting sooted, instead of starting with a hot plug and risking preignition engine damages.
    NGK 5 is a bit crazy, maybe there was a relation with the different type of fuel back then but i would not trust that heat range in a 308 for anything more than parking.
  22. f355spider
    17,939
    The year of the article recommending NGK 5 for carb Ferraris was early 2000s...maybe 2005 or 2006? But agree, start cooler, go hotter when necessary.
  23. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,410
    Toronto / SoCal
    Rob C.
    I going to throw a monkey wrench in this discussion by saying I have recently changed from NGK 7's to NGK 5's with really positive results.
    On my carb 308 with conventional coils, mechanical advance, and a Pertronix ignitor replacing the points I ran the Iridium BPR7EIX's for years and was pleased with the performance. My ignition system is in good condition, the carbs are fresh, the compression and leak down are excellent so I know the basics are good. The carbs were set using O2 sensors in the exhaust to optimize the jetting so I know that is also good. Despite all of this my plugs were always dark and the engine lacked the low end snap I knew it could have. It seemed as though the engine constantly needed high speed bursts to 'clean' out the plugs. After a good hard run the car was extra zippy down low but then would bog after a short time driving a moderate speeds (we are talking very little differences here).
    After changing to BPR5es non iridium conventional plugs the engine now performs just as well up high but is much cleaner running at low speeds. It also starts easier cold and the plug colour is much closer to ideal. I am about to go one step further and put in a set of BP5ES plugs because I do not need the resistor in my car. Nothing about the way the car runs or the colour of the plugs indicates that the heat range of the plugs is anything less than an improvement over the 7 heat range plugs.
    lm2504me and f355spider like this.
  24. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    EIX and EIV plugs are numbered one step colder than BPR and BP (conventional tip) plugs, so the BPR7EIX equals a BPR6ES plug.
    Rob, haven't talked to you for ages! Your experience with the car starting easier cold with the ES plugs is interesting, as it contradicts with the physics of both terminal types. The EIX and EIV plugs have tiny electrode surfaces which lowers the voltage required for a spark crossing the air gap. This is the reason why EIX and EIV are so interesting for conventional inductive coil ignitions, but won't change anything with a CDI/Dinoplex/MSD ignition.
    f355spider likes this.
  25. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,410
    Toronto / SoCal
    Rob C.
    Adrien I make no secret about the fact that you forget more about electrical items while eating breakfast that I have ever known; it's all Greek to me. While all the science points to iridium plugs being better for cold starts my experience is that the hotter conventional plugs are better.
    That said I think what is happening is that the colder plug is not running as cleanly as the hotter one so while it does produce more spark energy, because it is fighting the 'dirtiness' of the plug, the net effect is that the spark is less powerful than the conventional plug which is cleaner to start with. I can confirm this theory because I tried putting in a brand new set of iridium plugs after the car sat a long time and I did not have the normal starting problems I did after the iridium plugs were driven around a few km.
    As an aside, years ago I raced (and still own and drive) Formula A direct drive 100cc karts. This is the premier level and where all the F1 stars got their start. 20,000 rpm 2 Cycle screamer engines which are incredibly sensitive to carb settings and spark plugs. So sensitive are the engines that if you foul even a new plug once it is garbage because the engine will never run right. It is even common to heat the engine on one plug and then change out to a fresh plug while it is still hot to run a race. All this experience has left me really sensitive to small variances in how an engine runs particularly as it pertains to fueling and ignition differences.
    Lastly I never knew the iridium plugs were stepped one level colder. Makes me even more comfortable with running the plugs I do.
    alhbln, Martin308GTB and f355spider like this.
