308/328 GTB/GTS / DINO GT4 PARTS CROSS REF. THREAD | Page 18 | FerrariChat
Discussion in '308/328' started by thecarreaper, Jun 25, 2005.
  1. Tvjake2
    Tvjake2 Karting
    Jun 28, 2017
    129
    Glendale, CA
    Tom J.
    Do you know of any nail polish color for Rosa Chiaro? Maybe I should ask my daughter to search for a match...
  2. Bertocchi
    Bertocchi Formula 3
    Jan 28, 2004
    2,176
    Austin, Texas
    David Castelhano
    I am looking for the grey flexible ducting used in the 308 (and Boxer) ventilation system. I.D. is 3 1/4" or 79mm. It's an odd size.
  3. Bertocchi
    Bertocchi Formula 3
    Jan 28, 2004
    2,176
    Austin, Texas
    David Castelhano
  4. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
  5. Bertocchi
    Bertocchi Formula 3
    Jan 28, 2004
    2,176
    Austin, Texas
    David Castelhano
    Thank you. We are doing a Concourse restoration and looking for grey hose..as original.
  6. jmaienza
    jmaienza Formula Junior
    608
    Massachusetts
    Joe
    If the ducting is still intact, but dirty, it can be cleaned. I washed mine using Simple Green and a Scotchbrite pad. I worked with a damp pad and removed dirt, grease and paint overspray. Mine (78 308 GTS) looked like yours and seemed to be made of a grey vinyl, not paper or cardboard.
  7. Bertocchi
    Bertocchi Formula 3
    Jan 28, 2004
    2,176
    Austin, Texas
    David Castelhano
    Yes it is grey vinyl. The two sections that lead from the blower motor are in very poor shape. Other pieces have fused to some of the components.
  8. ragtop1
    ragtop1 F1 Rookie
    4,934
    Ontario
    Larry Warren
  9. jmaienza
    608
    Massachusetts
    Joe
  10. BLACK HORSE
    BLACK HORSE Formula 3
    1,937
    California - Bay Area
    Rob
  11. absostone
    absostone F1 Veteran
    9,178
    3D print them?
  12. Kidasters
    Kidasters Formula Junior
    Oct 4, 2013
    546
    Houston, Tx
    Ken
  13. bustedbelt
    bustedbelt Rookie
    Jan 18, 2012
    10
    Burlington, VT
    Bill Lockwood III
  14. bustedbelt
    bustedbelt Rookie
    Jan 18, 2012
    10
    Burlington, VT
    Bill Lockwood III
    Is there a current google sheet version of the cross reference list?
  15. ragtop1
    ragtop1 F1 Rookie
    4,934
    Ontario
    Larry Warren
    Thank you for the info. I ended up buying the whole box from Superformance. Perfect match
  16. EEMark
    EEMark Rookie
    Aug 10, 2018
    4
    Mark Charles
    On the baldwin PF866 Fuel filter...
    The bottom washer is glued to the filter, and if you use an old spring from an UFI fuel filter, it won't properly compress that rubber washer to the bottom of the fuel filter, which means you risk not having a good seal there.
    The solution is to use a fender washer between the spring and the bottom rubber seal. THAT way, there's good compression against that washer, while pushing the fuel filter upwards!
    Use a washer with roughly 15mm i.d., and a minimum of 38mm O.D.
    If you want to get fancy, fix the fender washer to the spring permanently, that way it won't get off center.
  17. Pablo Pérez-Fuentes Ramos
    Dec 26, 2018
    3
    Castro-Urdiales
  18. Ferraritalian
    Ferraritalian Formula Junior
    Jan 19, 2019
    289
    Midwest
    Steve
    OK I’ve been researching gas struts for my ‘79 308. The following are what’s listed on eBay and Ricambi for most 308/328:
    Stabilus Lift o mat. #SG237001 about $88 a pr.
    Sachs #SG237001 (same as Stabilus # and also cross-references to #6271, Strong Arm number) abt $50 each
    Strong Arm #6271, abt $40 ea, many diff prices)
    Also another listing for Strong Arm under # ZD74N5- don’t know what that is.
    Ricambi #60592800 abt $60 each.
    Prices other than Ricambi all over the map, but kinda similar.
  19. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,149
    Kingsport, TN
    Lawrence A. Coppari
    I purchased these over a year ago. They fit properly and work fine
  20. vaccarella
    vaccarella Formula 3
    Apr 16, 2011
    2,291
    Paul
    I've always thought that simply regassing the existing is a better idea than buying new.
  21. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    Mine weren't stamped "Ferrari"... I believe they were dead Stabilus struts. For $23, less trouble to just replace.
  22. oelboxer
    oelboxer Karting
    117
    Matt Wright
    This isn't exactly a cross reference, or if it is it's a looooong toss across. Nonetheless, after searching forever for a seat belt receiver for my '75 Dino GT4, I found that the same Robbins seat belt used in my front seats were installed in 72-73 Volkswagens. I wrote up a DIY thread in this forum section if anyone is interested. Here are the two receivers side by side.
    NoGoSlow likes this.
  23. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    Caliper parts: I'm rebuilding the ATE calipers and for anyone doing this, Bigg Red on ebay has all four front 48mm pistons/seals for £40 (part No. BRKP86.) I got the rear caliper seals from buycarparts.co.uk (autodoc.de) for £4 each side (D4096) and they have the front seal sets for £5 each side (248030.) Always better to search for the 48mm and 38mm piston ATE parts listed for Porsche as they are cheaper. I think that some Ford Capri/Cortinas and a few others used the ATE 48mm front caliper with a 30mm high piston.
  24. kbento
    kbento Rookie
    May 12, 2014
    32
    Upstate NY
    Kevin Bento
    I just ordered 2 new Heater Control Valves for my '85 308QV. They are from an Opel and look to be identical, right down to the numbers stamped on the actuator arms. Here are the part numbers:
    opel SAVARA 9.82.029.11
    SAVARA 98202911
    Opel: 8948020 - 8.948.020
    Cost: 38 Euros each, plus 30euros to ship.
    https://www.spitline.com/index.php/rubinetto-riscaldamento-opel-kadett.html
    Once I get them, Ill let you know how they fit. Heres some pics of the ones from my car, teh rubber inside are shot, although they do prevent me from blowing through them... It PE had the line all plugged up and had the hoses bypassed, probably wasnt able to source replacement valves and didnt want to deal, so they plugged with rubber stoppers and put the hoses back on!!
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    waymar likes this.
  25. kbento
    kbento Rookie
    May 12, 2014
    32
    Upstate NY
    Kevin Bento
    For Starters, I found this guy in upstate NY that sells new starters for many Ferrari models:
    https://www.classiccarperformance.com/collections/ferraristarters-com
    I ordered one for my '85 308 QV, and the next day the owner (Dave Austin) hand delivered it to me while I was out in my barn working on it! Not sure if you will get the same hand delivered service (Dave just happened to be in the area).
    These are gear reduction starters, better than stock and more reliable.
    I highly recommend him, great guy and a great product. Fair price and a lifetime warranty.
    Andreas Engesvik and ATSAaron like this.
