3 piece rims are leaking | FerrariChat
Discussion in '308/328' started by jbell, May 14, 2008.
  1. jbell
    jbell Rookie
    Jul 8, 2007
    24
    Warwick N.Y.
    Jim Bell
    My front rim is leaking around the bolts that hold it together. How or were do I get them fixed. I dont know anthing about them why are they made like that. They are the same rims that are on a 288 gto. Any help would be great. thanks jim
  2. Motob
    Motob Formula 3
    Nov 11, 2003
    2,338
    Frederick, Maryland
    Brian Brown
    You should inspect the wheels to ensure that they are not cracked and that the bolts are tight. If so, then you have to dismount the tires. Clean the area where the rim halves are joined and apply a bead of good quality RTV silicone sealant to the joint.
  3. ALUMINUMYELLOW328
    ALUMINUMYELLOW328 Formula Junior
    May 30, 2004
    381
    Bergen County, NJ
    Rhett R Arcilla
    Check out Wheel Collision on the web and see if they can help you.
  4. jbell
    jbell Rookie
    Jul 8, 2007
    24
    Warwick N.Y.
    Jim Bell
    Thanks for the help. I am going to silicone it first and see what happens. I went to a rim and tire place and saw a rim there, it had silicone on the seam. jim
  5. RichardAguinsky
    RichardAguinsky Formula Junior
    Nov 12, 2007
    478
    Palo Alto, Californi
    Richard Aguinsky
    I had that problem with one of my rims. I put the wheel in a large pan with water and look for all the leaks. In my case, I had an area of about 1/2" where bubbles would come out. I was surprized to find that, I thought I was going to find a pin hole, not a defect in the material.
    I marked the area. Cleaned it well and sanded it. Took all the air out of the tire. I used JB Weld, the black and red epoxy from PepBoys, Napa, etc. I left it curing for 72 hrs before inflating the tire again. It worked great for me.
    If you don't deflate the tire, the leaking air will bubble through the epoxy. It stays soft for hours.
  6. F&M racing
    F&M racing Formula Junior
    Feb 26, 2006
    668
    Michigan
    JimF
    I pulled my Porsche's BBS wheels apart to powder coat, and I put them back together with silicone between the center and wheel halfs. I did this about 7 years ago, no leaks!! Just make sure you tighten the bolts in sequence and you should be ok.
