3 car garage heater suggestion?
Discussion in 'Ferrari Discussion (not model specific)' started by doctorj!, Nov 13, 2011.
  1. doctorj!
    doctorj! Formula 3
    Aug 3, 2010
    1,509
    Jersey
    AJ
    So I am putting in a heater in my 3 car garage so I can keep my 599 with me at all times. I worked the numbers, and it will be cheaper in the long run to install a heater and pay for the gas/electric vs 3 months of storage every year.
    Any suggestions for a heater?
    AJ
  2. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Check out craigslist.com. A friend just bought a used NG heater for $50, list new was $250.
  3. SCKOMS
    SCKOMS F1 Rookie
    3,900
    Lake County, IL
    Spiro
    Several years ago I installed a Dayton model 3UG73. It is electric so no venting needed. It keeps my 600 sq ft 3 car garage at 50 F without running very often. It is mounted to the ceiling and is very compact. However, you will have to run 220volt service to your garage if you don't have it. The unit cost around $400 brand new. I am very pleased with it.
    Schulz308 likes this.
  4. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    I would consider something along the lines of gas fired hot water / radiator type of system. They can be had in suspended models with blower or convection type... several options in compact sizes, depending on expecations. For a storage / garage installation where overall temperature maintainance is more important than quick recovery a convection system should have low acquistion and operating cost, especially in the north. If the garage floor is in need of an upgrade, heat coils could be installed into the floor as an option. Become informed and you should find the correct solution.
  5. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I got a free forced air high-efficiency furnace from a house that was going to be demolished and put in my garage. It is sized for a small house, perfect for a 1000sf garage. It is a wonderful thing and installation cost was minimal.
  6. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    I have a propane fired shop heater mounted on the ceiling of my 2 car garage. Works great. Mine is 45k Btu but they make a 75k one for a larger space. My garage is standalone and not very well insulated but this keeps up no problem. it is vented out the gable end of the garage. Standard house thermostat.
    I got mine at Lowe's for $300, best money I have spent.
    Here is a link to the company website
    http://www.mrheater.com/product.aspx?catid=50&id=117
  7. ENDOSURG
    ENDOSURG Karting
    Dec 9, 2008
    70
    Massena,New York
    Vijaykumar Mandalaywala
    You may want to check this site...Reviews are good as well as the price...
    http://www.air-n-water.com/product/G73.html
  8. bill365
    bill365 F1 Rookie
    Nov 3, 2003
    3,319
    Chicago area
    Bill
    #8 bill365, Nov 13, 2011
    Would electric radiant in floor retrofit be possible?
    There are a number of low-voltage mat type systems available, that can be installed with a portland cement veneer over the existing slab floor. Like laying ceramic tile, without the tile, or you can lay tile on top, if desired. Since heat rises, everything above gets warm. It will also dry the floor quickly. It is very efficient and is best to leave it on, during the heating season, because it takes a while to re-heat the slab. Because you would be heating the slab, it prevents frost-heaving and floor cracking.
    http://www.cement.org/tech/pdfs/PL971Radiant.pdf
    http://www.concretenetwork.com/radiant-floor-heating/retrofit.html
    http://www.warmyourfloor.com/nuheatfloorheatingmats.aspx?gclid=CMWy9I6JtKwCFQrGKgodUFlU2Q
  9. BlackHorseRacing
    Sep 2, 2008
    31
  10. fskof
    fskof Karting
    Nov 23, 2005
    217
    Milwaukee, Wi
    Frank
  11. Glassman
    Glassman F1 World Champ
  12. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Forgot to mention it's 75k BTU. I think there are a few listed.
  13. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Why not a heat pump so you get cooling in the summer too?
  14. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    heat pumps don't work in cold climates... when it gets cold they go to strip heat mode ( use electric elements, as in a common electric heater ) depending on area, electricity can be costly
  15. Mr. V
    Mr. V Formula 3
    Oct 23, 2004
    1,247
    Portland, Oregon
    I don't know whether you have central air / heating for the the rest of the house, but if you do, have an HVAC guy run it / extend it to your (presumably attached) garage.
    You can have zonal temp controls installed, so you only use heat and AC when you want it.
    I did this when I bought my current home, and it works great.
  16. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    it is against building code in many areas... to heat / cool garage areas with the same system as the rest of the house... the major concern is carbon monoxide and other toxic gases
    on the surface it seems like not a big deal, but in reality it is serious. Also it may be in breach of insurance, should somethng happen, the insurance carrier could use that to not pay any claims... If it is in violation of code, it could affect a future sale of the house. Better to verify your local building codes. The codes are based on substance, so there is some reality behind their caution
  17. fgcfire8
    fgcfire8 Formula Junior
    Jan 19, 2008
    459
    Montpelier Va
    Frank Castelvecchi
    Yes garage HVAC air ducts need to be separate from house by code. If you have a hot water system could do water loop to garage.
    When you heat/cool the garage, code will also require that it be insulated.
    That said in NJ top end system for heating and cooling would be heat pump with gas fired backup or geothermal heat pump.
    considerably lower installation cost would be gas fired unit heater or electric unit heater, if have gas, gas is a lot cheaper to fuel than electric resistance.
  18. PRS
    PRS Formula Junior
    Jun 1, 2011
    715
    Issaquah
    Pete S
  19. PaulK
    PaulK F1 Rookie
    4,770
    Michigan
    Paul
    Curious, just how much are the running costs to heat a garage?
  20. raider1968
    raider1968 F1 Rookie
    Mar 13, 2008
    4,966
    NC Mnts & Asheville
    John E
    #20 raider1968, Nov 17, 2011
    You can heat the floor with 1 30-60 gal water heater, a closed loop piping (called pecking) with a thermo on the wall - it controls a pump. It will not bring the garage up to a room temp in a freezing area but will be good enough for the cars - best heat also - from the ground up - I use this plus regular heat when in my garage in the mountains but only the floor heat when I am gone for the winter
  21. Nurburgringer
    Nurburgringer F1 World Champ
    Jan 3, 2009
    11,161
    Texass
    Our garage is ~850 sq ft (4 cars with plenty of space around them) with 8ft ceiling and has a large, NG forced air heater built into the ceiling. Fairly well insulated, but even so in doing research on past gas bills they were quite high in the winter.
    This'll be our first winter in the house - couldn't tell what was house and what was garage, but in an effort to keep my winter gas bills low I just bought one of these (recommended by fellow Milwaukee F-chatter Joe):
    http://www.heatersunlimited.com/item29040.ctlg
    I know the 25k BTU model won't heat the garage to 70F+ in January, I'm just planning to use the radiant heater to keep it 40-45F, then fire up the big forced air unit when I plan to work out there for 1hr+.
    Radiant is much more efficient and doesn't move air&dust around. I plan to install it this weekend, will let you know how it works.
  22. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    their site says the heater is ventless, something to give second thought to
    from my experience ventless heaters usually have a disclaimer in the fine print that requires fresh air be vented ( open window etc ) into the space being used, limit the time spent in that space, time heater can be run etc to avoid build of toxic gases.
  23. Nurburgringer
    Jan 3, 2009
    11,161
    Texass
    #23 Nurburgringer, Nov 18, 2011
    The heater came with a ~12"x12" outside-vent, but after speaking with the sales tech we determined that my garage should have sufficient leakage (2 garage doors, 4 windows, 2 outside doors) that punching another hole in the wall isn't necessary.
    Joe - if you're on did you add any vents in your garage?
    This is where I plan on mounting mine. There's an exisiting 3/4" gas line running to the ceiling mounted forced-air heater, so I just need to install a 'T', ~12" straight piece, another T, and a 3/4-1/2" reducer to go to the flex pipe to the infra-red heater on the wall.
  24. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    "came with outside vent"... "should have sufficient leakage"... tells me there are venting / clean air issues... a proper hot water "boiler" or forced air furnace has zero emissions...
    there are plenty of outside walls to vent combustibles through and perhaps overhead / in roof space...a hot water system can take up very little space and be mounted anywhere... radiators can be convection or powered or both and installed anywhere... radiant heat from the floor
    what really is amusing is the penny pinching hap hazard logic, a single trip to the dealer for service is significantly more costly than a properly installed heating system that will deliver much better heat under any conditions at no personal risk.
  25. Nurburgringer
    Jan 3, 2009
    11,161
    Texass
    Well that's a rather odd response. Why so surly?
    I'd love to hear an HVAC expert's input on that statement.
    In-floor hot water systems sound great, but I believe the OP is not building a new garage.
