78 308 fuel filler neck hose | FerrariChat
Discussion in '308/328' started by Jdubbya, Apr 18, 2010.
  1. Jdubbya
    Jdubbya The $10 Trillion Man
    42,249
    PNW
    #1 Jdubbya, Apr 18, 2010
    First of all, no this is not simply another thread about fuel hoses, but while taking mine apart I did find something very interesting. It's been a few years since my fuel hoses had been touched and I didn't know if the filler neck had ever been done. I needed to do a filter and pump anyway so figured "while I was in there" I might as well do the fuel hoses too.
    After reading all the threads about E10 affecting the hoses I figured it wasn't a bad thing to at least take a look at mine since they just started using E10 where I live last year.
    Cutting to the chase of this thread, I started cutting the filler neck hose off and had one heck of a time getting a razor through it. I was thinking to myself, that is one crusty hardened old hose if it's this hard to cut! After I got it off it turns out it wasn't really a hose, but a plastic plumbing flex fitting and let me tell you, there is no way it had even started to deteriorate, and even less possibility that gas could ever leak out of it. I'm thinking someone had stuck this on in the past after fighting to find a hose that would last. I think this thing could have been on there for the rest of this car's life and never leaked, it is tough!!
    Has anyone ever seen this type of thing on their car? I also have read in other threads about the filler neck being 1 3/8" or 1 1/2" but mine is actually closer to 2" (and also the size of the Fernco fitting). Did the size change at some point or is mine an oddball?
    I've been talking with Dave Helms about his new hose set and will likely buy it just for peace of mind if nothing else, but the other smaller hoses that I've taken apart so far seem to actually be in good shape.
    Just curious if any has opinions about this!?
  2. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,652
    The fabulous PNW
    Han Solo
    Mine was plain old dried out, cracked rubber but still a bit tough to cut off.
  3. Champboat/Champcar
    Champboat/Champcar Formula Junior
    Jan 29, 2007
    885
    Freeport NY
    Eric T
    My fuel filler hose on my old GT4 was also 2 inches dia. , it was completely shot, Probably original.
  4. Spasso
    Feb 16, 2003
    14,652
    The fabulous PNW
    Han Solo
    IIRC I replaced mine with a NAPA 1055 and two Marmon clamps.
  5. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    ** +1 Exactly what I did too, even the clamps, no more worries.
  6. Spasso
    Feb 16, 2003
    14,652
    The fabulous PNW
    Han Solo
    #6 Spasso, Apr 18, 2010
    At 1/10 the cost for equal stuff.
  7. Jdubbya
    42,249
    PNW
    I managed to get it but ended up with 2 1/4" hose. I couldn't get anything smaller over mine even with the filler neck sitting on the workbench! It clamped up nice and tight though so I'm not worried about it. Once I went to the larger size it was actually fairly easy.
  8. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    I ended up doing the same with my car - used 2 1/4" industrial fuel transfer hose I obtained through one of my workplace suppliers (Newline).
    It's their own label but it appears to be made by Goodyear. The spec is SAE J1527 A2 and it's rated for a whole bunch of stuff (ethanol, methanol, gasoline, diesel, etc...). I wouldn't be surprised if it would last the rest of the life of the car (or until some other magic, "green" fuel takes over the market ;) ).
