250 Washer Pump testing and installation - any experience? | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by gimmea250swb, Nov 26, 2019.
  1. gimmea250swb
    gimmea250swb Formula Junior
    575
    Washington, DC
    Taylor
    Dad asked me to check his 250 washer pump before he cleans/installs it. The two terminals closest to the plunger are normally closed and they open when the plunger is pressed. The rear terminals are normally open but when the plunger is pressed there is no change. Seems like they should close.
    How is the power connected when installed? The red/black wire in the photo has a connector that may attach to one of the mounting bolts in the back (as ground) and then attach to one of the terminals? Which terminal is positive?
    Thanks!
  2. Motob
    Motob Formula 3
    Nov 11, 2003
    2,238
    Frederick, Maryland
    Brian Brown
    The pump does not have a positive terminal. One terminal is connected to ground (through an wire that uses an eyelet terminal on one of the mounting bolts).
    The other terminal is connected to a wire from the wiper motor. When you operate the washer pump, it connects the two rear terminals together, causing the wiper motor to make a single wipe.
    Brian Brown
    San Francisco Motorsports
    gimmea250swb likes this.
  3. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    3,045
    San Francisco Area
    John Vardanian
  4. gimmea250swb
    575
    Washington, DC
    Taylor
    Thank you gents. So from your explanations and photos we've got a repair to do. The rear terminals do not connect when the plunger is pressed. I appreciate your help very much!
  5. enio45
    enio45 Formula 3
    1,537
    Gilbert, AZ
    Ed
    sounds like time to take it apart - probably some corrosion in there
    is this on the ellena car?
  6. gimmea250swb
    575
    Washington, DC
    Taylor
    Hey there! No, it's a Lusso
