250 HP Mondial, Cheap Ferrari,, etc. | Page 9 | FerrariChat
Discussion in 'Mondial' started by 350HPMondial, May 30, 2014.
  1. 350HPMondial
    350HPMondial F1 Veteran
    5,322
    Edwardo
    Found in Transmission,,, Cambiocorsa Pan.
    Ferrari Crown Ring Bolt/Locating Pin. Ferrari P/N 106777 $ 98.00 for one.......!!!!!!!!!!!!
    Note the machined stress riser under the hex cap.
    I wouldn't give you $0.02 for anymore of these,,,,,,, for your gonna break them all.
    Pulling Mondial-8 differential now.
    (whew)
  2. 350HPMondial
    5,322
    Edwardo
    The holes thru the differential have plenty of "chamfer," on the Sx side.
    Why the 90 deg stress riser under the bolt hex head????????????????
  3. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    Wow. Glad no other damage to the trans.
    Aaron
  4. 350HPMondial
    5,322
    Edwardo
    Aaron,
    AAAA ha ha,,, that is the trick. To Have,,,, The bolt finally jam inbetween the Crown Ring Pilot, and the Rear end cover..... at 2 mph,,,,,,,,, in my gravel driveway.
    (whew)
    so,
    Luck is my middle name. I must be a Tabby Cat ( Like Tippy, my last and best cat.) ,,, for, I'm definitely into my 7th life.. ha ha
  5. 350HPMondial
    5,322
    Edwardo
  6. 350HPMondial
    5,322
    Edwardo
    Hey All,,,,, the search function is your friend.
    Verrell,,,,has been down this road,
    13 years ago.
    I'm going to use (4) Ferrari Factory 106777 Crown ring bolts.
    With New,,, Ferrari Nuts 104011,,, properly torqued.
    Alternated with,
    (4) 10 x 1.25 x 70 Cap Screws, Gr 10.8,,,, with the M10 nuts used on the 308 CV joints.
    This is my best guess for an adequate repair.
    All Ferrari Engineers,,,
    and resident expert on Unobtainium parts,,, Mr. Birdman,,, aka Verrell,
    Please advise,
    Edwardo
  7. 350HPMondial
    5,322
    Edwardo
    Thus, Birdman was correct in his quote," So, what we do is Just shop for thickest grade 12, 10mm bolt we can find.
    Correct he is.
    The problem is Not The Bolt.... The hole is too Big...!
    The Crown Ring Bolts break,,,, because,
    the Ferrari geniuses designed a 0.020" clearance,,, in an application that requires an, " ASA Class 4 fit, 0.0025" max. clearance.
    My FAA Certified mechanic says, 0.0010" clearance is preferred.
    Note, the next class, a class 5 'interference fit," will require 0.000" total clearance....
    ARP has Grade 12 Bolts.
    Shoulder Diameter is 0.392" a Full 0.001" thicker,,, then the Ferrari Factory Crown Ring Bolts, p/n 106777,,, and, The Heads Won't pop off,, at 75 MPH,,,, sideways in the fast lane.
  8. 350HPMondial
    5,322
    Edwardo
    Torque is going to be 8 Kg.m
    Thanks for tuning in.
    Edwardo
  9. 350HPMondial
    5,322
    Edwardo
  10. 350HPMondial
    5,322
    Edwardo
    MvT and Wade like this.
  11. Temple
    Temple Formula Junior
    Jun 13, 2015
    594
    Portland, OR
    Temple
    Great job, congrats. And thanks for the info & pics!!
    Temple
  12. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Good find on those ARP bolts!! Suspect they weren't available when my bolt let go.
  13. 350HPMondial
    5,322
    Edwardo
    Mr. Verell,
    Thanks for chiming in. 15 years ago,,, we used WOODEN DOWELS.. I mean, New Improved Ferrari Bolts.
    Just, same old design flaw..... with new bolts.
    Sheeeeeese,, laweese!!!!! That square peg just fits in that round hole.. But, it is still Wrong.
    Ha
    That ARP bolts are 0.001” thicker
    davem and paulchua like this.
  14. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    From your pix it looks like the extra length of the ARP bolts is not a problem.
  15. 350HPMondial
    5,322
    Edwardo
    Verell,
    Hello,
    Hope your out enjoying this great driving weather.
    And,
    Yes, you are correct... I was considering cutting off the extra 3/16” of protruding threads,,, down to a proper 1/16”,,
    But, the ARP bolts are installed in the opposite direction as the original Ferrari bolts.
    Thus,,, the ARP bolt head is against the crown wheel and the clearance for the protruding threads is greater.
    Whew
  16. 350HPMondial
    5,322
    Edwardo
  17. 350HPMondial
    5,322
    Edwardo
  18. 350HPMondial
    5,322
    Edwardo
    All,,,, beeen a while.
    hope your all well..
    Front cover bearing... done
    Now,,, see rear head,,, pulled due to burned valves in # four cylinder.. Due to bad brake booster.
    ( Brake Booster issue, rebuild it for $ 200.00,,
    sent to Steve at Power Brake Booster Exchange... they do Ferrari...)
    harumph....!!! Thought that a hobby was supposed to make your blood pressure go down....????
    ha ha
    Now, Everything should be fixed...
    (whew)
    Thank You Climate Change.... ha ha
    endless summer here in California.
    Drive those classics...
    (smile)
    Eduardo
    Jeka and paulchua like this.
  19. 350HPMondial
    5,322
    Edwardo
    After my brake booster valve failed. (Thus,, burning the intake and exhaust valves in # 4 cylinder. )
    Some internet threads debate as to the usefulness of moving the Brake Booster vacuum port,, from its factory position on cylinder #4 intake runner,,, up, into the intake plenum.
    1) In the event of another Brake Booster failure,,,, The factory position allows only #4 cylinder to go lean... Somplifying repairs and isolating damages to the rear bank and head,,, which can be removed easily with motor in car.
    2) You can actually remove # 4 Piston and Liner,, with the motor in the car.
    ( After the difficult,,, oil pick up tube removal..)
    3) When you lift the throttle and stab the brakes,,,,, The motor gets a slug of air from the booster. All cylinders are running lean at this point. Thus,, it doesn’t matter if #4 is running lean,,, it’s not under load.
  20. 350HPMondial
    5,322
    Edwardo
    So,,, I am going to ignore the above factory logic.
    in photo,,, on left,, See 1/4 “ hex plug installed in cyl. #4 intake runner.
    The thread is actually a 7 mm ,,, but, a 1/4 NPT fits nice,,, with lots of teflon tape.
  21. 350HPMondial
    5,322
    Edwardo
    This is how the longer ,,, brake booster vacuum tap will look ,,,, when installed in the plenum. When I stab the brake peddle,,, It will deposit air into the intake stream for cylinders #3 and # 6.
    I will continue to monitor the Air/Fuel mix with an O2 senser in the foreward bank. We will see how lean it goes when I stab the brakes.
    Ok,, so now I need feedback. from you guys. Good idea or not????
    ( whew)
  22. 350HPMondial
    5,322
    Edwardo
  23. 350HPMondial
    5,322
    Edwardo
    #224 350HPMondial, Oct 25, 2018
    Note:
    This intake system for the 308 GTSi series of motors has the characteristic of poor flow into the rear bank of cylinders. Numbers 1 - 4. Thus,, the rear bank ,,, always runs leaner then the front bank.
    This is not good for the Cylinder #4,,, since it is already required to gulp the extra air from the brake booster.
    of Last Note:
    The hose barb is cut as short as possible to allow the 1/2” vacuum hose to clear the Mondial engine cover frame rail.
  24. mwr4440
    57,919
    Bavaria, The 'Other' Germany
    Mark W.R.
    Edwardo,
    When you put the lower belt drive pullie back on, how do you know it is on the snout far enough or too far?
