News
250 HP Mondial, Cheap Ferrari,, etc.
Discussion in 'Mondial' started by 350HPMondial, May 30, 2014.
  1. 350HPMondial
    350HPMondial F1 Rookie
    Feb 1, 2002
    4,735
    18 mi from the surf.
    Edwardo
    Your Labor is alllllll-Ways free.
    Let's see,, 100.00 per hour.
    15 hours a week.
    Eight years...
    = $ one million dollars
  2. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    #152 350HPMondial, Jan 29, 2016
    Fixing Fuel Pump Voltage Drop forever.
    Careful,,
    Don't get the board too hot trying to solder on 16 gage wires.
    For,
    Your warranty from GT car parts is now void
  3. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    #153 350HPMondial, Jan 29, 2016
    My Bob Cat has been on top of my Storage shed.
    Little too close for comfort,,, I have some firecrackers for him,,, if I see him this close again.
    Don't want to hurt him,,, he is cool looking.
  4. paulchua
    paulchua Cat Herder
    Moderator Owner
    Jul 1, 2013
    7,624
    Menlo Park, CA
    Paul Chua
    I continue to bow to your greatness....
    Keep up the great work!!!
    Be safe with those bobcats my friend!
    Cheers
  5. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    #155 350HPMondial, Feb 27, 2016
    Thanks Paul,,,,
    For tuning in..
    Hey!! I'm half way out of smog hell.
    ( California )
    Got Zero,, Nada,, nothing,, at ideal speed.
    Hoo Raa
    But,
    I got CO, 2.27 at 2500,,, néed 1.5
    Das Book says 1.2 is nominal ....??? For my Ferrari 308 GTSi Motore'
    Let's see,, drop Primary Pressure a little.
    I believe I replace the Factory 1.0mm shim down to 0.4mm..
    Retest.
    Stay tuned,,,
    pun intended.
    paulchua likes this.
  6. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    Aaaaaaaaa nope,
    To lean the mixture,,,, Raise primary pressure,,, a little.
    I have a 1.5 mm shim,, in place of the 1.0 mm factory.
    Whew.
    Next week will retest.
    Stay Tuned.
    Pun intended....
    Hoo Raa
    Edwardo
  7. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    #157 350HPMondial, Mar 4, 2016
    Hey now,,, got engine cover on for a test fit...
    See 600.00 of bodywork,,
    Including shrinking dents,,, etc.
    and, it still needs sealed and sanded,, with a top coat of PPG Nero Urethane.
    ( whew)
  8. bartzagato
    bartzagato Formula Junior
    Aug 7, 2010
    614
    Belgium
    Bart
    Edwardo,
    If you keep digging in like that: this can't be the cheapest Mondial anymore.... ;)
  9. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    #159 350HPMondial, Mar 23, 2016
    Bart,
    Don't jinx me. ;)
    This thing has to fall under 20k,,, or?
    Thus,
    Hey all,, I got your parts here.
    New in box, SS intake valves,,, half price.
    Edwardo
    Hoo RAA.!!!
    (it passed smog.)
    Now on to the exhaust system rebuild.
    And, see my Red Shafted Flicker... My alarm, at 6:00 am.
  10. Alden
    Alden F1 Rookie
    Rossa Subscribed Owner
    Apr 25, 2010
    2,708
    Central Florida
    That looks like a red handled shovel to me. :)
    Alden
  11. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    Alden,
    That is a Snow Shovel. Ha ha. Waiting for a few flakes..
    (Thanks for noticing.)
    I use it to shovel Bull ****,,, yes, the real stuff,,, not what you-all are thinking.
    Edwardo
  12. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    #162 350HPMondial, Apr 21, 2016
  13. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    #163 350HPMondial, Apr 25, 2016
  14. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    #164 350HPMondial, May 24, 2016
    Waiting on my muffler install.
    Painted Engine Cover PPG Nero.
    (Smile) yes it is very black,, thus, you sand for two months.
    (Whew)
    Next,
    Found the source for three small oil wheeps,, not really leaks,, just annoying.
    Two easy,, oil cooler hose fitting needed a new copper O ring,, and, the drain hose for the fwd. valve cover.
    Now, to pull one Cam Cog bolt,, O ring needs replaced and black grease used upon install.
  15. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    #165 350HPMondial, May 24, 2016
  16. Cadillacbart
    Cadillacbart Formula Junior
    427
    Denver, CO
    Does this fix the clicking fuel pump relay? What are you fixing here?
    Thanks, apologies if this has been addressed and I missed it:)
  17. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    Yes,, and other issues caused by those 2 Old blade and lug connectors.
    On those two 8ga red wires that run under the font bumper.
    And, those
    Connectors are metric and NLA,, unless, you buy and entire foreward wire loom.
    Note,
    All of the cars power is lost if these Both fail.
    Mine are now technically bolted Togather.
  18. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    #168 350HPMondial, Jun 13, 2016
  19. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    #169 350HPMondial, Jun 15, 2016
  20. MvT
    MvT F1 Rookie
    3,789
    The Netherlands - NH
    Tijn
    oh wow! custom! why only a single pipe and not a twin on each side?
  21. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    Tips are to be painted,, flat White VHT.
    Like a Real Ferrari should.
    Next,, we pull the foreward valve cover.
  22. Robz328
    Robz328 F1 Veteran
    5,856
    ATL, Georgia
    Rob Hemphill
    Nice exhaust!
  23. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    #173 350HPMondial, Jul 9, 2016
  24. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    #174 350HPMondial, Jul 9, 2016
  25. 350HPMondial
    Feb 1, 2002
    4,735
    Edwardo
    #175 350HPMondial, Jul 16, 2016
    Torqued all head nuts to 72.4 lbs..... Six out of ten moved....!!
    One nut spun an additional 270 deg.
    No snappin der head studs. (whew)
    All intake valves at 0.010,, cept one at 0.011"
    New, exhaust valves clearance is more,,,,,?? About 0.003 per valve.
    But, they all varied the same clearance and a few thousandths more wont hurt at this phase.
    And, rear Valve cover is on.
    Beer me.
