250 HP Mondial, Cheap Ferrari,, etc. | Page 5 | FerrariChat
Discussion in 'Mondial' started by 350HPMondial, May 30, 2014.
  1. 350HPMondial
    350HPMondial F1 Veteran
    5,321
    Edwardo
    #101 350HPMondial, Aug 12, 2015
    Waiting on parts....
    See my Lil Bull.... He is shy,, stays tight with the herd,, good thing,, I saw a bachelor coyote a few days ago.
    Ha
  2. rob
    rob F1 Rookie
    May 22, 2002
    4,271
    Vt
    Those coyote are bad, bad news. Open season on them here in Vt evil animals.
  3. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
    They are everywhere, even in the cities and suburbs. I see them weekly, in our streets and even in the alleyways behind our houses. Mostly in the evenings and at night.
    However, they aren't as bad as the feral hogs that are breeding exponentially here. Even in the suburbs, they are causing problems. And, feral hogs are not afraid of people (most coyotes are - unless they are rabid).
    For an interesting perspective, google Helicopter Hog Hunting (don't if you are squeamish).
    Sid
  4. rob
    rob F1 Rookie
    May 22, 2002
    4,271
    Vt
    Yes Feral hogs are REALLY bad news. Luckily we don't have any near me but we have had them over in upstate new York. I remember seeing on the news they totally devastated a couple of farms.
  5. 350HPMondial
    5,321
    Edwardo
    #105 350HPMondial, Aug 13, 2015
    Right On Sid,,,
    we have Feral hogs here too.
    No not bikers up riding our cool road.
    Bad Pigs,,, mean, will Kill you.
    The only way I feel safe when they come to graze,, is with slugs in a shotgun.
    If you shoot piglet ,,,?? The mommas will attack.
    Coyotes are Very adaptable to city life. Shame,,, then they cease to be, Truly coyotes.
    Edwardo
    See my Volvo Valve Shim kit and my V W Rabbit Shim Plyers. With my massive valve job,, I need 16 shims.
  6. 350HPMondial
    5,321
    Edwardo
    #106 350HPMondial, Aug 20, 2015
    Intake Cams installed.
    Now, Valve Covers sealed on one side, waiting on 7 more shims.. My exhaust valves are Tight,,,, very tight.
    I have used all the thin shims in my Volvo kit.
    Called Interntional Auto Parts,, a Fiat Supplier,, to get the thin,, 2.95 and 3.00 mm shims not in the Volvo Kit, at less then $ 3.00 each,,, I should have called them first.
    Baby Steps... For This, needs to be right.
    Hoo Raa.
    Edwardo
  7. 350HPMondial
    5,321
    Edwardo
    #107 350HPMondial, Aug 20, 2015
    USA Compliant Exhauste,,, built in Santa Monica, ca..
    Ha ha.
    Crap to be installed for California SMOG check soon.
    Better CAT system to be built.
    Edwardo
  8. 350HPMondial
    5,321
    Edwardo
    #108 350HPMondial, Aug 20, 2015
  9. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,408
    Menlo Park, CA
    Paul Chua
    keep up the good work Edwardo!!! I love these updates...
  10. FCnew
    FCnew Formula Junior
    May 5, 2015
    687
    Hong Kong / Canada
    Jonathan
    +1
  11. 350HPMondial
    5,321
    Edwardo
    #111 350HPMondial, Aug 25, 2015
    Thanks Paul,,, 1000 th post too.
    Jon,, thank you too,, I'm getting closer to a Second drive.
    First was in my driveway,, into the garage.
    Edwardo
    PS. See my little Ranch friend. Looks like a male terantula. Very poisonous,, mad at me too.
    Gave me the heivie geevies. Thank god it has No Fangs.
  12. 350HPMondial
    5,321
    Edwardo
    #112 350HPMondial, Aug 25, 2015
    20 cam bearing blued.
    16 valve shi,,, shimmed,,,,, each and all at least 3 times.
    Intakes at 10-12.... Exhaust at 15-17. Thousandths. Looooooose. ( They should tighten up with break in.)
    Next,,,
    Four Cam cleaned and installed with new O rings.
    Two Fat gates belts and Cam are all quickly timed with the help of Scottys Aluminum Cogs.
    And, a partridge in a pear tree..!!
    Whew.
    Edwardo
  13. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
    Excellent!!!
    Mind you it's a bit creepy, with all those bugs around... ;-)
  14. 350HPMondial
    5,321
    Edwardo
    #114 350HPMondial, Aug 25, 2015
    Aaaaaaaaaaa a properly sealed cam cover gasket.
    Hoo Raaaa.
    Polyurethane on top and a schmallll schmearrrr of Silcon on the bottom.
    Sssschmile.
  15. 350HPMondial
    5,321
    Edwardo
    Ha ha my Bro.
    Bugs here are harmless,, just Uuuuuuugggglyyyyyyy.
    Smile.
  16. Bell Bloke
    Dec 6, 2012
    1,839
    Engine looking terrific, what with the vernier cam pulleys and all.
    What's your cam timing set too?
    Regards Bell
  17. 350HPMondial
    5,321
    Edwardo
    Bell,
    A difficult question,, I will try to answere.
    Factory Cam setting for the California Smog Check.
    But, My car is a Euro 308,, with EURO Exhaust Cam.
    Factory Ferrari Euro Cam timing is a little different then a USA spec. car.
    Before I start to play with cam advance, I think I need to address The Very Poor flowing Ferrari intake system, to enable the cam to be advanced more,, and,, next, get new cam, with more duration.
    Whew,
    Edwardo
  18. 350HPMondial
    5,321
    Edwardo
    #118 350HPMondial, Aug 28, 2015
    Foreward 308 Ferrari motor Bank,,,,, Celinders 5,6,7,8 All ready to go.
    Spark Plugs, a "cool set," (NGK BP7ES) are installed,,, along with 3 cc of Two Stroke oil, I rotated the motor after this,,,.
    but, I'll pull the Sparkplugs in order to spin the engine with the Main oil pressure. For a good flush.
    My Break in oil is going to be a crappy, dinosaurs based oil, it be Castrol GTX 10 w40.
    Then,,,,
    After break in, I'll switch to a good synthetic oil, probably after 500 hours or so.
    Hoo Raa
    Edwardo
  19. 350HPMondial
    5,321
    Edwardo
    #119 350HPMondial, Aug 30, 2015
    The Vail has been cast. ,
    She sleeps,,, ready to be awakened.
    (. Shhhhhhhh,,,, hoo, ,,,,,,, , ,
    , , , , raa..... )
    Edwardo
  20. FCnew
    May 5, 2015
    687
    Hong Kong / Canada
    Jonathan
    +1
    is this going to be 350 HP?
  21. 350HPMondial
    5,321
    Edwardo
    Noooooo,,
    (Duh)
    Only 250 HP,, a very subdued lil girl.
    Edwardo
  22. 350HPMondial
    5,321
    Edwardo
    #122 350HPMondial, Sep 1, 2015
  23. Bell Bloke
    Dec 6, 2012
    1,839
    Yay!! It's in :)
  24. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
    And, she looks gorgeous!
    sid
  25. 350HPMondial
    5,321
    Edwardo
    #125 350HPMondial, Sep 3, 2015
    Bell,
    Thank you. Closer to running.
    Sid,
    Yessss, Sir.
    But, cleaner on the inside.
    Hope she breaks in well.
    Let's see......
    Got good oil pressure.
