Mark, thanks for tuning in. Hoo Raa Hey, see the green tape covering the top, bell housing view port.? Well, Inside the bell housing, is an undiscovered Black Hole, with infinite, inescapable gravity. It pulled in a Large 1/2" socket....??? How..?? Gravity and Murphy's law ,, thus, I am really good at pulling the bell housing and the starter. Soon, I will install said port cover. More to follow. Edwardo Image Unavailable, Please Login
Thanks Howie, But, do you really eat off you motor...? Ha ha Soon, to be driven and dirty. See updated photos. Edwardo Image Unavailable, Please Login
Adding Gear Oil. Gallon plus a little in the drop gears. Next,, torque the rear header,,, oh,,,, yes. Edwardo Image Unavailable, Please Login
Ed You can't go out with your car, you can't! This engine is soo clean you'll cry an eye out when first road grime is visible.
Well,,, I'm crying now also. But, not over cleanliness . Transmission leaking at bell housing,, Aaaaaaarrrrrrgggggggg. Pull bell cover. ,,, , , , , Drop tools into inspection port. Pull bell cover. , , , , , Two stripped M8 studs needing heli-coils. , , , , ,pull bell cover. , , , Ashtray full. , , , Pull bell cover. Edwardo Image Unavailable, Please Login
Use three different taps with light oil. Read your cutting fluid label, some can't be used on aluminum,,, especially, Ferrari alloys, because of their High quality. Edwardo Image Unavailable, Please Login
See my home made tool for holding the lower drop gear. Hoo Raa Edwardo Image Unavailable, Please Login
Back in the 40s or 50s (before or after, as well), you'd be called "a real, honest to goodness, hot rodder" !! Cheers, Hank
Thanks Hank, See my home made Fuel Injector tester. Found two sticky injectors out of 8. 25% failure rate out of the box..! My CIS , Mercedes Benz, guru told me to clean the two,, and, test again,,, before ordering replacements. Image Unavailable, Please Login
Got three new Bosch fuel injectors, to replace the two with poor atomization. Fitting cams and Scottys Aluminum Cogs,,, ready to set the valve clearance on the rear set of 8. Need to work on the foreward Cam Saddles,, blue,,, scrape, !, etc. Looking pretty.. Maybe. Whew. Smile Edwardo Image Unavailable, Please Login
This injector functions good. Ready for seal installation. Edwardo Hoo Raa Image Unavailable, Please Login
See how to do.. Don't be in a hurry,, line up the hex head on the injector unit with the coller. Ok, Whew...! Edwardo Image Unavailable, Please Login
