250 HP Mondial, Cheap Ferrari,, etc. | Page 10 | FerrariChat
Discussion in 'Mondial' started by 350HPMondial, May 30, 2014.
  1. 350HPMondial
    350HPMondial F1 Veteran
    5,323
    Edwardo
    Mark,
    I'm guessing the you mean the seal,,, which is installed first,, behind the drive gear.
    I first installed the seal,, but not all the way,,, just enough to see the MT snap ring grove. ( grease the seal good with MO grease.)
    Next I installed the snap ring, but not in the groove,,,, install it with snap ring plyers,,,,, 1/4" prior to it snapping into the groove.
    Now, get a plastic piece of PVC pipe, over the shaft. (Mark it with tape so you know how deep it is,,,, when tapping...) Use it to slowly tap in the snap ring,,, which is used to push the seal in, the snap ring will now snap into the groove, this way, the snap ring prevents pushing the seal in too far. ( NOTE; if you push the seal in too far,, you must destroy it to remove it. Thus, always buy extra.)
    Now, heat bearing to 250 deg,,, drive it home with a piece of mild steel pipe,, now another snap ring.
    Finally, the drive pulley is installed. ( I use a Titanium washer under the "split nut." Superperformance has HEX nuts, to replace the split nuts.. I bought extra.)
    The new bearing just torques against the last snap ring.
    Good luck,
    Eduardo
    davem likes this.
  2. 350HPMondial
    5,323
    Edwardo
    see tools for driving home an outer front cover bearing.
    note the fat, 1/2” thick,, Aluminum Washer.
    used to keep the force evenly distributed between the two bearing races.
  3. mwr4440
    57,919
    Bavaria, The 'Other' Germany
    Mark W.R.
    Edwardo,
    Thanx Muchly, but no, I meant the drive gear (pullie).
    How do you know it is on 'far enough/correctly' to be lined up with the cam belt pullies?
  4. 350HPMondial
    5,323
    Edwardo
    Mmmmmmmmm,
    Good question...
    The pullie is on,,,,, all the way when it is bottomed out on the Front Cover Bearing “Inner” Race.
    Then the “split nut,” or new hex nut,, is torqued.
    I did place a straight edge,, on the face of the one or both pullies,,, to see how they align with the Cam Drive Cogs.
    Bravo.
    Hope this helps.
    Eduardo
  5. mwr4440
    57,919
    Mark W.R.
    Thanx Edwardo.
  6. 350HPMondial
    5,323
    Edwardo
  7. 350HPMondial
    5,323
    Edwardo
    See a streatched Head Stud.
    :eek:
    Checked all 10,, on this rear valve job.
    FerrParts had one.
    $30.
    I also replaced all 10 Cap Nuts.
    $12 ea
    (whew)
    Eduardo
    paulchua likes this.
  8. 350HPMondial
    5,323
    Edwardo
    see 2nd O2 sample port.
    welded onto the rear header.
    ready for a second fuel/oxygen mix gage.
  9. 350HPMondial
    5,323
    Edwardo
  10. 350HPMondial
    5,323
    Edwardo
  11. 350HPMondial
    5,323
    Edwardo
  12. 350HPMondial
    5,323
    Edwardo
  13. 350HPMondial
    5,323
    Edwardo
    Got me a new Mechanics Helper.......
    Her photo is from sophomore high school Yearbook.
    1978 ( if I mention her age,,, I’m a dead Ferrari owner.)
    We used to dance together in the Gym after football games.
    I’m the worlds luckiest Ferrari Owner.
    Now if I could just find a scanner wrench to remove the gas tank sender,, ,,, aaaaaaahhhhhhhhggggggg.
    Eduardo
    JLF likes this.
  14. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
    Congrats!
  15. 350HPMondial
    5,323
    Edwardo
    Hey now,
    Life is magic,,,, and
    then you get a Ferrari.
    Eduardo
  16. 350HPMondial
    5,323
    Edwardo
  17. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    The decals are a genius idea. I'm about to add some extra gauges to my 308 and I will totally steal this idea. ;-)
    350HPMondial likes this.
  18. 350HPMondial
    5,323
    Edwardo
    no,, Ferrari Brother,
    I spent ,,, like,,,
    $ 0.87 cents on those decals.
    gotta send me $ 0.435. cents.
    lol
    and,, a ride in your car.
  19. Temple
    Temple Formula Junior
    Jun 13, 2015
    594
    Portland, OR
    Temple
    ATSAaron are we going to hear from the new owner here of your beautiful black coupe??
  20. aabryan
    aabryan Rookie
    Apr 23, 2012
    38
    Hey all! I’m the black coupe’s new caretaker. I’ve been off the forum a bit recently. New baby on the way and getting a new business off the ground. What’s up? [​IMG] [​IMG]
    ronfrohock and 350HPMondial like this.
  21. 350HPMondial
    5,323
    Edwardo
    pretty car.
    Interesting wheels.
    18”.....?
    but,, your
    Hyster needs some care.
    at least a
    Wax and Shine.
  22. aabryan
    aabryan Rookie
    Apr 23, 2012
    38
    Hahaha not my hyster. They’re speed lines. I believe they are 18 but I need to go out and look. Considering swapping for 348 wheels.
  23. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
  24. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,654
    Argent/Brasil
    Guido
    Love the decalls on the front wings...should be more to the front a bit...but love those on that dark color.
