246 Decals | Page 2 | FerrariChat
246 Decals
Discussion in '206/246' started by TonyL, Jul 21, 2019.
  1. HMB-Dino
    HMB-Dino Formula 3
    2,175
    Pebble Beach, CA
    RonG
    I'm a bit confused. Perhaps it would be best to show which tag went with which clock (ie, show the clock face)...that would make it very clear.
  2. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,857
    Norfolk - UK
    Tony
    Ron - It depends on what "electronico" clock you have, both I believe are identical to look at but have a different operation on the small knob that adjusts the time. Either it pushes or pulls. It could be the Daytona, 512 or 365 clocks are different - I don't know.
    some are selling the Quartz tags for the 246, this is incorrect as far as I know, they belong to the later cars ie the 308 series.
    https://www.ebay.co.uk/itm/Rare-Original-Ferrari-246-Dino-308-Veglia-Borletti-Clock-Tag-Instructions-/173885064413
    Tony
  3. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    May we please see the reverse?
    8 years ago I loaned an original "Pull" to a friend that is one of Shaughnessy's sources to make repops, might be from that batch.
    There are some small tell tales, such as "041" vs "042" on the last line
  4. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,857
    Norfolk - UK
    Tony
    see post 18 - 042 is the end digit numbers - I don't have the reverse side.
  5. HMB-Dino
    HMB-Dino Formula 3
    2,175
    Pebble Beach, CA
    RonG
    I don't have an `electronico' clock...trying to determine which tag is correct
  6. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,857
    Norfolk - UK
    Tony
    Ron - I would guess your clock tag would be the electric tag - easiest way to find out, does the knob push or pull.
    Here is the reverse side of the tag
    synchro likes this.
  7. Eltel246
    Eltel246 Karting
    May 14, 2012
    155
    London
    Charles Hill
    TonyL likes this.
  8. HMB-Dino
    HMB-Dino Formula 3
    2,175
    Pebble Beach, CA
    RonG
    Just got to check out my clock...it's a `pull and turn to set time' clock. And the second hand ticks rather than a smooth sweep. I should note that my clock was rebuilt some years ago and I can't say whether anything about it changed as a result of that rebuild.
  9. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,857
    Norfolk - UK
    Tony
    Sounds like its an electric version ? whatever that is!!
  10. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    That is the quartz movement installed in an OEM clock - Clause Meese has been doing that for decades on these clocks.
    That Clock tag on Ebay is a copy, but at the $9 price not worth it
  11. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,857
    Norfolk - UK
    Tony
    Scott - What clock tag is on ebay (post 31) ?
    Superformance do the clock tags for the electronic version and sensibly priced at £24. You could pay £500 - £1000 for an original if your wallet is bursting at the seams. In my opinion they are a good replica and adds a little extra to the dino pack of collectable items.
  12. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
  13. TTR
    TTR F1 Veteran
    5,214
    Riverside, CA
    Timo
    Might be a good idea to research that further.
    I could be wrong, but believe these labels were initially intended for U.S.-delivery examples to indicate belts meeting U.S. D.O.T. regulation standards, hence printed in English.
  14. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,857
    Norfolk - UK
    Tony
    Finally got around to making some new replica Klippan seat belt tags for the UK version. Really pleased with how they turned out.
    Fortunately i had the old ones to copy and managed to get the right colour polyester to match exactly.
    I have a few spare if any one wants a set.
    Tony
    dgt likes this.
  15. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,434
    Toronto / SoCal
    Rob C.
    Very nicely done Tony.
    TonyL likes this.
  16. HMB-Dino
    HMB-Dino Formula 3
    2,175
    Pebble Beach, CA
    RonG
    Perhaps this has been addressed already, but were there different seat belt tags for Italian delivery Dino's?
  17. celestialcoop
    celestialcoop Formula Junior
    714
    Coop
  18. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,857
    Norfolk - UK
    Tony
    Each country would have its own standard and therefore different tags.
    The tag is OE but the fraying isnt- Is it stitched to the webbing? to stop the edge fraying even more and ruining the original tags then you can use a fabric sealer or a very small amount of super glue on the outer edge.
  19. HMB-Dino
    HMB-Dino Formula 3
    2,175
    Pebble Beach, CA
    RonG
    Awesome...now if I could only find them!
  20. celestialcoop
    714
    Coop
    #45 celestialcoop, Nov 16, 2019
    Tony,
    The tag is only captured along its top edge under the stitched webbing; the two sides have embroidered edges, and the bottom is unfinished. The tag waves freely, like a tiny flag. As you know, their location shelters them from direct sunlight and they are removed from chafing, wind or other contact. I'm not sure why they have 'weathered' so.
    At any rate, I appeciate your suggestion and will attempt to preserve them.
    Cheers,
    Coop
  21. celestialcoop
    714
    Coop
  22. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,857
    Norfolk - UK
    Tony
    Coop
    The polyester material is woven vertically and horizontally so when it is cut there is nothing to stop the fibres coming adrift. The side edges are heat sealed when the ribbon is cut from the sheet of material which looks like an embroidered edge. I wouldnt advise using heat on a valuable item as this, the wife's nail polish is good as well. Use sparingly.
    Most i have seen are stitched at both ends, the lower edge is attached face down, then folded over and stitched as your ones sandwiched between the webbing, they did this to stop the edges frayng as your example!.
    What version dino was this Tag fitted to, mine are for UK cars and were fitted to other models of the era ie Daytona, 365 etc?
    Best
    Tony
  23. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,857
    Norfolk - UK
    Tony
    Do you know anyone who can do the artwork in pdf, i have the ribbon?
  24. celestialcoop
    714
    Coop
    Tony,
    'more interesting info. Thanks.
    I don't recall seeing any indication on the webbing of attachment of the tag along the frayed edge. I've also expanded each of the four pics that I posted and nothing stands out. Hmmm. I'll go out first thing in the morn and detach the belts for a close-up exam.
    Further, I plan to source a soft plastic (ideally opaque or tinted) sleeve to slide over the end of each belt to protect/preserve the tags.
    Oh, these reside in an Italian delivery Tipo E 246 GT.
    Coop
  25. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,857
    Norfolk - UK
    Tony
    I cannot see any evidence of stitching either so they must of come like this, us Brits are more thorough :)
    Good idea on some sort of plastic sleeving, cling film? If they have survived this long then i guess they may go the extra mile, you need to stop the frraying though, it will unravel itself eventually.
    Best
    tony
