2020 Barcelona Testng: Feb. 19th - 21st & Feb. 26th - 28th | Page 5 | FerrariChat
Discussion in 'F1' started by jgonzalesm6, Feb 6, 2020.
  1. Ferrari 308 GTB
    Ferrari 308 GTB F1 Veteran
    Feb 21, 2015
    7,730
    Tropical
    Maybe to compensate for the inertia of the driver tending to slide forward under braking?
  2. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    41,359
    ESP
    Bas
    stavura and Flavio_C like this.
  3. jgonzalesm6
    jgonzalesm6 Two Time F1 World Champ
    20,715
    Corpus Christi, Tx.
    Joe R Gonzales
    Craig Scarborough
    Lots of videos now emerging of the Merc steering wheel being moved backward when joining the straight, with some apparent effect at the front wheels, then bring moved forward before braking. It could be just play in the assembly. Perhaps the column also moves the steering rack
  4. Bas
    Mar 24, 2008
    41,359
    ESP
    Bas
    10.2.3 No adjustment may be made to any suspension system while the car is in motion.
    It's illegal as ****, basically.
    stavura and Igor Ound like this.
  5. Bas
    Mar 24, 2008
    41,359
    ESP
    Bas
    not a chance that's ''play'' in the rack, and then magically changes the toe angle!
  6. Pis7a2020
    Pis7a2020 Formula Junior
    Dec 17, 2019
    665
  7. Ferrari 308 GTB
    Feb 21, 2015
    7,730
    Tropical
    Lewis stopped doing it now LOL
  8. Bas
    Mar 24, 2008
    41,359
    ESP
    Bas
    I can't see how it'll be legal at all. It's moving suspension components...it basically allows them to run more toe (better cornering), which would normally have significantly extra tyre wear, but they straighten it out on the straight, allowing for higher top speed (less mechanical drag) and much lower tyre wear.
    Brilliant innovation but utter shambles if they allow this.
  9. SPEEDCORE
    SPEEDCORE Four Time F1 World Champ
    Jul 11, 2005
    45,906
    Toe Knee
  10. G. Pepper
    G. Pepper Three Time F1 World Champ
    33,964
    Texas/Colorado
    George Pepper
    I'm sure it's just to get testing data and arrive at the best toe in compromise.
    Ferrari 308 GTB likes this.
  11. SPEEDCORE
    Jul 11, 2005
    45,906
    Toe Knee
  12. SPEEDCORE
    Jul 11, 2005
    45,906
    Toe Knee
  13. Bas
    Mar 24, 2008
    41,359
    ESP
    Bas
    Renault update:
    Everything is broken.
  14. Ferrari 308 GTB
    Feb 21, 2015
    7,730
    Tropical
    Good point ,its a lot quicker then coming in and out the pits to alter the toe in
    no doubt they run all the scenarios in the sim ,then confirm it on track,or not.
    G. Pepper likes this.
  15. Bas
    Mar 24, 2008
    41,359
    ESP
    Bas
    that seems like an expensive engineering challenge to put just that in for testing purpose only.
    Igor Ound likes this.
  16. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,836
    Norfolk - UK
    Tony
    Not necessarily illegal when you consider
    Article 10.4 - Steering (not suspension)
    10.4.1 Any steering system which permits the re-alignment of more than two wheels is not permitted.
    (the intention of this regulation i suppose was to prevent 4 wheel steer!)
    Clever solution, seen this used before in grass track racing, my guess is it is legal but not in the spirit of the reg's, so long as it passes the safety impact test under 10.4.4
    DGPF likes this.
  17. SPEEDCORE
    Jul 11, 2005
    45,906
    Toe Knee
  18. Bas
    Mar 24, 2008
    41,359
    ESP
    Bas
    but surely the adjustment is made using track rods...a suspension component. And I think it could (easily) be argued that the adjustment is not made trying to steer the car but rather adjust the geometry to gain an advantage in both straight line and corners.
  19. Bas
    Mar 24, 2008
    41,359
    ESP
    Bas
    Mercedes just confirmed it's NOT just for testing and they intend to race it. They call it a different steering ''mode''. unbelievable.
    stavura, Igor Ound and Nortonious like this.
  20. Ferrari 308 GTB
    Feb 21, 2015
    7,730
    Tropical
    Wait until the Stroller starts to move it in and out!:D
  21. SPEEDCORE
    Jul 11, 2005
    45,906
    Toe Knee
  22. fer312t
    fer312t Formula Junior
    Nov 16, 2010
    777
    Very trick system...fun stuff :)
    Regardless of whether it's ultimately legal or not, top points for clever interpretation and implementation - it's a nice pysch job if nothing else.
    A348W and Flavio_C like this.
  23. Patrick Dixon
    Patrick Dixon Formula 3
    Mar 27, 2012
    1,084
    If it's changing the wheel alignment then it's not adjusting the suspension it's adjusting the steering. I have no idea whether it's legal or not, but innovation is what F1 should be about.
    DGPF and tifosi12 like this.
  24. Ferrari 308 GTB
    Feb 21, 2015
    7,730
    Tropical
    Meanwhile down the pit lane garages..[​IMG]
    DGPF and G. Pepper like this.
  25. G. Pepper
    33,964
    Texas/Colorado
    George Pepper
    I would expect protests. The movement of two wheels in the steering reg is meant to allow steering of only two wheels, and not four, but not changing camber and/or toe in separately from the steering geometry. I'd be surprised and disappointed if they allow it.
    stavura and Bas like this.
