2007 Ferrari F430 for 40K
Discussion in '360/430' started by jdfenn, Mar 31, 2025.
  1. Qavion
    Qavion F1 World Champ
    13,844
    Ian Riddell
    Ok, thanks... I just saw this, so I thought the pump for the F1/eDiff might be playing up.
  2. jdfenn
    jdfenn Karting
    Jan 28, 2022
    74
    Jeff Fenn
    It seems to me the controls on the steering wheel are activating the actuators to shift but perhaps the clutch is not engaging to allow the gear change.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,675
    Central NJ
    Dominick
    I will send you a PM with my number .text me first and then we can get in a call
  4. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,833
    The Cold North
    Tom
    What fault do you have in the TCU?
    flash32 likes this.
  5. jdfenn
    jdfenn Karting
    Jan 28, 2022
    74
    Jeff Fenn
    That’s the crazy thing, I don’t have any that pertain to f1 system
  6. tbakowsky
    Sep 18, 2002
    19,833
    The Cold North
    Tom
    Can you talk to the TCU at all?
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,675
    Central NJ
    Dominick
    I was on the phone with Jeff for a while .. we did a complete diag of the TCU and have a plan of attack but unfortunately we need a more capable tool to continue
    We will pick up Monday or Tuesday after tool arrives and go from there .. rest assured we will report back with what the issue(s) was and final resolution
    This is for the F1 issue he mentioned above - no shifting
    We also spoke about CAT temp fault - I think something is going on with comm between the two ECUs and he ends up running on one bank. This floods the CAT with fuel and when he fires up the second time it causes the issue - i ask him to try to wait a few minutes after he turns key to see if that resolves issue - if it does, it may be the IMMO off coding causing the issue - TBD still
    Pete Schweaty and Qavion like this.
  8. jdfenn
    jdfenn Karting
    Jan 28, 2022
    74
    Jeff Fenn
    Huge thanks to @flash32 for hopping on the phone for almost an hour yesterday to walk me through step by step on how to get the car in gear yesterday. Here is the best recap I can make for what we did.
    1. First, the car would start initially and run slightly rough then give a slow down light and then turn off. (we believe this is what is throwing the Catalytic converter error)
    2. Then the car would immediately restart and run and idle smoothly with no slow down light.
    3. Flash startred by discovering what model transmission I had which was helpful when using the diagnostic tool. Turns out I was looking at the older model the entire time.
    4. Next we went though a variety of metrics looking to see the current values and comparing those to normal.
    5. These values were all discovered in the live data of the TCU.
    6. The key metrics we checked, to the best of my memory, were Hydraulic pressure, F1 pump re-pressure time, and then dwell time - the amount of time the F1 system held pressure. Ill post my actual numbers in a follow up post so other members have something to compare theirs to. We also checked centering, clutch wear, and several other things.
    7. Then we moved on to doing the actuator calibration active test and the differential bleed active test.
    8. We checked the pressure during and after each of these tests to make sure they seemed ok.
    9. Then we used the manual gear engagment for 1st, 2nd, and Reverse gears.
    10. At first the car did not want to go into first but is slid into second. Then it went into reverse. Then it went into first.
    11. Then we tried it with the car running and used the paddles and the reverse button. Each of the gears were selected and the car went into first, second, and reverse with the paddles and the button as normal.
    12. My Autel scanner does not have the ability to do a relearn so I ordered the Thinkdiag2 and and android tablet to pull the function off.
    13. We were also able to determine that my accumilator was a little week and only holing pressure for 4min. I ordered a new accumilator.
    A couple side notes
    1. We believe that during the initial drive the car went into a limp mode of sorts. Then I tried to bleed the F1 system and the selenoids which further confused the actuators and shifting system. Essentially taking one issue and making it two.
    The plan is to relearn the transimission and the ediff and then tackle the catalytic converter over temp.
    Flash believes that as part of the immobilizer defeat they could have created a system that doesn't let the engine check complete before the Engine OK light is displayed and then I am trying to start the car early. This results in a bunch of raw fuel being dumped into the cat an igniting which is causing them to overheat and turn the car off, then placing the car in a limp mode. We are going to try to let the ECUs fully startup and warm up giving them a full 2 minutes to get spinning and then try to start.
    Hope this helps anyone else in search of solutions.
    Jeff
    flash32 likes this.
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,675
    Central NJ
    Dominick
    Jeff ..great recap
    Just a few small corrections / clarifications
    ****Flash started by discovering what model transmission I had which was helpful when using the diagnostic tool. Turns out I was looking at the older model the entire time...
    This is reversed ..you were using the newer version 3.01 and should be using 2.31
    ***The plan is to relearn the transimission and the ediff and then tackle the catalytic converter over temp
    They should say the plan is to do self relearn on the transmission/gearbox and retest the Ediff solenoid.. most likely needs to be replaced then tackle the catalytic converter overtime
    *****. Then I tried to bleed the F1 system and the solenoids which further confused the actuators and shifting system. Essentially taking one issue and making it two
    When Jeff removed the actuator to do a proper bleed the shifting grid was distributed and further compunded the issue .. a self relearn should fix that
    We will report back how the self relearn and e-diff test goes ..
    Dominick
    AandSC likes this.
  10. jdfenn
    jdfenn Karting
    Jan 28, 2022
    74
    Jeff Fenn
    yes it communicates with tcu just fine
  11. jdfenn
    jdfenn Karting
    Jan 28, 2022
    74
    Jeff Fenn
    Sunday update,
    Did a couple very simple tests to investigate the Cat Temp High error coming across immediately after startup. Started the engine, it threw the cat over temp code, displayed a slow down light and killed the engine. Restarted the engine and it ran fine and smooth.
    Le the engine get up to temp and measured the cats with and external thermometer and they were both at 510 degrees.
    Launched my scan tool and went live data in right engine and in the left engine the CGT - calculated exhaust gas temperature was -25degrees C and the Catalyst temp on both sides was -50degrees C. Neither of these values changed at all during warm up.
    Does anyone know how the 2007 F430 actually reads the temps. It must be through some sort of emission system or it is an equation of some sort?
    Could it possibly be the Co2 sensors being bad, or perhaps they are just unplugged somewhere?
    I don't think the 2007 f430 has the exhaust ECU like the 360 but maybe I am wrong.
    thanks again guys
    Jeff
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,675
    Central NJ
    Dominick
    Did you try my theory..turn key and wait 2 mins to start car
  13. jdfenn
    jdfenn Karting
    Jan 28, 2022
    74
    Jeff Fenn
    Yeah a couple different times and it acted the same.
    I even waited a full 2:30 one of the times and it didn't make a differance.
    I went ahead and traced back O2 sensor wires and one was missing a clip but seemed to be plugged in fine. I replaced the retainer clip.
    flash32 likes this.
  14. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,675
    Central NJ
    Dominick
    I don't recall when the thermocouple was removed from the f430 ..2006 or 2008
    You can always switch sides or even the wires if it reaches and see if makes a difference
  15. Mario Andretti
    Mario Andretti Formula 3
    1,745
    Boston
    Check the assembly number.... See my post 112. Thermocouples are there up to ass. no 67970 (check the plate on the beam behind the exhaust muffler) . Or just look at the headers, you will have some nice O2 sensor like thingies poking out of them if you have them.
    EDIT: If you have them, I have no doubt they are the culprit. Mine did the same, shutting off the engine bank completely.
    flash32 likes this.
  16. jdfenn
    jdfenn Karting
    Jan 28, 2022
    74
    Jeff Fenn
    lll have to check that, pretty sure mine doesn't have them.
  17. jdfenn
    jdfenn Karting
    Jan 28, 2022
    74
    Jeff Fenn
    Just want to clarify a bit. The red slow down light comes on immediately after start on a cold engine. The cats are not hot and never over heat.
    I know that the co2 sensors don’t start sending data right away until the system enters a closed loop status.
    my question is, how does the car make a decision before that time?
    im assuming these are parameters programmed into the computers.
    can this programming be turned off? If so what type of programmer would you need?
    also, I know the mechanic that had the car before had switched the ecus, right for left, could this cause an issue like this?
  18. jdfenn
    jdfenn Karting
    Jan 28, 2022
    74
    Jeff Fenn
    One other though is if the car relies on maf sensor for early open loop calibration could it be a vacuum leak or intake leak causing the issue?
  19. sammyf
    sammyf Formula Junior
    Aug 13, 2004
    255
    Northern California
    Late MY07 for US cars. Early 07 builds had physical temp sensors, late do not. There was corresponding ECU software change. If @jdfenn can post ECU part labels, I can probably verify.
    jdfenn, flash32 and Qavion like this.
  20. Qavion
    13,844
    Ian Riddell
    The car can be updated from a thermocouple type to a no thermocouple type:
    https://www.ferrarichat.com/forum/posts/146735054/
    But it sounds like you don't have them anyway. Have older ECUs been fitted without the correct software update?
    No, the ECUs are identical. Although the L/R ECUs have some different functions, they know where they are when they are plugged in. The extra wire on the L ECU tells the ECU where it is.
    jdfenn and flash32 like this.
  21. jdfenn
    jdfenn Karting
    Jan 28, 2022
    74
    Jeff Fenn
    Ok thanks, that rules that out. Mine does fall in the group without thermocouples. I’ll post pics of the ecus to make sure those look like the correct ones.
  22. jdfenn
    jdfenn Karting
    Jan 28, 2022
    74
    Jeff Fenn
    I’ll have all the tools today to relearn the Tran’s so hopefully flash and I can check that off this evening.
  23. jdfenn
    jdfenn Karting
    Jan 28, 2022
    74
    Jeff Fenn
    My question on programming was more on cat delete specifically. For example, when guys install cat deletes they must reprogram the computer in some way not to check the cat temp. If I’m planning to put on a full valvetronic exhaust with no cats, does it make since that the cat over temp error would go away with that change anyway???
  24. Mario Andretti
    1,745
    Boston
    YES, that is what I did. I installed Fabspeed headers (which have no cats) and I got my computers programmed by @sammyf. The aftermarket headers come with a plug where the thermocouple was (some of them) . I eliminated them completely and I got a bit more power too - with the new software and better flow - , and great sound when full throttle :)
  25. Mario Andretti
    1,745
    Boston
    But if you don't have thermocouples, I am not sure now what and how is that temp check performed... the ecus apparently have other means of checking the cats... maybe using O2 sensor values
