2-post lift for low-clearance Ferrari? | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by dantm, Jun 21, 2009.
  1. dantm
    dantm Formula 3
    Nov 1, 2003
    1,103
    YYZ, BOS, SFO
    Dan B.
    Hi, can you guys give me some suggestions for a 2-post lift that would be suitable for a low-clearance Ferrari? Given that some of these cars have 5" or so of ground clearance (or lower?), I assume a regular 2-post lift would not work since the arms would be situated higher in their lowest position than the bottom part of the car.
    Are there some lifts that have lower clearance arms or would there be adapters that are used?
    Or maybe the idea is to use a minor ramp for each wheel to raise the clearance of the car? I.e. as you position the car between the lift posts, each wheel goes up on a little wooden platform/incline to give it a few inches of clearance.
    Thoughts?
    Thanks!!!
  2. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    I have a Mohawk 2 post. I jack each side of the car and put 2 x 6 blocks under the wheels, then it goes right on.
    In my experience, it takes some getting used to putting a car on the lift for the first time. Once you figure it out, it goes very easily. Just finished changing the oil in my 355, easy as pie.
  3. dantm
    dantm Formula 3
    Nov 1, 2003
    1,103
    YYZ, BOS, SFO
    Dan B.
    Interesting -- the other thing that I was thinking of is that you could sink in the lift a little bit but I think the block idea is the best and least hassle...
  4. tr0768
    tr0768 Formula Junior
    Oct 28, 2008
    735
    Lake Stevens Washington
    Howard Musolf
    We have many hoists in our Subaru
  5. tr0768
    Oct 28, 2008
    735
    Howard Musolf
    We have a number of hoists in our Subaru Service Centers. Many of our customers lower their WRX's and Imprezza's. We use a 3' length of 2X8. One piece for each wheel(4).
    This allows our techs to drive the lowered vehicle easlily up on the blocks with little or no chance of slipping off or damaging a wheel or exhaust system. These longer boards are tapered on the leading edge so driving up on them will not slide them forward. If you were to lower the hoist below floor level you will sacrafice elevation height. Also the well that you place the hoist base in will be a collection point for fluids, oil, water, and general floor sweepings. Much easier to mount your hoist on the flat surface and use drive on boards. Once done with your service you remove the boards from the floor and your floor is smooth and easy to sweep and clean.
    Howard Musolf
    1981 Ferrari 308gtsi
    Maserati spyder
    2 many brass era cars
  6. drmikethompson
    drmikethompson Karting
    Oct 7, 2006
    57
    Jonesboro, AR.
    Michael L. Thompson
    I have a Bend Pak HD-9 four post lift and my 512 TR and F430 go up on the ramps and onto the runways without any boards or ramp extensions. Make sure you get the model that allows you to adjust the runway separation. I have had no problems at all.
  7. aclifts
    aclifts Rookie
    Nov 10, 2005
    11
    Folsom, CA. 95630
    Brad Davies
    #7 aclifts, Jul 1, 2009
  8. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    The problem with the low profile arms is that in many cases the arms themselves have to go under the car too. So even if the pads are low, you have to raise the car. In a shop, you have more options. In a home, you often get limited by the height of the lift and the width you want to space the posts. The more clearance you have both up and out, the more choices you will have with lifts.
  9. Jdubbya
    Jdubbya The $10 Trillion Man
    42,249
    PNW
  10. AceMaster
    Feb 6, 2009
    34,749
    Ontario, Canada
  11. Jdubbya
    42,249
    PNW
  12. AceMaster
    Feb 6, 2009
    34,749
    Ontario, Canada
  13. mousecatcher
    mousecatcher Formula 3
    Dec 18, 2007
    2,116
    san mateo, ca
    the harbor freight ones, like most dollies, aren't wide enough to work with many sportscars. a set of boards is easy and works perfectly.
  14. Jdubbya
    42,249
    PNW
    Hmm never thought of that. I was just a friends house who had a similar set and they worked on my car. Of course anything newer than a 308 like mine would have wider tires I'm sure. I wonder if the Griot's set is wider, I never looked that close.
  15. stephenofkanza
    stephenofkanza Formula Junior
    Mar 5, 2005
    542
    Kansas
    Stephen LeRoy Sherma
    I use wood blocks at the front only. You have to make sure when the car is on the block that the hoist arms have clearence to swing into position both at the front and rear. I painted guides on the floor for the blocks then I followed it up with guide lines from the lift to the garage door. If the 308 is between the lines upon entry and you stay between the lines your on the blocks easy. I only have to level the car when changing the transaxle oil (wihch is easy enough, raise, put 2 jack stands at the rear, then lower on to the stands and use 2x4 blocks on the lift pads, then raise, when lower on the stands and remove blocks off the pads, raise, remove jack stands then lower).
    I now have raised the floor in front of my work bench to the height of the wood blocks. Much more comfortable than the concrete when working at the bench.
    Stephen
  16. MordaloMVD
    MordaloMVD F1 Rookie
    Sep 7, 2005
    4,222
    WA
    Michael von Ditter
    Griots claims to handle up to 13".
