1999 550 M STICK CRANK NO START | FerrariChat
Discussion in 'Technical Q&A' started by kdross, Jul 16, 2021.
  1. kdross
    kdross Formula Junior
    887
    NJ
    Ken
    CAR CRANKS BUT WONT START, FOUND NO CHECK ENGINE LIGHT ON WHEN IT DOSENT START . HAD BOTH ECU CHECK TWICE NEW FUSE BOX AND RIGHT RELAYS FROM GT CAR PARTS . YOU LEAVE KEY ON AND LISTEN FOR 30 SECOND YOU WILL HEAR RELAYS CLICK AND CHECK ENGINE LIGHT GOES ON . CHECK ALARM MODULE AND IMMOBILIZER , GOOD BUT IT CRANKS. REMOVE BOTH PASS AND DRIVER HARNESS CONNECTORS TO CLEAN, FOUND PASS. SIDE CONNECTOR NEED TO BE CLEAN. CHECK ALL POWERS AND GROUND BY PIN CHECKS . KEY ON POWER IN FUSE BOX AT RELAY BUT MAYBE WEAK GROUND TO PULL RELAY DOWN, JUMP RELAY CHECK ENGINE ON
  2. wmuno
    wmuno Formula Junior
    434
    Wilmette, Illinois
    Bill Muno
    Next steps would be to check if you are getting a spark and if the fuel pump is working.
    Qavion likes this.
  3. Qavion
    Qavion F1 World Champ
    11,533
    Ian Riddell
    #3 Qavion, Jul 17, 2021
  4. kdross
    887
    NJ
    Ken
  5. Qavion
    11,533
    Ian Riddell
  6. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,380
    The Cold North
    Tom
    I'm seeing this more and more. The immobilizer is shot. The car will beeped and crank as normal.. but it will not unlock the fuel pumps.
  7. Qavion
    11,533
    Ian Riddell
    Electricians rule of thumb: If in doubt, go to the last modification :cool:
    Rule of Internet: ALL CAPS is considered to be shouting. It also makes the message harder to read.
