1995 F355 GTS: Restoration and Major Service | Page 45 | FerrariChat
Discussion in '348/355' started by MAD828, Jul 15, 2015.
  1. ShineKen
    ShineKen F1 World Champ
    16,604
    Southern California
    Nostradamus
    What finish coat do you plan on going with? I just repaired mine, but have not decided on finish.
  2. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    My process was to throughly degrease the trays, block sand them to remove all previous coatings, repair any cracks and fill any pin holes.
    This tray in particular was very poorly finished from factory with hundreds of pin holes in the gelcoat so I used a polyester gel coat repair putty and let it set before wet sanding it out.
    Panel wiped it down, 2 coats of fiberglass primer, and then 3-4 light coats of Septone Matt Black acrylic. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    INTMD8, Challenge, Kokose7en and 2 others like this.
  3. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    INTMD8, Challenge and 308 GTB like this.
  4. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Car is awaiting it’s under trays and a replacement brake delay valve which has been ordered and being held up somewhere in the UK. Image Unavailable, Please Login
    INTMD8 and 308 GTB like this.
  5. ShineKen
    16,604
    Southern California
    Nostradamus
    Looks fantastic! Septone.... must be one of those magical Australian brands :).
    MAD828 likes this.
  6. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Thanks, like anything it’s all in the preparation. I painted a section without the proper process and the finish was very poor. So take note you need to properly prepare the surface or it will be patchy. One mistake I made was use wax and grease remover and it gets absorbed by the fiberglass and spoils the finish. Have to use non petroleum based - so I went with methylated spirits as a pre paint cleaner and it was perfect. Painful and time consuming lesson that one!
    ShineKen likes this.
  7. 308 GTB
    308 GTB F1 World Champ
    11,183
    New Jersey
    Barry Wolinsky
    jimmym likes this.
  8. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Thanks! The later year models not only had a slightly different undertray design but the moulds were better and the under trays had a much better finish. They were made by Ranger Plast in Italy, not sure if the early 95’s were too as they were pretty average and roughly finished.
  9. Qavion
    Qavion F1 World Champ
    11,534
    Ian Riddell
    Did you buy the OEM version, Elliott? Scary price. UKP 1,686 from Eurospares.
  10. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    The OEM one from Eurospares is not in stock new. I sourced a second hand item and will wait to see if it is going to be the fix.
    Qavion likes this.
  11. The Outcast
    The Outcast Formula 3
    Apr 19, 2011
    1,561
    Royal Oak Michigan
    Yeah...we could all sit around the car, Mongolian style.
  12. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    INTMD8, judd10, Robb and 2 others like this.
  13. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Under trays finished and reinstalled on the car. Happy to have this item finished as it took quite a bit of time. The end result was worth it! Complete with the factory rubber capped dome nuts and black oxide washers.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    rennspeed, INTMD8, Challenge and 6 others like this.
  14. 0.0.1.99
    0.0.1.99 Formula Junior
    Jan 14, 2012
    423
    Carolinas
    Ken
    Those rubber capped dome nuts have been hard to locate. Do you have a source?
  15. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,381
    The Cold North
    Tom
    You do intend to hopefully drive this car I hope.
  16. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Sure do. I drive it probably more than most. Has 61500 kms on the clock and I look forward to many more with the piece of mind the car is looking and running as per new if not better.
    INTMD8, FourthAlfa, OCKlasse and 3 others like this.
  17. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Unfortunately I do not. I collected them from breakers, purchasing a few to get a nice complete set of undamaged ones.
    Qavion likes this.
  18. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    GTUnit, Illyria, rennspeed and 9 others like this.
  19. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,503
    Lake Villa IL
    Congratulations! Very well deserved. Just when I think the car can't get any nicer you post some more photos :)
    jimmym and MAD828 like this.
  20. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    13,891
    Robb
    Congratulations. Outstanding.
    Robb
    MAD828 likes this.
  21. ShineKen
    16,604
    Southern California
    Nostradamus
    Congratulations. Well deserved. The Ferrari world is in trouble the day Elliot becomes a judge.
    Mike Morrissey, MAD828 and Robb like this.
  22. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
  23. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Completed and installed. Capristo bypass valve reinstated to keep OEM one for safe keeping. Still running stock exhaust and will remain that way for a bit. I will switch back to a Tubi Evolution soon as I’m pretty sure I prefer the note of the Tubi on a 2.7 car over the Capristo.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Robb and Qavion like this.
  24. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
  25. Carmellini
    Carmellini Formula Junior
    Jul 16, 2019
    814
    ain't that the truth...LOL....well said...
    Congrats on all your accomplishments.....you have set the bar very high....and frankly, I appreciate it.
    MAD828 likes this.
