1995 456 GT Windows fix | Page 2 | FerrariChat
Discussion in '456/550/575' started by oss117, Nov 9, 2006.
  1. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    Well guys, it is soon going to be 6 years since I had my windows fixed by the F1 guys in Naples and my car is still as watertight as the day it left the shop.
  2. skl63
    skl63 Karting
    Dec 13, 2007
    228
    Melbourne, Australia
    Scott
    I know they are problematic, but what do you do to service them?
  3. SonomaRik
    SonomaRik F1 Veteran
    late response: THANKS! going to try and tackle it this Sat.
  4. number46
    number46 Karting
    Jun 21, 2005
    110
    London
    Can anyone who has had the F1 fix done give me a clear explanation of what they do? As I have read the posts on here about the fx and I am not clear that I understand exactly what they are changing on the mechanism. It seems to me that the mechanism is not upto the job so I am interested to know what this mods do? As I am in the UK sending the units over to the US is not an economic proposition.
  5. SonomaRik
    One of the 'mods' is to replace Al pins with SS pins.
    But the most effective one I've seen documented is having four flat-head counter sunk screws placed on each 90-degree portion of the pentograph wheel. That ensures the lack of seperation between the two arms.
    PM me if you want pics.
  6. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    You may want to read my first post.
    The window regulator is ok and is retained: what is being replaced is the pin where the lifting arm pivots.
    However, this is only part of the fix, as the glass guides sometime also need to be adjusted and the rear rubber gasket may need to be replaced or modified.
  7. THudgins
    THudgins Rookie
    Jan 17, 2008
    27
    Naples, FL
    Ted Hudgins
    You may be able to ask Eric himself shortly. He was in my office yesterday for some tax and business planning and I suggested he get on FChat to improve his visibility and to share some of his experience about fixing our favorite things which end in a vowel. As long as he isn't flamed to death like Rifledriver and Taz were, we should all benefit.
  8. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    Why would Eric be flamed at all?
  9. dvr
    dvr Rookie
    Sep 19, 2012
    4
    I'm currently fixing the window mechanisms and would be interested in your photos too. I can't PM you, so could you email me.
    So far I've removed both sides and the mechanisms are a mess. Much butchering and bending from previous mechanics. I need to study the arms closely because it looks like there were some bends originally. The alloy spine on the driver's side appears undamaged but the passenger's is gone and something foreign has been welded (looks like chicken ****) in place. Lots of lateral movement though. Hopefully all the wear pieces, slides guides etc, are still obtainable and I can get or replicate the splines. I'm in Australia.
  10. SonomaRik
    PM Sent.
  11. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    On all window-mechanics: once in there, at least go to your local BMW dealer and get six (three for each side) plastic blocks for E36 coupe windows. They are a very well known failure item on those cars so they'll have them on the shelf. I believe PN is 51 32 1 938 884.
    Cost is a few $ each and take out slack that otherwise would have remained - and believe me, you need as little slack as possible. Lubricate with lithium grease on installation.
  12. dvr
    dvr Rookie
    Sep 19, 2012
    4
    Thanks for that guys.
    Should that be 8 instead of six BMW guides? These are the "U" ones that fit to the bottom of the windows and slide up the curved stainless "L" rails, yes?
    I'll also be needing the ones (4x) which are on the ends of the scissors and slide in the channels attached to the lower edge of the windows. Is there a better alternative for those as well?
    Cheers
  13. Tassie
    Tassie Formula Junior
    Dec 17, 2009
    349
    Tasmania, Australia
    Wayne Clark
    Just as a warning to everyone playing with this, when my window was not sealing a local shop (very good) pulled the door trim off and found the mechanism (regulator) loose, so tightened it up and reset the window. Perfect.
    2 days later the window exploded all by itself.
    Further investigation revealed that the arms and regulator itself had been "tweaked" by someone previously, so when the regulator was set right the window likely was going up too far and ultimately exploded.
    Worst part is THERE ARE NO SPARES through Ferrari. I was found a second hand one but it was the only one available at the time. Window works perfect now.
    The shop paid for everything and did not charge for the original fix either - great service.
    If you break one - beware.
  14. dvr
    dvr Rookie
    Sep 19, 2012
    4
  15. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    #40 166&456, Oct 11, 2012
    Most important is to only slightly tighten the bolts that go through the glass. Use loctite to secure them instead of force, very important.
    Per recollection, the Ferrari mechanism uses three blocks per side.
  16. gatorgreg
    gatorgreg Formula 3
    1,944
    NAPLES
    Greg Griffin
    I had a 1995 456. Eric did the fix for me. It worked great. I can't say enough about Eric and F1 imports.
  17. SonomaRik
    did the window mechanism replacement and much better. the newer upgraded model has better adjustment screws for for/aft leveling if not adjustment. Highly recommended if you have older one to acquire newer mechanism. Never heard a good explaination on how to adjust the older one.
  18. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,437
    where did you purchase the new regulator and how much did it cost?
  19. BigTex
    79,368
    Houston, Texas
    Bubba
    It was a Factory recall, your VIN should have been notified by FNA.
    If not, they still owe you the fix???
  20. SonomaRik
    #45 SonomaRik, Oct 23, 2012
    Used, $225 delivered. Ferrparts. Ricambi had the item, but I was after a used one.
    You had so much time to react to the Ferrari 'fix', which was realistically only temporary anyway, and yes, I got the $8,000 'fizzellfix' years ago. They did/do go out and need constant adjustment.
    There were several updated mechanisims and the one I installed is the latest...and very much better.
    Total time to take out and install with alignment: 90 Min.
  21. TheZinger
    TheZinger Karting
    Oct 5, 2019
    50
    I'm curious, is this a similar problem as what occurs on the 550?
  22. tazandjan
    39,151
    Similar, but not the same. 550 windows can usually be adjusted to work fine.
  23. TheZinger
    TheZinger Karting
    Oct 5, 2019
    50
    According to my shop, the regulator is shot. I got a new one that’s sitting in my garage, but reading this I’m wondering if the repair wasn’t in their repartee.
